N914VA(at)starband.net Guest
Posted: Thu Feb 16, 2006 4:51 am Post subject: SL-30 |
I see from my search that a few of you have put a Garmin SL-30 nav/com in their Europa. I have purchased 0ne, but it appears to be too long to install in the panel. I haven't cut anything, so I'm looking for someone to tell me how they did it and where in the panel did they put it.
Thanks in advance.
Vaughn Teegarden, the wiring idiot
XS mono
Ivor Phillips
Posted: Thu Feb 16, 2006 7:36 am Post subject: SL-30 |
Hi Vaughn
I have set the instrument panel on 1 inch rubber mounts for isolation
purposes, And this gives 12 inches clearance to the firewall,
The SL30 carrier and wiring is 11 1/2 inches, It will leave the SL30 radio
protruding about 1/2 inch from the front of the avionic panel, which is
normal for most avionics
It will go above the Dynon EMS-D10, The flush bracket being 4 1/2 inches
high, followed by a Narco 890 DME then the SL30.
Subject: SL-30
<N914VA(at)starband.net>
regards
Ivor Phillips
Posted: Thu Feb 16, 2006 9:18 am Post subject: SL-30 |
Thanks Ivor. Do you have the monowheel?
Vaughn
robh(at)hyperion-ef.us Guest
Posted: Thu Feb 16, 2006 9:26 am Post subject: SL-30 |
Apparently the factory folks never checked the dimensions of commonly
installed radios.
I wanted to avoid encroaching on the already limited knee room, so rather
than simply mounting the entire panel with a spacer at the firewall I
modified the radio stack portion of the panel to increase the depth
sufficiently to clear several of the Garmin products. First I made a
"splash" of the original radio stack area with a layup of several layers of
bid using plastic film as a mold release. Then, using that as a mold I
made a new piece that exactly matched the original, but with the needed
increased length. From there is was a straightforward cut and paste using
the usual fiberglass methods to attach the new face to the panel in place of
the original radio stack. Of course, this scheme required the same
fill-and-sand tedium that is needed on the entire exterior of the airframe,
but it was good practice.
Best regards,
Rob Housman
A070
Airframe complete
Irvine, CA
Ivor Phillips
Posted: Thu Feb 16, 2006 9:56 am Post subject: SL-30 |
No its a Tri-gear with 914
ivor
rlborger(at)mac.com Guest
Posted: Thu Feb 16, 2006 4:35 pm Post subject: SL-30 |
Vaughn,
I have a Garmin panel which I am in the process of installing. I
found that it wouldn't fit as the radio stack was too deep. I have
used 1" Neoprene stand-off isolation mounts from McMaster-Carr.
You can see what I have completed to date by going to my Europa
Owners build web-site (signature block). Go to the back end of Year
4, Q4, 2005 and beginning of Year 5, Q1, 2005.
Good building and great flying,
Bob Borger
Europa Kit #A221 N914XL, XS Mono, Intercooled 914, Airmaster C/S
http://www.europaowners.org/N914XL
(85%) tail kit done, wings closed, cockpit module installed, pitch
system in, landing gear frame in, rudder system in, outrigger mod in,
Fuselage Top on, lift/drag/flap pins in, wing incidence set, tie bar
in, flap drive in, Mod 70 done. Baggage bay in. Working in - 24
Instrument Panel, 25 Electrical, 28 Flaps, 29 Main Gear, 30 Fuel
System, 32 Tail, 34 Door Latches & 35 Doors, 37 Finishing. Airmaster
arrived 29 Sep 05. Seat arrived from Oregon Aero. Preparing ROTAX
914 for installation.
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
Posted: Thu Feb 16, 2006 5:29 pm Post subject: SL-30 |
Thank you all for the replys. The digest is indeed a wonder for the wondering!
Vaughn
