rparigoris
Posted: Fri May 14, 2010 9:23 pm Post subject: D-sub connectors, what is disadvantage of solder over crimp? |
What is the disadvantage of using a 36 or 50 pin solder pot d-sub connectors (while having an extra set of hands to insert wires) where you heat shrink over solder pot and wire compared to using much more expensive machined pin connectors that are crimped?
Ron Parigoris
Joined: 28 Mar 2008 Posts: 1940 Location: Riley TWP Michigan
Posted: Sat May 15, 2010 3:43 am Post subject: Re: D-sub connectors, what is disadvantage of solder over cr |
I believe the advantage of machined pins is a better electrical connection between the male and female pins. Whether to solder or to crimp is another issue.
Joe
_________________ Joe Gores |
