Windsceen Lexan
Goto page Previous  1, 2
patreilly43(at)hotmail.co
PostPosted: Wed Aug 27, 2008 2:16 pm    Post subject: Windsceen Lexan Reply with quote
Bob C Yes C I used the heat gun to bend or form plexi as well as drilling. I built a 2 piece windshield / cabin top. The cabin top is smoked and the windshield clear. They overlap at the crossmember at the top of the windshield and are riveted together. I did form the cabintop down with heat to lap under the windshield. I believe it is recommended to heat the 1 piece windshield after it is bent to relieve the stress at the major bends. Anyway get a heat gun some plexi and practice.
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
Subject: RE: Re: Windsceen Lexan
Date: Tue C 26 Aug 2008 20:03:59 -0400
.ExternalClass .EC_hmmessage P {padding-right:0px;padding-left:0px;padding-bottom:0px;padding-top:0px;} .ExternalClass BODY.EC_hmmessage {font-size:10pt;font-family:Tahoma;} Pat - how about for bending? I would think that would be more important that it be warm (more flexible?) when bent(?)
I know I'm more flexible when I'm bent... Wink
Bob Brennan - N717GB
1991 UK Model 2 ELSA Kitfox
Rotax 582 with 3 blade prop
Wrightsville Pa
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of patrick reilly
Sent: 26 August 2008 7:56 pm
Bob C I think I heated to 120 degrees before drilling. I can't really remember. I used a heat gun C as I said C and a laser thermometer and practiced on a scrap piece first.
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
Date: Mon C 25 Aug 2008 19:34:06 -0400
.ExternalClass .EC_hmmessage P {padding-right:0px;padding-left:0px;padding-bottom:0px;padding-top:0px;} .ExternalClass BODY.EC_hmmessage {font-size:10pt;font-family:Tahoma;} Pat C
I was thinking that the previous owner hadn't heated the current windscreen properly C or probably not at all C which is why I am getting stress cracks. In general the recommendation for lexan C that I have seen C is to not try to work with it at all under 70F. I am thinking the warmer the day the better for working with lexan. And warm days in the UK.... well let's just say it's a rarity!
Wrightsville Pa
Sent: 25 August 2008 6:40 pm
Dave C You want a dull bit that won't grab. ACS sells a special  plexi bit C but I didn't use one. You can heat the material with a heat gun also then it is not brittle. I don't remember how hot I got it. I used a laser thermometer to test to get right temp in practice and then heated to that temp before drilling. Worked good for me.
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
[quote] From: matronics(at)bob.brennan.name
Date: Mon C 25 Aug 2008 18:25:07 -0400
--> Kitfox-List message posted by: "Bob Brennan" <matronics(at)bob.brennan.name>
Thanks Dave C
So that sounds like a recommendation for .080 or .093? I don't have a
micrometer but the current windscreen starts to pulsate at a little over 75 C
so it must be .060(?)
There are some fairly sharp curves on my KF2 C which is where the cracks
occurred. I am planning to use the old pieces as templates and cut the new
with a Dremel with a cut-off wheel. With that I should be able to also
smooth the edges. I imagine that using the right kind of drill bit to drill
the rivet holes is important too C don't want any cracks there. A
metal-drilling bit?
Wrightsville Pa
PostPosted: Wed Aug 27, 2008 4:14 pm    Post subject: Windsceen Lexan Reply with quote
Pat - I like the idea of smoked lexan (BTW you did mean "lexan" didn't you? not "plexi"?) on the top. My first flight out and I forgot to where my cap - serious sunburn on my forehead and "thinning regions". Where did you get smoked lexan?
Wrightsville Pa
Sent: 27 August 2008 6:16 pm
Bob, Yes, I used the heat gun to bend or form plexi as well as drilling. I built a 2 piece windshield / cabin top. The cabin top is smoked and the windshield clear. They overlap at the crossmember at the top of the windshield and are riveted together. I did form the cabintop down with heat to lap under the windshield. I believe it is recommended to heat the 1 piece windshield after it is bent to relieve the stress at the major bends. Anyway get a heat gun some plexi and practice.
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
Date: Tue, 26 Aug 2008 20:03:59 -0400
.ExternalClass .EC_hmmessage P { PADDING-RIGHT: 0px; PADDING-LEFT: 0px; PADDING-BOTTOM: 0px; PADDING-TOP: 0px } .ExternalClass BODY.EC_hmmessage { FONT-SIZE: 10pt; FONT-FAMILY: Tahoma } Pat - how about for bending? I would think that would be more important that it be warm (more flexible?) when bent(?)
Wrightsville Pa
Bob, I think I heated to 120 degrees before drilling. I can't really remember. I used a heat gun, as I said, and a laser thermometer and practiced on a scrap piece first.
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
Date: Mon, 25 Aug 2008 19:34:06 -0400
.ExternalClass .EC_hmmessage P { PADDING-RIGHT: 0px; PADDING-LEFT: 0px; PADDING-BOTTOM: 0px; PADDING-TOP: 0px } .ExternalClass BODY.EC_hmmessage { FONT-SIZE: 10pt; FONT-FAMILY: Tahoma } Pat,
I was thinking that the previous owner hadn't heated the current windscreen properly, or probably not at all, which is why I am getting stress cracks. In general the recommendation for lexan, that I have seen, is to not try to work with it at all under 70F. I am thinking the warmer the day the better for working with lexan. And warm days in the UK.... well let's just say it's a rarity!
Wrightsville Pa
Dave, You want a dull bit that won't grab. ACS sells a special plexi bit, but I didn't use one. You can heat the material with a heat gun also then it is not brittle. I don't remember how hot I got it. I used a laser thermometer to test to get right temp in practice and then heated to that temp before drilling. Worked good for me.
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
Date: Mon, 25 Aug 2008 18:25:07 -0400
Thanks Dave,
micrometer but the current windscreen starts to pulsate at a little over 75,
There are some fairly sharp curves on my KF2, which is where the cracks
the rivet holes is important too, don't want any cracks there. A
metal-drilling bit?
Wrightsville Pa
PostPosted: Wed Aug 27, 2008 7:41 pm    Post subject: Windsceen Lexan Reply with quote
Bob C Yes C I like the idea of a tinted cabintop. I was going to add the tinted film to clear plexi but Menards (a large lumber yard chain ) had a sheet of bronze tinted plexi with a corner broken off that was marked down about 25%. No C I used plexi not Lexan. One of the builders at the airport said he liked plexi better. There are pros and cons for both. I think he said plexi is more petrol resistant and doesn't scratch as easy C and can't be buffed out. I thought Lexan was more scratch resistant. I actually used a very flexable clear new plexi of some sort for the windshield. I don't know how it will prove out. It was called J Peg on something on that order. Someone on the website was asking about it and I thought it sounded good C so thats what I used. You can even cut it with sheetmetal shears without fracturing it. Seems rather soft. We'll see what happens.
Pat Reilly
Mod # 582 Rebuild
Rockford C IL
Date: Wed C 27 Aug 2008 20:13:09 -0400
.ExternalClass .EC_hmmessage P {padding-right:0px;padding-left:0px;padding-bottom:0px;padding-top:0px;} .ExternalClass BODY.EC_hmmessage {font-size:10pt;font-family:Tahoma;} Pat - I like the idea of smoked lexan (BTW you did mean "lexan" didn't you? not "plexi"?) on the top. My first flight out and I forgot to where my cap - serious sunburn on my forehead and "thinning regions". Where did you get smoked lexan?
Wrightsville Pa
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
Wrightsville Pa
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
Wrightsville Pa
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
Thanks Dave C
metal-drilling bit?
Wrightsville Pa
Fox5flyer
PostPosted: Thu Aug 28, 2008 3:43 am    Post subject: Windsceen Lexan Reply with quote
Pat, again I think there is still some confusion between polycarbonate and Plexiglas. Polycarbonate (Lexan, Rhino, Manchester, and many other names) is soft and can be cut with tin snips, drilled with a conventional drill bit, and bent in a sheet metal brake. The downside is that it is very soft and easily scratched. Plexiglass is hard, brittle, difficult to cut, can't be bent very much without a lot of heat, resistant to scratching, yet brittle enough so that it can easily be cracked if stressed. Plexiglass is what is used in certified aircraft and also what LP Aeroplastics supplies. It sounds like the J Peg you are referring to is polycarbonate, not Plexiglas.
Polycarbonate is fine for experimental aircraft use, but it will have to be changed more often than Plexiglas.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 391+ TT
"The aim of an argument or discussion should not be victory, but progress."
- Joseph Joubert
Lynn Matteson
PostPosted: Thu Aug 28, 2008 8:03 am    Post subject: Windsceen Lexan Reply with quote
Deke-
LP Aeroplastics uses *acrylic*.....where does that fit into the grand
scheme of things?
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200, 562 hrs and holding for repairs
Status: "Condition grounded, but determined to try." (Pink
Floyd..."Learning to Fly")
On Aug 28, 2008, at 7:42 AM, fox5flyer wrote:
[quote] Pat, again I think there is still some confusion between
Deke Morisse
Mikado Michigan
progress."
- Joseph Joubert
Lynn
Kitfox IV-Jabiru 2200
N369LM
Fox5flyer
PostPosted: Thu Aug 28, 2008 8:49 am    Post subject: Windsceen Lexan Reply with quote
Acrylic -- Plexiglass, same thing.
Do you have all your parts yet?
Deke
Lynn Matteson
PostPosted: Thu Aug 28, 2008 10:30 am    Post subject: Windsceen Lexan Reply with quote
Not all of 'em...they sent a crank, but without the 6mm dowels in the
gear end or the welch/welsh plugs that are needed. I got the gear
case cover and gear that was supposed to take 2-4 weeks from
Australia yesterday. So I can start to assemble the short block, but
I'm waiting for word on some piston rings...locally, I hope. Too many
pitfalls to list, but part of the problem is it's taking too long to
get answers back from Australia, and when they do answer (through the
dealer, never to me) the answer seems to have been written by a
lawyer...vague, short answers...for example...."heat the head..."
HOW HOT? 400° 1000° 3000°? WHAT? You can tell I'm gettin' pi - - ed!
Lynn Matteson
Kitfox IV Speedster
On Aug 28, 2008, at 12:49 PM, fox5flyer wrote:
<fox5flyer(at)idealwifi.net>
Deke
Lynn
N369LM
larry huntley
PostPosted: Thu Aug 28, 2008 10:50 am    Post subject: Windsceen Lexan Reply with quote
All Plexiglas is acrylic,but not all acrylic is Plexiglas. ;o) Larry
Larry Huntley,Dundee,NY
Kitfox 4-1200 N234EE
EA81,AMAX Redrive Warp 3 blade
Michel
PostPosted: Thu Aug 28, 2008 11:47 am    Post subject: Windsceen Lexan Reply with quote
All Plexiglas is acrylic, but not all acrylic is Plexiglas. ;o) Larry
.. what? Do you mean to say that the acrylic paint I used for these:
http://home.online.no/~michel/paint/
is not Plexiglas? ... Smile
Michel
Kitfox 3 - Jabiru 2200
larry huntley
PostPosted: Thu Aug 28, 2008 12:51 pm    Post subject: Windsceen Lexan Reply with quote
Beautiful display Michel. Thank you for sharing! Larry
PostPosted: Thu Aug 28, 2008 2:04 pm    Post subject: Windsceen Lexan Reply with quote
Deke C Thanks for the clarification. I must have used polycarbonate for the windshield and bronze tinted plexi for the cabintop and turtleback hatch. That was my 1st experience with polycarbonate. I was very surprised how flexible it is. Has anyone else tried a 2 piece windshield and cabintop vs. the 1 piece? I will be mounting it next week. I built it last winter and just finished the paint. Looks pretty good. Could have been better if I could have learned how to look into the light a little sooner. Hardest part of building a plane or car is the paint. It is an art that needs to be excercised more that every 5 to 10 years.
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
Subject: Re: Re: Windsceen Lexan
Date: Thu C 28 Aug 2008 07:42:25 -0400
.ExternalClass .EC_hmmessage P {padding-right:0px;padding-left:0px;padding-bottom:0px;padding-top:0px;} .ExternalClass BODY.EC_hmmessage {font-size:10pt;font-family:Tahoma;} Pat C again I think there is still some confusion between polycarbonate and Plexiglas.  Polycarbonate (Lexan C Rhino C Manchester C and many other names) is soft and can be cut with tin snips C drilled with a conventional drill bit C and bent in a sheet metal brake.  The downside is that it is very soft and easily scratched.  Plexiglass is hard C brittle C difficult to cut C can't be bent very much without a lot of heat C resistant to scratching C yet brittle enough so that it can easily be cracked if stressed.  Plexiglass is what is used in certified aircraft and also what LP Aeroplastics supplies.  It sounds like the J Peg you are referring to is polycarbonate C not Plexiglas.
Polycarbonate is fine for experimental aircraft use C but it will have to be changed more often than Plexiglas.
Deke Morisse
Mikado Michigan
"The aim of an argument or discussion should not be victory C but progress."
- Joseph Joubert
Page 2 of 2
