Exhaust Ball Joint Conversion Kit - anyone using it?
John H Murphy
PostPosted: Sun Mar 25, 2007 2:01 pm    Post subject: Exhaust Ball Joint Conversion Kit - anyone using it? Reply with quote
CPS is selling this new "Exhaust Ball Joint Conversion Kit". It's about time for the muffler spring replacement. Anybody using this? If so, what's the verdict so far?
HShack(at)aol.com
PostPosted: Sun Mar 25, 2007 5:02 pm    Post subject: Exhaust Ball Joint Conversion Kit - anyone using it? Reply with quote
In a message dated 3/25/2007 6:02:31 PM Eastern Daylight Time, jhm9812(at)yahoo.com writes:
I like mine fine, but I recommend cutting off all the spring hooks before you put it on. I also had to use some longer bolts to avoid having to cut any off the ball joint.
Howard Shackleford
FS II
SC
AOL.com.
N111KX (Kip)
PostPosted: Sun Mar 25, 2007 6:17 pm    Post subject: Re: Exhaust Ball Joint Conversion Kit - anyone using it? Reply with quote
I've used them for 5 years now and have been very reliable. They do take some worry out of springs breaking...
Kip
Firestar II
building a Waiex at the moment
Kip
Firestar II, N111KX
Waiex, N111YX
Quickie 1, N111QX
Atlanta
Richard Pike
PostPosted: Sun Mar 25, 2007 8:06 pm    Post subject: Re: Exhaust Ball Joint Conversion Kit - anyone using it? Reply with quote
I made my own. Here are the ones on the MKIII and on the FSII. With 5/16" bolts, it will take a while to wear through them...
Richard Pike
MKIII N420P (420ldPoops)
 Filesize:  48.27 KB
 Viewed:  581 Time(s)
 Filesize:  45.92 KB
 Viewed:  607 Time(s)
David.Lehman
PostPosted: Tue Mar 27, 2007 1:15 pm    Post subject: Exhaust Ball Joint Conversion Kit - anyone using it? Reply with quote
I have 30+ hours on mine... A lot better than springs in my estimation... I have stainless bolts and they're wearing... My best guesstimate is stainless bolt replacement at around 40-50 hours... No broken springs though...
DVD
On 3/25/07, John H Murphy <jhm9812(at)yahoo.com (jhm9812(at)yahoo.com)> wrote: [quote]--> Kolb-List message posted by: "John H Murphy" <jhm9812(at)yahoo.com (jhm9812(at)yahoo.com)>
ô¿ô
"Both optimists and pessimists contribute to the society. The optimist invents the aeroplane, the pessimist the parachute."
--- George Bernard Shaw
