Dual Elevator Cables
Goto page Previous  1, 2, 3  Next
Ed in JXN
PostPosted: Fri Dec 01, 2006 10:17 am    Post subject: Dual Elevator Cables Reply with quote
Not so quick on the flag-wavin', there...
Aircraft returning from Europe (for sale here in the States) have some improvements our Friendly Aviation Advisers didn't deem necessary in the original design, i.e.; high-amp-draw warning lights, low oil-pressure lights, etc.
We do, however, have the best government money can buy!
"A courtroom is the place where justice is dispensed with." - Horace Rumpole, 'Rumpole of the Bailey'
I think John H. and Dennis S. have spoken volumes. I believe Homer's designs are more than adequate, no need for dual cables. FWIW, I had a 3/16 SAS (Stability Augmentation System, sort of an artificial stall-warning) cable on a Merlin IIIB fail. Not catastrophic, but goes to show cables can fail when abused (this one was pinched). Electrical problems in that bird got one's attention tho, as the full-flying stab was only driven electrically.
Ed in JXN
MkII/503
Do not archive.
eagle1(at)commspeed.net
PostPosted: Fri Dec 01, 2006 1:46 pm    Post subject: Dual Elevator Cables Reply with quote
The FAA-NTSB took the plane to Phoenix to be examined. However they said it
is way down the line on the list of planes to be looked at. I am afraid that
it will be months before we get any word on the cause.
George Thompson
Do Not archive
Steve Boetto
PostPosted: Fri Dec 01, 2006 7:11 pm    Post subject: Dual Elevator Cables Reply with quote
In a message dated 12/1/2006 11:14:42 A.M. Eastern Standard Time, pj.ladd(at)btinternet.com writes:
does that mean that anyone can build a plane (within the ultralight limits) and just fly it?
"Land of the Free, Home of the Brave"
Hope it stays that way.
Steve
FF007
PostPosted: Sat Dec 02, 2006 4:11 am    Post subject: Dual Elevator Cables Reply with quote
"Land of the Free, Home of the Brave" Hope it stays that way.>>
Hi Steve,
Good luck to you. Perhaps you have more open space to fall into without hurting someone than we have..
We had that freedom in the early days when people began to add little engines to hang gliders. Then several bad accidents occurred and it was either get organised or get banned completely.
Cheers
Pat
PostPosted: Sat Dec 02, 2006 4:17 am    Post subject: Dual Elevator Cables Reply with quote
Hi Steve,
Just an afterthought. perhaps that is why everyone seems so exercised about fitting dual cables. If I had a design that had never been subjected to a proper engineering analysis I would have dual cables everywhere.
I dont mind sticking my neck out, I built and used an aqualung from a Practical Mechanics article the thought of which scares me to death now, but a flying machine?.......
Cheers
Pat
PostPosted: Sat Dec 02, 2006 4:31 am    Post subject: Dual Elevator Cables Reply with quote
However they said it is way down the line on the list of planes to be
looked at. I am afraid that it will be months before we get any word on the
cause.>>
Hi George,
that is what I would have expected. Bit scary that they have such a backlog
of wrecks to examine though. Planes must be falling out of the sky like
autumn leaves.
Cheers
Pat
flykolb(at)pa.net
PostPosted: Sat Dec 02, 2006 4:32 am    Post subject: Dual Elevator Cables Reply with quote
John,
The trim tab worked well, if installed correctly. A couple builders as I
recall switched the spring and the cable attachments and this could result
in flutter of the trim tab, not having enough tension on the spring could
also create problems. There were some other misc considerations too,
appearance and ease of elevator folding, I think. So as I recall the change
was made to the simpler system on the MK3 for these reasons.
Dennis
PostPosted: Sat Dec 02, 2006 4:37 am    Post subject: Dual Elevator Cables Reply with quote
How many innocent bystanders/uninvolved third parties have been taken out by a legal ultralight? Some? A few? None?
Hi Richard,
Passengers?
Pat
PostPosted: Sat Dec 02, 2006 4:45 am    Post subject: Dual Elevator Cables Reply with quote
The EAA did an excellent job of lobbying the CAA/FAA to allow builders to be creative, >>
Hi Dave,
There are murmurings hers about a move towards something like an `Experimental` category and that would be good. Present regs are too tight. We couldnt change a prop. without approval for instance, but I wouldn`t be very happy about a`build what you like provided the C of G is in the right place. That wont stop your flying wires from giving way, or your engine stopping on climb out because there is insufficient fuel flow.
Cheers
Pat
Richard Pike
PostPosted: Sat Dec 02, 2006 5:56 am    Post subject: Dual Elevator Cables Reply with quote
Legal ultralights do not carry passengers.
Richard Pike
MKIII N420P (420ldPoops)
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
PostPosted: Sat Dec 02, 2006 6:36 am    Post subject: Dual Elevator Cables Reply with quote
Cheers
Pat
Patrick:
Did over regulation, on your side of the pond, prevent further "bad
accidents"?
hauck's holler, alabama
jindoguy(at)gmail.com
PostPosted: Sat Dec 02, 2006 6:46 am    Post subject: Dual Elevator Cables Reply with quote
Pat, Well I know of one innocent bystander who was killed by a part 103 hang glider. It happened at Dog Mtn. in Washington state in the late 80's. She was watching a high wind launch when one wingman didn't let go of the wire, the glider did a ground loop and knocked her head first into a rock.
Right now the FAA is seeking the maximum penalty, 10 years in prison and a $10,000 fine, against an ultralight pilot in Nebraska who crashed his Quicksilver into a storage building along side a football field while carrying a passenger, after dark, doing low level aerobatics, while a football game was in progress. It seems like it wouldn't be possible to pack so much stupid into a single crash, but this fool managed it. Gotta be a world record (Kudos to "Our Man Flint").
Rick
On 12/2/06, Richard Pike <richard(at)bcchapel.org (richard(at)bcchapel.org)> wrote:[quote] Legal ultralights do not carry passengers.
Richard Pike
d-m-hague(at)comcast.net
PostPosted: Sat Dec 02, 2006 7:36 am    Post subject: Dual Elevator Cables Reply with quote
football game was in progress...
Typically the FAA doesn't investigate ultralight crashes at all, fatal or
not... once they determine it was a legal ultralight, they leave it up to
local law enforcement to conduct any investigation.
In the Nebraska crash, if it's the one I recall, although it looked like a
2 seater in the TV news film, I didn't think he was carrying a
passenger. Either way, as soon as there are two seats, or it's otherwise
blatantly "fat", unless the pilot can make a convincing case that it was
being legally operated under a training exemption, they throw the book at
him, considering it not an ultralight but an unregistered, uninspected
aircraft, probably unlicensed pilot, no BFR, low flying (unlike part 103,
the 500' rule applies if they determine it's an "aircraft" and not a
"vehicle", even if unregistered), low aerobatics, careless and reckless
operation, etc. I don't envy that pilot... but he's an idiot, deserves
whatever he's got coming.
-Dana
The family that shoots together..... shouldn't be messed with!
PostPosted: Sat Dec 02, 2006 7:37 am    Post subject: Dual Elevator Cables Reply with quote
prison and a
his
while
a
| Rick
Rick G:
Is this the accident you are referring to?
http://urlsnip.com/882618
Ed in JXN
PostPosted: Sat Dec 02, 2006 1:11 pm    Post subject: Dual Elevator Cables Reply with quote
a58r(at)verizon.net
PostPosted: Sat Dec 02, 2006 2:35 pm    Post subject: Dual Elevator Cables Reply with quote
I used a pair of 1/16 in. cables to "elevate" my FireFly for CG measurement, although a single would have been OK. Total drop 2"This thread has become a cable, or vv? regards,
Bob N.    FireFly 070 Old Kolb
biglar
PostPosted: Sat Dec 02, 2006 3:36 pm    Post subject: Dual Elevator Cables Reply with quote
Ed, the "need" is questionable, obviously, and that has been well addressed here. Addressing my insecurity is also questionable, but sure makes me feel better. There are obviously many on the List who disagree with me, and also some who do agree. It's well established that the Kolb's are well engineered planes, which is one of several reasons I bought my kit in the 1st place.
When taking my flying lessons for my private pilot's license in Port Angeles, WA, back in '95, my instructor, Roger Andersen, required me to learn to fly the plane (Cessna 172) with trim only, since, as I recall he said, "if something happens to the up elevator system, you're in bad trouble, and this gives you a way to fly the plane." A couple of BFR's later, my check instructor had me fly the plane (again, a 172) onto short final with only the elevator trim, before ending the exercise. It worked well - the landing would have been a good one - and I was suitably impressed. I believe it was around that time that I was assembling my Mk III and got to looking at the elevator cable & attachment to the elevator tang. "Hmmm," I thought, "what if that thing decided to pop, for whatever reason ??" The chances are vanishingly small, but the picture in my mind of watching the ground come up while I could do nothing didn't please me much, when an alternative is so simple. In my youth I rode motorcycles for several years and several times saw the brake and clutch cables break. So. I ran a completely separate cable to the elevator tang, and connected it to the trim mechanism. I feel much more secure. If someone doesn't agree with me, fine. Don't use it. But......I WILL use it. Don't bash me for watching out for my precious ass.     Lar.
Larry Bourne
Santa Fe, NM
www.gogittum.com
Larry Bourne
Palm Springs, CA
Building Kolb Mk IIIC
"Vamoose"
PostPosted: Sat Dec 02, 2006 5:29 pm    Post subject: Dual Elevator Cables Reply with quote
Way to go Larry, I'm with you. We can never be too safe in our hobby. I don't think you are overly safety conscious.
We went to Dave's memorial today. It was one of the hardest things that I have ever done. But I got thu the eulogize without breaking down and it was an absolutely beautiful program.
George Thompson
biglar
PostPosted: Sat Dec 02, 2006 5:59 pm    Post subject: Dual Elevator Cables Reply with quote
Thanks, George, and good on you. I'd have been snuffling like a baby.   Lar.   Do not Archive.
Larry Bourne
Santa Fe, NM
www.gogittum.com
Larry Bourne
Palm Springs, CA
"Vamoose"
PostPosted: Sun Dec 03, 2006 12:13 pm    Post subject: Dual Elevator Cables Reply with quote
Hi Lar,
I had a mate, now dead, unfortunately, who was a gunner in a Halifax. He told me that his skipper always rounded out on the trim. Not quuite pattern and approach I agree but pretty neat.
Thanks for the pics. we may use your hotel if we make it to MV next year
Cheers
Pat
Page 2 of 3
