Electric Rudder Trim ala Vic Syracuse
kearney(at)shaw.ca
PostPosted: Fri Nov 10, 2006 2:14 pm    Post subject: Electric Rudder Trim ala Vic Syracuse Reply with quote
Hi
I have decided to add electric rudder trim before I complete the rudder. The theory being that it will be infinitely easier to do this before the rudder is completed. That being said, I want to shamelessly copy Vic’s design as documented on Tim Olson’s website (see http://myrv10.com/tips/mods/RudderTrim/index.html).
The pictures are quire revealing (pun intended)! I see that the access panel is has a Ray Allen T2-7A servo and that the access panel sits on a flange that was riveted to the rudder skin. What I don’t have are the dimensions of the access panel as well as its location on the rudder. I can guess but would prefer something a bit more accurate if available. Failing that, is the T2-7a servo dimensionally the same size as the T3-12A servo that came with the tail kit? If so, I can estimate the access panel size.
Inquiring minds need to know ...
Les Kearney
RV10 # 40643 - Vertical Stab
Tim(at)MyRV10.com
PostPosted: Fri Nov 10, 2006 2:42 pm    Post subject: Electric Rudder Trim ala Vic Syracuse Reply with quote
Ed Hayden just completed a nearly identical modification on his
rudder using Vic's design concept. He used the following
standard parts:
VA-195C
VA-195D
These I believe are the standard cover plate and doubler that
go in place of the stall warning hole. I don't think it would
really matter what dimensions you use as long as your servo
fits. I don't know for sure if there's a difference in
footprint between servos, but I doubt it....someone else would
have to fill you in on that. If you are doing the mod though,
I'd buy the servo and have it handy for doing the mod.
Les Kearney wrote:
Hi
access panel size.
Les Kearney
kearney(at)shaw.ca
PostPosted: Fri Nov 10, 2006 3:01 pm    Post subject: Electric Rudder Trim ala Vic Syracuse Reply with quote
Hi Tim
Many thanks for the info. I will order the parts directly. Would you happen
to know where Vic got the cover for the servo arm I can't tell if it was
riveted on or if it was plastic (glued?).
Cheers
Les
Tim(at)MyRV10.com
PostPosted: Fri Nov 10, 2006 4:07 pm    Post subject: Electric Rudder Trim ala Vic Syracuse Reply with quote
That part I don't know. It looks like a regular rudder cable
exit fairing that you can get from Aircraft spruce or Avery Tools.
I'm sure you could proseal it on if you wanted, or rivet it, either
way. I've had good luck internally using E6000, but I don't know
if I'd use that outside....probably proseal.
Les Kearney wrote:
Hi Tim
Cheers
Les
capsteve
PostPosted: Fri Nov 10, 2006 10:53 pm    Post subject: Electric Rudder Trim ala Vic Syracuse Reply with quote
Just how necessary is this mod?? Has anyone flying their 10 had to put a wedge on the rudder to correct for an out of trim condition? I think it’s a great idea just need to make sure its needed.
Thinking about rudders…. I’m seriously considering mounting the nav/gs antenna in the rudder. I can’t find a certified example with an external antenna in a control surface, I’m not sure if that’s on purpose. I’m thinking that the rudder is fairly stationary in cruise and approach. So there shouldn’t be a problem…..
Steve
40205
Subject: Electric Rudder Trim ala Vic Syracuse
Hi
Les Kearney
No virus found in this outgoing message.
11/10/2006
mritter509(at)msn.com
PostPosted: Sat Nov 11, 2006 4:57 am    Post subject: Electric Rudder Trim ala Vic Syracuse Reply with quote
I have to use a little right rudder to keep the ball centered. Without
right rudder its about a half ball out to the right. Rudder trim is on my
list of things to do.
Mark (N410MR Flying)
Subject: RE: Electric Rudder Trim ala Vic Syracuse
Date: Sat, 11 Nov 2006 01:52:43 -0500
Steve
40205
Hi
The
documented on Tim Olson’s website (see HYPERLINK
"http://myrv10.com/tips/mods/RudderTrim/index.html"http://myrv10.com/tips/mo
panel
Les Kearney
11/10/2006
11/10/2006
Add a Yahoo! contact to Windows Live Messenger for a chance to win a free
trip!
Tim(at)MyRV10.com
PostPosted: Sat Nov 11, 2006 5:19 am    Post subject: Electric Rudder Trim ala Vic Syracuse Reply with quote
I don't know of any RV-10's flying that don't either have a rudder
tab wedge in place, or electric rudder trim. (I'm sure there's one
somewhere though, but none that I know of....but they would probably
not be flying perfectly straight) I myself have a wedge taped on.
It looks fine, and works ok in cruise at lower power settings.
The problem is, even adding 5-10kts is significant enough to make
the wedge too much trim, and flying at lower speeds makes it too
little.
I didn't have any believe in rudder trim when I started. My
previous plane didn't have it, and I didn't care. But as both my
aircraft quality, and flying quality has improved with the RV-10,
I now see it as a much more necessary item if you're going for a
truly nice flying airplane. I wish I would have done it earlier,
because it's harder to do after you've painted.
As far as your antenna in the rudder, I would most certainly
avoid that, from a balance standpoint, a wiring standpoint, and
more. Even when doing the rudder trim, the builders who've
checked with Van's had them recommend that the servo be mounted
forward enough to balance the trim control on the aft side. I
really think putting an antenna there is a bad idea...especially
given the abundance of GOOD locations for the antenna.
Steve
40205
*Subject:* Electric Rudder Trim ala Vic Syracuse
access panel size.
Les Kearney
jesse(at)itecusa.org
PostPosted: Sat Nov 11, 2006 8:03 am    Post subject: Electric Rudder Trim ala Vic Syracuse Reply with quote
I would have to agree with Tim that putting antennas in the rudder might be a mistake. Not only with balance issues but also because of the wire wearing as the rudder moves. While it may remain fairly stationary in flight, it certainly moves a LOT while on the ground taxiing. I don’t even like having the wires to the tail lights back there, but that is hard to avoid.
As far as the need to rudder trim, all three -10’s I have spent time in have electric trim and are regularly “stepping on the ball”, depending on how they are flying and how they are loaded. I also don’t think I have seen one without at least the wedge. I don’t know how much speed is lost when out of trim, but I imagine it is measureable enough to justify. If putting on just a wedge, I would recommend putting it on to trim for cruise, whether you like economy or speed. You definitely need some rudder in climb. With the options available (Aerotrim runs as little as $175 without the indicator), I think it is definitely a good mod to include.
I have mentioned Aerotrim a number of times, so I will give a little more detail (I have no financial connection whatsoever). This guy is usually at the big shows with a little half-booth (and very not-impressive) and an airplane-through-the-head hat on. He is often sleeping, or at least playing with his dentures. He does, on the other hand, have a trim system that is STC’ed or PMA’ed for quite a few different certified airplanes. The servo supposedly has all metal gears, although I have not disassembled one to find out. The housing that the servo is in is not very professional, and the wires coming out of the servo or included with the system are very small (so are the Ray Allen’s), but it works very well. There are two wires, so no real option for an indicator unless you use his, which I think comes centered just like the servo, and when you give power to run the servo, you are also sending the same power to the indicator that moves it. I haven’t even considered using the indicator on the 10 trims that I have bought from him. The servo runs very slowly, which is fairly good for aileron or rudder trim, since those mostly need very minor adjustments during flight. The servo comes with a hinge that you rivet onto the trailing edge. It has a spring that keeps it from fluttering/shaking/vibrating. It comes from the factory/garage mechanically centered, so you want to attach the hinge to the arm coming out of the servo with it centered before you run the servo. It also comes with pop rivets to attach the servo to the skin of the aileron or rudder (it is VERY lightweight) after you cut the hole for it. On 4 of our installations we decided to use nutplates on the skin and #6 countersunk screws, which seems to be a good fit. The first 2 installations we made were done after the plane was flying and without removing either the aileron or rudder, so painting it ahead of time should make it a very easy installation for most people. For those considering it, I would recommend getting it without the toggle switch and without the bundle of wire that comes with it and without the indicator (you can easily see the state of the aileron trim in flight, and the ball is the indicator on the panel for the rudder trim).
Well, that’s it for now.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Steven DiNieri
Sent: Saturday, November 11, 2006 1:53 AM
Steve
40205
Hi
Les Kearney
11/10/2006
-- Date: 11/10/2006
11/10/2006
capsteve
PostPosted: Sun Nov 12, 2006 9:02 am    Post subject: Electric Rudder Trim ala Vic Syracuse Reply with quote
Thanks for all the input. It seems fairly unanimous that some form
of rudder trim is preferred. Technically there's going to be two ways to
make it happen. Bias spring/servo type on the pedals under dash somewhere or
servo/tab in the rudder. I'll probably spend most of today scratching my
head trying to find an elegant (read: simple) way to keep it under dash.
Choice 2 would be to cut a tab into the trailing edge of the rudder. I'm not
quite happy about hanging a hinge off the trailing edge. A couple of
thoughts on the servo.....i do have an extra mac servo, but I might compare
the torque to a large scale servo from the rc world. The servo would be
lighter and the pwm operation would allow slide type control. A indicator
wouldn't be necessary as the slide would reflect tab position - left on the
slide is left trim, center slide is neutral trim.........
I'll report on how badly I've mangled the rudder later......Smile
Steve
40205
little.
> Steve
> 40205
> access panel size.
> Les Kearney
capsteve
PostPosted: Sun Nov 12, 2006 9:31 am    Post subject: Electric Rudder Trim ala Vic Syracuse Reply with quote
Well, deep down I knew it was a bad idea. Thinking about it, if the
antenna elements vibrated during flight (and I'm sure they do) they could
contribute to flutter. So, I've decided to install the nav/gs antenna in the
vertical stabilizer around the top hinge. I've yet to install the upper
hinge doubler in the service bulletin, so when I'm in there I’ll add a
bracket. None of the other placements make as much sense to me. I think
keeping it as far from the fuse as possible can't hurt, plus I have a few
rugrats running around the hangar and keeping the eye poking devices to a
minimum is important........
Steve
40205
avoid
Jesse Saint
I-TEC, Inc.
> Steve
> 40205
> access panel size.
> Les Kearney
pitts_pilot(at)bellsouth.
PostPosted: Sun Nov 12, 2006 12:31 pm    Post subject: Electric Rudder Trim ala Vic Syracuse Reply with quote
Actually, there are a couple of things you can do without trim servo's
or tabs. I don't know if Van's design has rudder return springs, but if
not ..... I'll add them when the time comes. A tension spring from the
rudder pedal (at the cable attach point) to the firewall is all you
need. With the springs in place, go fly. If the aircraft changes
heading with the wings level, then you have one of two conditions: 1)
the spoiler is deployed on one side only. 2) the vertical fin/rudder
aren't in rig. Since I haven't seen a spoiler, we can forget #1.
Depending on which way the aircraft turns, you can twist/untwist the
rudder cables which will effectively shorten or lengthen the cables.
Loosen on the side inside the turn, and tighten on the outside of the
turn. It'll take some time, but unless the vertical fin is way out, you
can compensate. One way you can tell if the fin is the culprit (engine
thrust line could also be the culprit) is that the rate of turn will be
more pronounced at higher speeds.
Combinations of engine thrust and cable experimentation may be necessary.
Linn
Steve
40205
coop85(at)bellsouth.net
PostPosted: Sun Nov 12, 2006 2:38 pm    Post subject: Electric Rudder Trim ala Vic Syracuse Reply with quote
Linn,
These seem like good ideas for many airplanes, but there are a few snags
relating to the RV-10.
First, the rudder cables are not adjustable, there are no turnbuckles like
you find in many other airplanes.
I don't think there would be enough room to put tension springs and a
turnbuckle on the firewall side. Several folks have added tension springs,
but it's only to keep tension on the rudder pedals so they don't flop
backward, I haven't bothered as it hasn't been an issue.
Adjusting the thrust line or stab alignment would REALLY complicate the
cowling or fairing installation and there are no design features to allow
the adjustment. Anything's possible, but in the case of the -10 this would
be a lot of work for little gain. I honestly was surprised there isn't any
offset in the vertical stab like other airplanes I've built to reduce the
trim requirement.
Based on the above, the most simple route is electric rudder trim. I don't
have it yet, I just taped a plate on the rudder and kept bending it until I
didn't have to hold rudder pressure in cruise. Honestly, it takes very
little rudder input in other phases of flight and I'm waffling on how bad I
want to install the electric trim - would be kind of cool to have though.
Just my .02 FWIW,
Marcus
Linn
or
not
Steve
40205
jwt(at)roadmapscoaching.c
PostPosted: Sun Nov 12, 2006 6:24 pm    Post subject: Electric Rudder Trim ala Vic Syracuse Reply with quote
Steve
Have you considered putting Nav antennas in the wingtips? Makes for a real
clean install and I have heard mostly good reports about reception.
John Testement
jwt(at)roadmapscoaching.com
40321
Richmond, VA
Finish kit - wheel fairings, cowl prep
capsteve
PostPosted: Mon Nov 13, 2006 12:45 am    Post subject: Electric Rudder Trim ala Vic Syracuse Reply with quote
John, I'll probably add one for a 2nd nav reciever, but for ifr ops I'm
going to be most comfortable with a system that most resembles certified
spam can systems. Not so much that they're better, but reliable at best.
Steve
40205
<jwt(at)roadmapscoaching.com>
Steve
John Testement
40321
Richmond, VA
apilot2(at)gmail.com
PostPosted: Mon Nov 13, 2006 4:32 am    Post subject: Electric Rudder Trim ala Vic Syracuse Reply with quote
You might consider that many certified systems run 2 navs and 1 or 2
GS all off one nav antenna, and some are in fact built with nav
antennas in the wingtips. I know of at least one STC to remove tail
mounted nav antenna and replace it with one built into a fiberglass
wingtip. So if you are going to put an antenna in the wing tip, unless
you want to do the electronic comparison, there isn't a lot of reason
to have to nav antennas.
Steve
40205
> Steve
> John Testement
> 40321
> Richmond, VA
> Do not archive
