D-sub connectors, what is disadvantage of solder over crimp?
rparigoris
PostPosted: Fri May 14, 2010 9:23 pm    Post subject: D-sub connectors, what is disadvantage of solder over crimp? Reply with quote
What is the disadvantage of using a 36 or 50 pin solder pot d-sub connectors (while having an extra set of hands to insert wires) where you heat shrink over solder pot and wire compared to using much more expensive machined pin connectors that are crimped?
Ron Parigoris
PostPosted: Sat May 15, 2010 3:43 am    Post subject: Re: D-sub connectors, what is disadvantage of solder over cr Reply with quote
I believe the advantage of machined pins is a better electrical connection between the male and female pins. Whether to solder or to crimp is another issue.
Joe
Joe Gores
