c.ennis(at)insightbb.com Guest
Posted: Sun Feb 26, 2006 5:51 pm Post subject: Fuel cap water protection? |
My 6A spends an appreciable amount of time outside in the weather. I have
some fuel cap covers from Sporty's, but they are not doing the job. Some
time back I remember seeing an ad for a cover which I am convinced will do a
better job. As I remember it was about 12" in diameter and was constructed
of a soft plyable rubber or plastic and had lead shot or some other heavy
material blended in with the rubber. It was heavy and soft and when placed
over the fuel cap if assumed the shape of the wing surface and effectively
sealed out water intrusion into the tank through the cap. Its weight and
plyability assured that it was in contact with the wing surface and would
not blow off.
If anyone could supply the name of the seller of this or a similar item, I
would be grateful.
Charlie Ennis
N60CE 50hrs and counting.
dan(at)rvproject.com Guest
Posted: Sun Feb 26, 2006 10:55 pm Post subject: Fuel cap water protection? |
Can't speak for anybody else, but I use a fair amount of fuelube (EZ-turn)
on my fuel caps. My plane has sat out in the rain for extended periods
while travelling (5 days in a row of T-storms) and I haven't seen any water
in the tanks. I think fuelube on the shaft and O rings does a decent job
sealing out the water. Just my personal opinion/experience.
)_( Dan
RV-7 N714D (827 hours)
http://www.rvproject.com
alexpeterson(at)earthlink Guest
Posted: Mon Feb 27, 2006 5:47 am Post subject: Fuel cap water protection? |
fuelube (EZ-turn) on my fuel caps. My plane has sat out in
the rain for extended periods while travelling (5 days in a
row of T-storms) and I haven't seen any water in the tanks.
)_( Dan
Ah, Dan the warm California Man,
I tried EZ Turn a while back - don't use it if the temperature is going to
be below about freezing. It becomes really stiff when cold. There was a
time when the OAT was around 10F where I could NOT get the caps off.
Fortunately, I was at the home base and simply taxied back to the hangar. I
spent a lot of time getting the crud out of the caps. I now spray some
Tri-Flow under the O-rings from time to time, which reduces the friction
enough that I can adjust the caps to adequately seal. It was amazing how
much more I could compress the big o-ring after putting Tri-Flow in there.
I have also used a spray white grease, same effect.
Alex Peterson
RV6-A N66AP 719 hours
Maple Grove, MN
lhelming(at)sigecom.net Guest
Posted: Mon Feb 27, 2006 5:57 am Post subject: Fuel cap water protection? |
I too use fuelube on the big O-ring in the fuel caps. I recently had my
plane parked outside for 7 weeks while our runways were widened. I did not
find any water in my tanks during the time and it rained quite hard a few
times during the time.
You could always use a couple pieces of electricians tape and do a good job
of sealing over the caps.
Indiana Larry, RV7 "SunSeeker" 90+ hours flying
khorton01(at)rogers.com Guest
Posted: Mon Feb 27, 2006 3:38 pm Post subject: Fuel cap water protection? |
On 27 Feb 2006, at 08:36, Alex Peterson wrote:
<alexpeterson(at)earthlink.net>
going to
was a
hangar. I
some
friction
amazing how
there.
Clarification please - did the spray white grease have the same
effect as the Tri-Flow, or the EZ Turn?
Kevin Horton RV-8 (finishing kit)
Ottawa, Canada
http://www.kilohotel.com/rv8
Posted: Mon Feb 27, 2006 6:51 pm Post subject: Fuel cap water protection? |
| Quote: | Clarification please - did the spray white grease have the
same effect as the Tri-Flow, or the EZ Turn?
Ottawa, Canada
Kevin, I feel they had the same effect. I don't have a lot of experience
yet, as I just this winter(finally) figured out this solution to a plaguing
problem of cold weather ops with the fuel caps. The difference in the force
needed to lock down the cap is perhaps 20% of what it had been, all else
equal, after lubing them. I simply peel out the big o-ring, clean out
whatever might be in there, and spray a small film of whatever lube in
there, and replace the o-ring. Each time the cap is actuated when wetted
with fuel, I'm sure some of the lube dissolves, so time will tell how
frequently to re-apply. I also put some under the clamping mechanism and
around that o-ring also.
There is a fundamental angle of repose problem with the fuel cap design. In
other terms, the angle of the cones is low enough that the large o-ring
refuses to slide radially outward as the two cones are brought together,
unless on puts some sort of lube behind it. There will be a bit of lube
streaking down the top of the wing, as some of the lube will be "outside"
the fuel seal. I found that I needed to tighten the adjusting nut after
using lube.
Alex Peterson
Maple Grove, MN
rv8ch
Posted: Tue Feb 28, 2006 12:36 am Post subject: Fuel cap water protection? |
| Quote: | ... I don't have a lot of experience
problem of cold weather ops with the fuel caps. ...
Another option is to use the "Retrofit lockable fuel caps".
http://www.rv8.ch/article.php?story=20040822215643234
I have not subjected them to any harsh winters, but the
design seems to be such that they will open and close
easily under all conditions.
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
_________________ Mickey Coggins
http://www.rv8.ch/ |
Posted: Tue Feb 28, 2006 4:01 am Post subject: Fuel cap water protection? |
On 27 Feb 2006, at 20:23, Alex Peterson wrote:
> Ottawa, Canada
experience
plaguing
the force
else
wetted
mechanism and
design. In
ring
together,
lube
"outside"
after
using lube.
Are you now using just a spray on lubricant, or are you using EZ Turn
+ a spray on lubricant?
We have some wonderfully clear winter flying days up here, but it can
be very cold.
Ottawa, Canada
Posted: Tue Feb 28, 2006 5:37 am Post subject: Fuel cap water protection? |
| Quote: | Are you now using just a spray on lubricant, or are you using
EZ Turn
but it can be very cold.
Ottawa, Canada
Kevin, no EZ Turn. It really, really gets stiff when OAT's get cold. Put
some on something and put it in the freezer.
Mickey, I may consider one of the retrofits at some point, but I'd have to
look at the details of the design to see the sealing mechanism first.
Alex Peterson
Maple Grove, MN
Fred Stucklen
Joined: 10 Jan 2006 Posts: 10 Location: East Windsor, CT
Posted: Tue Feb 28, 2006 5:52 am Post subject: Fuel cap water protection? |
It seems to me that there is another issue a work here: the elasticity
of the
"O" rings at low temps. I seem to remember listings (that should be in the
archives) that address this problem. If I remember correctly, Van utilizes
"O" rings that are not intended for low temperature operation.
Fred Stucklen
RV-6A N926RV
alexpeterson(at)earthlink.net <mailto:alexpeterson(at)earthlink.net> >
<mailto:khorton01(at)rogers.com> >
> Ottawa, Canada
> http://www.kilohotel.com/rv8 <http://www.kilohotel.com/rv8>
experience
plaguing
force
else
wetted
and
design. In
o-ring
together,
lube
"outside"
after
using lube.
Alex Peterson
Maple Grove, MN
cgreimer(at)mts.net Guest
Posted: Tue Feb 28, 2006 6:26 pm Post subject: Fuel cap water protection? |
| Quote: | It seems to me that there is another issue a work here: the elasticity
of the
utilizes
In cold weather I find it really helps to let the o-rings sit for a minute
or two after loosening before you try to remove the the caps. Flip the tabs
up, push down on the mechanism until you feed the bottom cone pop loose, and
then just let them sit so the o-ring can gradually relax.
I completely trashed one of my original caps trying impatiently to get it
off at a -22C fuel stop in Fargo, ND. Both caps were both well gummed up
with Fuel Lube, and that certainly is NOT the way to go for cold weather. I
installed my replacement caps from Van's as they came out of the box with no
additional lube, and they've been working pretty well but they still take a
little prying to get them out below -15C or so.
I think there might be a temperature below which they just aren't coming out
at all, lube or no lube. I'd be concerned about stopping for fuel where
it's -25C or colder. Not that I fly much in those temps, but it's not
unusual for these parts.
Curt
RV-6 375 hrs
Winnipeg
