dave.go
Posted: Sun Oct 30, 2011 9:02 am Post subject: Pinhole leak in top of tank. |
I arrived at the airport yesterday and found a section of the finish lifted about 2" wide and 5-6" long near the top inboard portion of the right tank. quite a small leak, I assume it's a pinhole, quite small at any rate. I will have to remove the wing to address it. I looked up all the posts about sloshing with various compounds. My tanks were made in 1992 and I'm looking for experience with various compounds.
Is sloshing with acetone or MEK and then with thinned Kreem going to work? Is it still the factory recommended solution? I ask because the Kreem site specifically says it is NOT for fibreglass tanks.
Caswell plating has an epoxy resin that is compatible with fibreglass, but everyone talking about it on their site says it hardens rock hard and I'm thinking flexible is a good idea for Kitfox tanks.
http://www.caswellplating.com/aids/epoxygas.htm
Hirsch Auto has fibreglass compatible and flexible sealer. http://www.hirschauto.com/prodinfo.asp?number=GTS
Kreem is of course still available and I could simply replace the tank. The problem is not related to alcohol, it's simply a small leak that I think has just developed over time.
Looking for experiences/ discussion for a solution. Speed is not a factor I am laying the aircraft up for a while to address a couple of problems.
Dave G.
KF IV 1050 582 [quote][b]
dave
![](images/avatars/36051342046dd7967deb50.jpg)
Posted: Sun Oct 30, 2011 9:30 am Post subject: Re: Pinhole leak in top of tank. |
Pinhole leak in top of tank.Get some expoty from Canadian Tire or Home =
depot -- Marine epoxy should work fine for top of tank
looks something like this=
http://www.loctiteproducts.com/p/epxy_mrn_s/overview/Loctite-Epoxy-Marine=
.htm
or get that knead together stuff
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
lcfitt(at)sbcglobal.net Guest
Posted: Sun Oct 30, 2011 12:55 pm Post subject: Pinhole leak in top of tank. |
Dave,
I had the same problem with a 1993 tank, however mine appeared as small BB sized bubbles in the top tank inboard of the filler neck. Since my tanks were factory Kreemed, I resloshed. Kreem and fiberglass? That sounds like a little bit of Lawyer speak to me. I would think that Kreem would adhere better to a resin than to metal and they claim independent tasting shows it is ethanol resistant, but that is just my logic talking. Personally, I think I would go with Kreem. My new projects tanks are 1992 vintage - factory Kreemed, but never seen gas, so take it for what it's worth.
Lowell
Sent: Sunday, October 30, 2011 9:55 AM
To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
Subject: Pinhole leak in top of tank.
Dave G.
href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
Lynn Matteson
Posted: Mon Oct 31, 2011 2:21 am Post subject: Pinhole leak in top of tank. |
Six or seven years since I re-Kreemed my fiberglas tanks, and they're
still going strong without leaks or any other problems...and that's
almost 1200 flying hours.
Lynn Matteson
Jabiru 2200, #2062
Prince prop 64 x 30, P-tip
Rotec TBI-40 injection (sleeved to 36mm)
Status: down for repair....
Lowell
tanks.
Kitfox tanks.
of problems.
Dave G.
KF IV 1050 582
forums.matronics.com href="http://www.matronics.com/
contribution">http://www.matronics.com/c _-
www.matronics.com/contribution _-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
occom
Posted: Mon Oct 31, 2011 1:28 pm Post subject: Pinhole leak in top of tank. |
Thanks for the help guys. I'll be re- sloshing with thinned Kreem, and also
hitting the area with epoxy, and also applying a thin sheet of aluminum and
Proseal over the area. The last one was suggested and I didn't think it
would look very nice, but I'll have to patch over the area anyway so it
might be an idea.
Dave G
KF IV 1050 582
[quote] --
