andrewbutler(at)ireland.c Guest
Posted: Tue Aug 11, 2009 4:22 am Post subject: Voltage drop puzzle |
Hello All,
I have more or less finished my wiring. I have impelemented Z13/8 on my project. I have a switch to engage the relay that isolates the feed from the SD-8 during normal operations. I have installed a bulb in this circuit to tell me that the relay is engaged.
While I have 12V plus on my main bus, I am getting a much lower voltage (the order of 4 volts) through the bulb (I was alerted to this by the bulb being very dim). Why is this? Sure enough I should have a drop through 1N5400 diode that is in the circuit, but surely not that much? Does the relay itself contribute to the drop aswell? Attached is the diagram with a circle around the bulb in question. The circuit is installed as shown.
Is this even a problem? The relay engages to the NO position as required when I flip the switch (number 12) and stays there.
Best regards,
Andrew Butler,
RV7 EI-EEO
Firewall Forward
Galway Ireland.
Description: |
 Download |
Filename: |
Voltage_Drop_Query.pdf |
Filesize: |
759.03 KB |
Downloaded: |
996 Time(s) |
mprather(at)spro.net Guest
Posted: Tue Aug 11, 2009 6:14 am Post subject: Voltage drop puzzle |
Best regards,
Andrew Butler,
RV7 EI-EEO
Firewall Forward
Galway Ireland.
As drawn, you have the bulb in series with the coil - a voltage divider.
This probably isn't a very good thing as the series resistance of the bulb
is reducing the current through the coil which will reduce the turn-on
margin on the relay. If the bus voltage drops, you might not be able to
get the relay to close. Once closed, it will probably stay there until
the controlling switch is opened - which is fine.
It seems like it's not a good idea to insert anything in the circuit to
the coil. If you wanted to monitor the position of the switch you could
select a double pole (DPST) switch to control the relay and wire the lamp
through the extra pole.
Matt-
Posted: Tue Aug 11, 2009 6:21 am Post subject: Voltage drop puzzle |
Having just stared at it a while, I realise that I need to take the unreliable bulb out of the circuit. Any suggestions on how I could wire one in to tell me whether or not the circuit is live?
Andrew.
jay(at)horriblehyde.com Guest
Posted: Tue Aug 11, 2009 6:46 am Post subject: Voltage drop puzzle |
Hi there,
I think that the voltage drop through the relay is the problem. Maybe
change the aux power switch to a 2 pole one (a 2-3) and then wire the second
pole with a 'clean' 12V from the 'upstream' side of the relay - say from the
same terminal as where the yellow wire of the OV crowbar goes to; then
through the switch and via the light to ground.
Jay
Posted: Tue Aug 11, 2009 6:47 am Post subject: Voltage drop puzzle |
Thanks Matt. My own bulb went off in my head while thinking on it a bit more and figured just that about the DPST switch.
Andrew.
flyboybob1(at)gmail.com Guest
Posted: Tue Aug 11, 2009 6:48 am Post subject: Voltage drop puzzle |
Matt wrote: << If you wanted to monitor the position of the switch you
could
through the extra pole. >>
It would be a weak design goal to know the position of the switch. A better
goal would be to know the position of the relay. A still better goal would
be to know the function the relay controled was working. Lectric Bob has
presented an inexpensive and elegant solution to the best design goal here.
In a recent thread with the subject: Pitot heaters . . . warn or not, that
IS the question, bob posted his solution on the web at:
http://www.aeroelectric.com/articles/Failure_Detection_and_Annunciation.pdf
Hope this helps.
Bob Lee
N52BL KR2
Suwanee, GA USA
92% done only 67% to go!
Posted: Tue Aug 11, 2009 7:49 am Post subject: Voltage drop puzzle |
Thanks Jay,
What about if using the 2-3 switch I connected the light to the live terminal on the capacitor? That would allow me to test the relay in pre-flight by engaging the switch (and checking for illumination) while also allowing me to monitor that I have flipped the switch during flight........
Andrew.
I'm surprised that the relay still pulls in but
that's a function of bulb size. As others have noted
you have the bulb wired incorrectly for the purpose
of showing that the relay is "closed". Wired as shown,
it only says that the relay coil has some current flowing
through it . . . but does not speak to actual connection
(or functionality) of the alternator.
Further, for you lamp to function as a "relay energized"
notification, the bulb needs to be in PARALLEL with the
relay coil, not series.
May I suggest that your active notification of low voltage
is a much better way to report condition of the WHOLE alternator
system? The fact that you KNOW the relay is energized
is not very informative. There are lots of things that
could cause alternator output to be inadequate or
completely missing. The fact that bus voltage is too
low to avoid discharging the battery (13.0) is the
DEFINITIVE indicator of alternator performance.
( -Thomas Paine 1776- )
Posted: Tue Aug 11, 2009 8:49 am Post subject: Voltage drop puzzle |
Hey there Andrew,
That would work fine- remember though that all you really are indicating is
that the pole on the switch is working Hopefully the other pole is
working as well...
The LV monitoring that Bob describes is also a good idea- normally this is
part of the Z13/8 circuit and perhaps you plan to include it in any case.
On the Sling I used the MGL EFIS to monitor the voltage; you can set an
alarm that can also give you a digital output to switch something. If you
are using an EFIS perhaps it has similar features? If not I would use the
LV warning cct and light.
Another idea is to reverse the wiring for the S704-1 relay and use the
normally closed contact to illuminate a light when the relay is de-energised
(see the attached diagram); to my mind this also tells you that the dynamo
is producing a voltage when it's not in use.
Jay
Description: |
 Download |
Filename: |
Visio-Z-13_8_Dynamo_alternative_cct.pdf |
Filesize: |
17.82 KB |
Downloaded: |
496 Time(s) |
Joined: 28 Mar 2008 Posts: 1942 Location: Riley TWP Michigan
Posted: Thu Aug 13, 2009 5:52 am Post subject: Re: Voltage drop puzzle |
What is the purpose of the diode connected to the over voltage relay coil? It appears that the intent is to raise the trip voltage by 0.7 volts, for instance from 16 to 16.7 volts. If the purpose of the diode is for arc suppression, then the diode should be connected in parallel with the coil, not in series.
Also, the 1A fuse inside of the red circle will blow before the 2A circuit breaker will trip. The Fuse should be removed from the circuit.
After shutdown, leaving the Aux Power switch on will drain the battery.
Joe
_________________ Joe Gores |
