run up on the trailer
raimo.toivio(at)rwm.fi
PostPosted: Fri Feb 23, 2007 7:43 am    Post subject: run up on the trailer Reply with quote
Those who know:
is it possible to run up an engine
when the plane is on the trailer
and do it safely?
I have a monowheel Europa
and an original Europa trailer
with the optional side supporters.
The trailer is fixed with a car and
the tailwheel is fixed with the trailer.
The wings will be derigged.
Just wonder is it too hard for the main
gear because of the prop torque?
My purpose is just to make it idle,
no full power at all.
Thanks, Raimo
Raimo M W Toivio
OH-XRT Europa XS Mono #417, completed
OH-CVK C172 Skyhawk, under reinterioring
OH-BLL Beechcraft C45, w radial engines (grounded)
37500 Lempaala
Finland
tel + 358 3 3753 777
fax + 358 3 3753 100
gsm + 358 40 590 1450
www.rwm.fi
pr(at)dcanderson.myzen.co
PostPosted: Fri Feb 23, 2007 8:12 am    Post subject: run up on the trailer Reply with quote
Yes - but make sure that the trailer is anchored, the fuse is strapped down
and that the wings and the elevators are removed. The wing supports should
be hinged down on the ground as otherwise the straps may fret.
Roger. G-BXTD
davidjoyce(at)doctors.org
PostPosted: Fri Feb 23, 2007 8:43 am    Post subject: run up on the trailer Reply with quote
Raimo, I did my engine runs that way including full power tests. No
problems. Picture attached. David Joyce
 Filesize:  135.7 KB
 Viewed:  235 Time(s)
scrimm
PostPosted: Fri Feb 23, 2007 8:45 am    Post subject: run up on the trailer Reply with quote
Roger,
"Fuse strapped down"????
I don't nor have I seen a Europa being strapped down for travel. Guess my
head is in the sand, nothing un-common. Can you or the group provide some
more information on this and maybe some pics? Am I lucky it hasn't jumped
off of it's trailer while I have been dragging it around the countryside?
Steve
N42AH
For Sale
www.stephenscott.com/Europa
Steve Crimm
N42AH
karelvranken(at)hotmail.c
PostPosted: Fri Feb 23, 2007 1:19 pm    Post subject: run up on the trailer Reply with quote
Raimo,
My trailer is not the original Europa trailer, so I can't take any
responsability in your case. But my alu-trailer is similar build as yours. I
did motor run ups with pushes to full power. It looked to me as stable as
ready to fly. Also on the trailer we did engine + prop balancing. That means
that we were bussy for two hours by running at different RPM's. Good luck.
Karel Vranken. # 447 F-PKRL
carl(at)flyers.freeserve.
PostPosted: Fri Feb 23, 2007 3:44 pm    Post subject: run up on the trailer Reply with quote
David,
I see you have hitched the trailer to to your car but on a "gravel
driveway".
Was there any paintwork left on the vehicle afterwards?
raimo.toivio(at)rwm-syste
PostPosted: Sat Feb 24, 2007 2:29 am    Post subject: run up on the trailer Reply with quote
Thanks David,
that looks clear. Europa towed
by Jaguar is a stylish combination!
Did you use some traps through a
spar tunnel to make extra support?
Raimo
PostPosted: Sat Feb 24, 2007 2:40 am    Post subject: run up on the trailer Reply with quote
Raimo, Yes but in retrospect I don't think it was necessary. David
PostPosted: Sat Feb 24, 2007 2:44 am    Post subject: run up on the trailer Reply with quote
Carl, The prop was over grass, the axis of the plane was horizontal so prop
wash not actually hitting gravel - no problem. Still driving the same car 4
yrs later! Regards, David
PostPosted: Fri Mar 02, 2007 11:54 am    Post subject: run up on the trailer Reply with quote
Thanks for all those kind mono-operators
who encouraged me to run up on the trailer.
I can confirm; it was a great pleasure
and felt safe and easy also. What a way
to do it w/o wings. No damages - I will
make it again. Just for happiness.
Raimo
Raimo M W Toivio
37500 Lempaala
Finland
raimo.toivio(at)rwm.fi (raimo.toivio(at)rwm.fi)
www.rwm.fi
 Filesize:  48.47 KB
 Viewed:  237 Time(s)
ptag.dev(at)tiscali.co.uk
PostPosted: Fri Mar 02, 2007 4:12 pm    Post subject: run up on the trailer Reply with quote
Well done Raimo. I see you are able to give your neighbour even more grief along with the C 45 ! (did you get both engines running running AOK?)
Bob H
Do not archive.
Robt.C.Harrison
-----Original Message-----
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Raimo Toivio
Sent: 02 March 2007 20:00
Subject: run up on the trailer
Raimo
Raimo M W Toivio
www.rwm.fi
PostPosted: Sat Mar 03, 2007 10:31 am    Post subject: run up on the trailer Reply with quote
Hi Bob,
unfortunately not yet but The Day is coming.
Too busy with some more important things,
so far.
We have here in Finland one flying DC3 with
2xdouble Prat&Whitney star engines and
its operatorīs responsible engineer promised
me to make my Junior Wasps singing one day.
If you like DC3īs just click
http://www.dc-ry.fi/front.htm
Last summer we all 5 had a rare chance to fly
in it. Our common friend - Beautiful Helena -
was there also.
Letīs meet in http://wings.pudasjarvi.fi/
next summer.
By the way Russians have made boats boosted
by huge star engines for military purposes
