		c.ennis(at)insightbb.com Guest
				 Posted: Sun Feb 26, 2006 5:51 pm    Post subject: Fuel cap water protection? |
				My 6A spends an appreciable amount of time outside in the weather. I have
 some fuel cap covers from Sporty's, but they are not doing the job.  Some
 time back I remember seeing an ad for a cover which I am convinced will do a
 better job. As I remember it was about 12" in diameter and was constructed
 of a soft plyable rubber or plastic and had lead shot or some other heavy
 material blended in with the rubber. It was heavy and soft and when placed
 over the fuel cap if assumed the shape of the wing surface and effectively
 sealed out water intrusion into the tank through the cap. Its weight and
 plyability assured that it was in contact with the wing surface and would
 not blow off.
 If anyone could supply the name of the seller of this or a similar item, I
 would be grateful.
 Charlie Ennis
  N60CE 50hrs and counting.
  |  | - The Matronics RV-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		dan(at)rvproject.com Guest
				 Posted: Sun Feb 26, 2006 10:55 pm    Post subject: Fuel cap water protection? |
				Can't speak for anybody else, but I use a fair amount of fuelube (EZ-turn)
 on my fuel caps.  My plane has sat out in the rain for extended periods
 while travelling (5 days in a row of T-storms) and I haven't seen any water
 in the tanks.  I think fuelube on the shaft and O rings does a decent job
 sealing out the water.  Just my personal opinion/experience.
 )_( Dan
 RV-7 N714D (827 hours)
 http://www.rvproject.com
		alexpeterson(at)earthlink Guest
				 Posted: Mon Feb 27, 2006 5:47 am    Post subject: Fuel cap water protection? |
  fuelube (EZ-turn) on my fuel caps.  My plane has sat out in
  the rain for extended periods while travelling (5 days in a
  row of T-storms) and I haven't seen any water in the tanks.
  )_( Dan
 Ah, Dan the warm California Man,
 I tried EZ Turn a while back - don't use it if the temperature is going to
 be below about freezing.  It becomes really stiff when cold.  There was a
 time when the OAT was around 10F where I could NOT get the caps off.
 Fortunately, I was at the home base and simply taxied back to the hangar.  I
 spent a lot of time getting the crud out of the caps.  I now spray some
 Tri-Flow under the O-rings from time to time, which reduces the friction
 enough that I can adjust the caps to adequately seal.  It was amazing how
 much more I could compress the big o-ring after putting Tri-Flow in there.
 I have also used a spray white grease, same effect.
 Alex Peterson
 RV6-A N66AP 719 hours
 Maple Grove, MN
		lhelming(at)sigecom.net Guest
				 Posted: Mon Feb 27, 2006 5:57 am    Post subject: Fuel cap water protection? |
				I too use fuelube on the big O-ring in the fuel caps.  I recently had my
 plane parked outside for 7 weeks while our runways were widened.  I did not
 find any water in my tanks during the time and it rained quite hard a few
 times during the time.
 You could always use a couple pieces of electricians tape and do a good job
 of sealing over the caps.
 Indiana Larry, RV7 "SunSeeker" 90+ hours flying
		khorton01(at)rogers.com Guest
				 Posted: Mon Feb 27, 2006 3:38 pm    Post subject: Fuel cap water protection? |
				On 27 Feb 2006, at 08:36, Alex Peterson wrote:
  <alexpeterson(at)earthlink.net>
  going to
  was a
  hangar.  I
  some
  friction
  amazing how
  there.
 Clarification please - did the spray white grease have the same
 effect as the Tri-Flow, or the EZ Turn?
 Kevin Horton         RV-8 (finishing kit)
 Ottawa, Canada
 http://www.kilohotel.com/rv8
				 Posted: Mon Feb 27, 2006 6:51 pm    Post subject: Fuel cap water protection? |
  	  | Quote: | 	 		   Clarification please - did the spray white grease have the
  same effect as the Tri-Flow, or the EZ Turn?
  Ottawa, Canada
 Kevin, I feel they had the same effect.  I don't have a lot of experience
 yet, as I just this winter(finally) figured out this solution to a plaguing
 problem of cold weather ops with the fuel caps.  The difference in the force
 needed to lock down the cap is perhaps 20% of what it had been, all else
 equal, after lubing them. I simply peel out the big o-ring, clean out
 whatever might be in there, and spray a small film of whatever lube in
 there, and replace the o-ring.  Each time the cap is actuated when wetted
 with fuel, I'm sure some of the lube dissolves, so time will tell how
 frequently to re-apply.  I also put some under the clamping mechanism and
 around that o-ring also.
 There is a fundamental angle of repose problem with the fuel cap design. In
 other terms, the angle of the cones is low enough that the large o-ring
 refuses to slide radially outward as the two cones are brought together,
 unless on puts some sort of lube behind it.  There will be a bit of lube
 streaking down the top of the wing, as some of the lube will be "outside"
 the fuel seal.  I found that I needed to tighten the adjusting nut after
 using lube.
 Alex Peterson
 Maple Grove, MN
		rv8ch
				 Posted: Tue Feb 28, 2006 12:36 am    Post subject: Fuel cap water protection? |
				 	  | Quote: | 	 		   ...  I don't have a lot of experience
  problem of cold weather ops with the fuel caps.  ...
 Another option is to use the "Retrofit lockable fuel caps".
 http://www.rv8.ch/article.php?story=20040822215643234
 I have not subjected them to any harsh winters, but the
 design seems to be such that they will open and close
 easily under all conditions.
 Mickey Coggins
 http://www.rv8.ch/
 #82007 finishing
  _________________ Mickey Coggins
http://www.rv8.ch/ |
				 Posted: Tue Feb 28, 2006 4:01 am    Post subject: Fuel cap water protection? |
				On 27 Feb 2006, at 20:23, Alex Peterson wrote:
 > Ottawa, Canada
  experience
  plaguing
  the force
  else
  wetted
  mechanism and
  design. In
  ring
  together,
  lube
  "outside"
  after
  using lube.
 Are you now using just a spray on lubricant, or are you using EZ Turn
 + a spray on lubricant?
 We have some wonderfully clear winter flying days up here, but it can
 be very cold.
 Ottawa, Canada
				 Posted: Tue Feb 28, 2006 5:37 am    Post subject: Fuel cap water protection? |
				 	  | Quote: | 	 		   Are you now using just a spray on lubricant, or are you using
  EZ Turn
  but it can be very cold.
  Ottawa, Canada
 Kevin, no EZ Turn.  It really, really gets stiff when OAT's get cold.  Put
 some on something and put it in the freezer.
 Mickey, I may consider one of the retrofits at some point, but I'd have to
 look at the details of the design to see the sealing mechanism first.
 Alex Peterson
 Maple Grove, MN
		Fred Stucklen
  Joined: 10 Jan 2006 Posts: 10 Location: East Windsor, CT
				 Posted: Tue Feb 28, 2006 5:52 am    Post subject: Fuel cap water protection? |
				It seems to me that there is another issue a work here: the elasticity
 of the
 "O" rings at low temps. I seem to remember listings (that should be in the
 archives) that address this problem.  If I remember correctly, Van utilizes
 "O" rings that are not intended for low temperature operation.
 Fred Stucklen
 RV-6A N926RV
 alexpeterson(at)earthlink.net <mailto:alexpeterson(at)earthlink.net> >
 <mailto:khorton01(at)rogers.com> >
       > Ottawa, Canada
       > http://www.kilohotel.com/rv8 <http://www.kilohotel.com/rv8>
 experience
 plaguing
 force
 else
 wetted
 and
 design. In
 o-ring
 together,
 lube
 "outside"
 after
       using lube.
       Alex Peterson
       Maple Grove, MN
		cgreimer(at)mts.net Guest
				 Posted: Tue Feb 28, 2006 6:26 pm    Post subject: Fuel cap water protection? |
				 	  | Quote: | 	 		      It seems to me that there is another issue a work here: the elasticity
  of the
  utilizes
 In cold weather I find it really helps to let the o-rings sit for a minute
 or two after loosening before you try to remove the the caps. Flip the tabs
 up, push down on the mechanism until you feed the bottom cone pop loose, and
 then just let them sit so the o-ring can gradually relax.
 I completely trashed one of my original caps trying impatiently to get it
 off at a -22C fuel stop in Fargo, ND. Both caps were both well gummed up
 with Fuel Lube, and that certainly is NOT the way to go for cold weather. I
 installed my replacement caps from Van's as they came out of the box with no
 additional lube, and they've been working pretty well but they still take a
 little prying to get them out below -15C or so.
 I think there might be a temperature below which they just aren't coming out
 at all, lube or no lube. I'd be concerned about stopping for fuel where
 it's -25C or colder. Not that I fly much in those temps, but it's not
 unusual for these parts.
 Curt
 RV-6  375 hrs
 Winnipeg
