		N914VA(at)starband.net Guest
				 Posted: Thu Feb 16, 2006 4:51 am    Post subject: SL-30 |
				I see from my search that a few of you have put a Garmin SL-30 nav/com in their Europa. I have purchased 0ne, but it appears to be too long to install in the panel. I haven't cut anything, so I'm looking for someone to tell me how they did it and where in the panel did they put it.
 Thanks in advance.
 Vaughn Teegarden, the wiring idiot
 XS mono
		Ivor Phillips
				 Posted: Thu Feb 16, 2006 7:36 am    Post subject: SL-30 |
				Hi Vaughn
 I have set the instrument panel on 1 inch rubber mounts for isolation
 purposes, And this gives 12 inches clearance to the firewall,
 The SL30 carrier and wiring is 11 1/2 inches,  It will leave the SL30 radio
 protruding about 1/2 inch from the front of the avionic panel,  which is
 normal for most avionics
 It will go above the Dynon EMS-D10, The flush bracket being 4 1/2 inches
 high, followed by a Narco 890 DME then the SL30.
 Subject: SL-30
  <N914VA(at)starband.net>
 regards
 Ivor Phillips
				 Posted: Thu Feb 16, 2006 9:18 am    Post subject: SL-30 |
				Thanks Ivor. Do you have the monowheel?
 Vaughn
		robh(at)hyperion-ef.us Guest
				 Posted: Thu Feb 16, 2006 9:26 am    Post subject: SL-30 |
				Apparently the factory folks never checked the dimensions of commonly
 installed radios.
 I wanted to avoid encroaching on the already limited knee room, so rather
 than simply mounting the entire panel with a spacer at the firewall I
 modified the radio stack portion of the panel to increase the depth
 sufficiently to clear several of the Garmin products.  First I made a
 "splash" of the original radio stack area with a layup of several layers of
 bid using plastic film as a mold release.  Then, using that as a  mold I
 made a new piece that exactly matched the original, but with the needed
 increased length.  From there is was a straightforward cut and  paste using
 the usual fiberglass methods to attach the new face to the panel in place of
 the original radio stack.  Of course, this scheme required the same
 fill-and-sand tedium that is needed on the entire exterior of the airframe,
 but it was good practice.
 Best regards,
 Rob Housman
 A070
 Airframe complete
 Irvine, CA
		Ivor Phillips
				 Posted: Thu Feb 16, 2006 9:56 am    Post subject: SL-30 |
				No its a Tri-gear with 914
 ivor
		rlborger(at)mac.com Guest
				 Posted: Thu Feb 16, 2006 4:35 pm    Post subject: SL-30 |
				Vaughn,
 I have a Garmin panel which I am in the process of installing.  I
 found that it wouldn't fit as the radio stack was too deep.  I have
 used 1"  Neoprene stand-off isolation mounts from McMaster-Carr.
 You can see what I have completed to date by going to my Europa
 Owners build web-site (signature block).  Go to the back end of Year
 4, Q4, 2005 and beginning of Year 5, Q1, 2005.
 Good building and great flying,
 Bob Borger
 Europa Kit #A221 N914XL, XS Mono, Intercooled 914, Airmaster C/S
 http://www.europaowners.org/N914XL
 (85%) tail kit done, wings closed, cockpit module installed, pitch
 system in, landing gear frame in, rudder system in, outrigger mod in,
 Fuselage Top on, lift/drag/flap pins in, wing incidence set, tie bar
 in, flap drive in, Mod 70 done.  Baggage bay in.  Working in - 24
 Instrument Panel, 25 Electrical, 28 Flaps, 29 Main Gear, 30 Fuel
 System, 32 Tail, 34 Door Latches & 35 Doors, 37 Finishing.  Airmaster
 arrived 29 Sep 05.  Seat arrived from Oregon Aero.  Preparing ROTAX
 914 for installation.
 3705 Lynchburg Dr.
 Corinth, TX  76208
 Home:  940-497-2123
 Cel:  817-992-1117
				 Posted: Thu Feb 16, 2006 5:29 pm    Post subject: SL-30 |
				Thank you all for the replys. The digest is indeed a wonder for the wondering!
 Vaughn
