patreilly43(at)hotmail.co Guest
matronics(at)bob.brennan. Guest
Posted: Wed Aug 27, 2008 4:14 pm Post subject: Windsceen Lexan |
Pat - I like the idea of smoked lexan (BTW you did mean "lexan" didn't you? not "plexi"?) on the top. My first flight out and I forgot to where my cap - serious sunburn on my forehead and "thinning regions". Where did you get smoked lexan?
Bob Brennan - N717GB
1991 UK Model 2 ELSA Kitfox
Rotax 582 with 3 blade prop
Wrightsville Pa
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of patrick reilly
Sent: 27 August 2008 6:16 pm
Subject: RE: Re: Windsceen Lexan
Bob, Yes, I used the heat gun to bend or form plexi as well as drilling. I built a 2 piece windshield / cabin top. The cabin top is smoked and the windshield clear. They overlap at the crossmember at the top of the windshield and are riveted together. I did form the cabintop down with heat to lap under the windshield. I believe it is recommended to heat the 1 piece windshield after it is bent to relieve the stress at the major bends. Anyway get a heat gun some plexi and practice.
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
Date: Tue, 26 Aug 2008 20:03:59 -0400
.ExternalClass .EC_hmmessage P { PADDING-RIGHT: 0px; PADDING-LEFT: 0px; PADDING-BOTTOM: 0px; PADDING-TOP: 0px } .ExternalClass BODY.EC_hmmessage { FONT-SIZE: 10pt; FONT-FAMILY: Tahoma } Pat - how about for bending? I would think that would be more important that it be warm (more flexible?) when bent(?)
I know I'm more flexible when I'm bent...
Wrightsville Pa
Sent: 26 August 2008 7:56 pm
Bob, I think I heated to 120 degrees before drilling. I can't really remember. I used a heat gun, as I said, and a laser thermometer and practiced on a scrap piece first.
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
Date: Mon, 25 Aug 2008 19:34:06 -0400
.ExternalClass .EC_hmmessage P { PADDING-RIGHT: 0px; PADDING-LEFT: 0px; PADDING-BOTTOM: 0px; PADDING-TOP: 0px } .ExternalClass BODY.EC_hmmessage { FONT-SIZE: 10pt; FONT-FAMILY: Tahoma } Pat,
I was thinking that the previous owner hadn't heated the current windscreen properly, or probably not at all, which is why I am getting stress cracks. In general the recommendation for lexan, that I have seen, is to not try to work with it at all under 70F. I am thinking the warmer the day the better for working with lexan. And warm days in the UK.... well let's just say it's a rarity!
Wrightsville Pa
Sent: 25 August 2008 6:40 pm
Dave, You want a dull bit that won't grab. ACS sells a special plexi bit, but I didn't use one. You can heat the material with a heat gun also then it is not brittle. I don't remember how hot I got it. I used a laser thermometer to test to get right temp in practice and then heated to that temp before drilling. Worked good for me.
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
[quote] From: matronics(at)bob.brennan.name
Date: Mon, 25 Aug 2008 18:25:07 -0400
--> Kitfox-List message posted by: "Bob Brennan" <matronics(at)bob.brennan.name>
Thanks Dave,
So that sounds like a recommendation for .080 or .093? I don't have a
micrometer but the current windscreen starts to pulsate at a little over 75,
so it must be .060(?)
There are some fairly sharp curves on my KF2, which is where the cracks
occurred. I am planning to use the old pieces as templates and cut the new
with a Dremel with a cut-off wheel. With that I should be able to also
smooth the edges. I imagine that using the right kind of drill bit to drill
the rivet holes is important too, don't want any cracks there. A
metal-drilling bit?
Wrightsville Pa
Fox5flyer Guest
Posted: Thu Aug 28, 2008 3:43 am Post subject: Windsceen Lexan |
Pat, again I think there is still some confusion between polycarbonate and Plexiglas. Polycarbonate (Lexan, Rhino, Manchester, and many other names) is soft and can be cut with tin snips, drilled with a conventional drill bit, and bent in a sheet metal brake. The downside is that it is very soft and easily scratched. Plexiglass is hard, brittle, difficult to cut, can't be bent very much without a lot of heat, resistant to scratching, yet brittle enough so that it can easily be cracked if stressed. Plexiglass is what is used in certified aircraft and also what LP Aeroplastics supplies. It sounds like the J Peg you are referring to is polycarbonate, not Plexiglas.
Polycarbonate is fine for experimental aircraft use, but it will have to be changed more often than Plexiglas.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 391+ TT
"The aim of an argument or discussion should not be victory, but progress."
- Joseph Joubert
Lynn Matteson
Posted: Thu Aug 28, 2008 8:03 am Post subject: Windsceen Lexan |
Deke-
LP Aeroplastics uses *acrylic*.....where does that fit into the grand
scheme of things?
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200, 562 hrs and holding for repairs
Status: "Condition grounded, but determined to try." (Pink
Floyd..."Learning to Fly")
On Aug 28, 2008, at 7:42 AM, fox5flyer wrote:
[quote] Pat, again I think there is still some confusion between
Deke Morisse
Mikado Michigan
progress."
- Joseph Joubert
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Fox5flyer Guest
Posted: Thu Aug 28, 2008 8:49 am Post subject: Windsceen Lexan |
Acrylic -- Plexiglass, same thing.
Do you have all your parts yet?
Deke
Lynn Matteson
Posted: Thu Aug 28, 2008 10:30 am Post subject: Windsceen Lexan |
Not all of 'em...they sent a crank, but without the 6mm dowels in the
gear end or the welch/welsh plugs that are needed. I got the gear
case cover and gear that was supposed to take 2-4 weeks from
Australia yesterday. So I can start to assemble the short block, but
I'm waiting for word on some piston rings...locally, I hope. Too many
pitfalls to list, but part of the problem is it's taking too long to
get answers back from Australia, and when they do answer (through the
dealer, never to me) the answer seems to have been written by a
lawyer...vague, short answers...for example...."heat the head..."
HOW HOT? 400° 1000° 3000°? WHAT? You can tell I'm gettin' pi - - ed!
Lynn Matteson
Kitfox IV Speedster
On Aug 28, 2008, at 12:49 PM, fox5flyer wrote:
<fox5flyer(at)idealwifi.net>
Deke
N369LM |
larry huntley
Posted: Thu Aug 28, 2008 10:50 am Post subject: Windsceen Lexan |
All Plexiglas is acrylic,but not all acrylic is Plexiglas. ;o) Larry
_________________ Larry Huntley,Dundee,NY
Kitfox 4-1200 N234EE
EA81,AMAX Redrive Warp 3 blade |
Michel
larry huntley
Posted: Thu Aug 28, 2008 12:51 pm Post subject: Windsceen Lexan |
Beautiful display Michel. Thank you for sharing! Larry
Posted: Thu Aug 28, 2008 2:04 pm Post subject: Windsceen Lexan |
Deke C Thanks for the clarification. I must have used polycarbonate for the windshield and bronze tinted plexi for the cabintop and turtleback hatch. That was my 1st experience with polycarbonate. I was very surprised how flexible it is. Has anyone else tried a 2 piece windshield and cabintop vs. the 1 piece? I will be mounting it next week. I built it last winter and just finished the paint. Looks pretty good. Could have been better if I could have learned how to look into the light a little sooner. Hardest part of building a plane or car is the paint. It is an art that needs to be excercised more that every 5 to 10 years.
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
Subject: Re: Re: Windsceen Lexan
Date: Thu C 28 Aug 2008 07:42:25 -0400
.ExternalClass .EC_hmmessage P {padding-right:0px;padding-left:0px;padding-bottom:0px;padding-top:0px;} .ExternalClass BODY.EC_hmmessage {font-size:10pt;font-family:Tahoma;} Pat C again I think there is still some confusion between polycarbonate and Plexiglas. Polycarbonate (Lexan C Rhino C Manchester C and many other names) is soft and can be cut with tin snips C drilled with a conventional drill bit C and bent in a sheet metal brake. The downside is that it is very soft and easily scratched. Plexiglass is hard C brittle C difficult to cut C can't be bent very much without a lot of heat C resistant to scratching C yet brittle enough so that it can easily be cracked if stressed. Plexiglass is what is used in certified aircraft and also what LP Aeroplastics supplies. It sounds like the J Peg you are referring to is polycarbonate C not Plexiglas.
Polycarbonate is fine for experimental aircraft use C but it will have to be changed more often than Plexiglas.
Deke Morisse
Mikado Michigan
"The aim of an argument or discussion should not be victory C but progress."
- Joseph Joubert
