John H Murphy
Joined: 03 Jan 2007 Posts: 78 Location: Henderson, NV
Posted: Sun Mar 25, 2007 2:01 pm Post subject: Exhaust Ball Joint Conversion Kit - anyone using it? |
CPS is selling this new "Exhaust Ball Joint Conversion Kit". It's about time for the muffler spring replacement. Anybody using this? If so, what's the verdict so far?
HShack(at)aol.com Guest
Posted: Sun Mar 25, 2007 5:02 pm Post subject: Exhaust Ball Joint Conversion Kit - anyone using it? |
In a message dated 3/25/2007 6:02:31 PM Eastern Daylight Time, jhm9812(at)yahoo.com writes:
| Quote: | | CPS is selling this new "Exhaust Ball Joint Conversion Kit". It's about time for the muffler spring replacement. Anybody using this? If so, what's the verdict so far? |
I like mine fine, but I recommend cutting off all the spring hooks before you put it on. I also had to use some longer bolts to avoid having to cut any off the ball joint.
Howard Shackleford
FS II
SC
AOL.com.
N111KX (Kip)
Posted: Sun Mar 25, 2007 6:17 pm Post subject: Re: Exhaust Ball Joint Conversion Kit - anyone using it? |
I've used them for 5 years now and have been very reliable. They do take some worry out of springs breaking...
Kip
Firestar II
building a Waiex at the moment
_________________ Kip
Firestar II, N111KX
Waiex, N111YX
Quickie 1, N111QX
Atlanta |
Richard Pike
Posted: Sun Mar 25, 2007 8:06 pm Post subject: Re: Exhaust Ball Joint Conversion Kit - anyone using it? |
I made my own. Here are the ones on the MKIII and on the FSII. With 5/16" bolts, it will take a while to wear through them...
Richard Pike
MKIII N420P (420ldPoops)
48.27 KB |
655 Time(s) |
45.92 KB |
691 Time(s) |
David.Lehman
Joined: 10 Jan 2006 Posts: 265 Location: "Lovely" Fresno CA
Posted: Tue Mar 27, 2007 1:15 pm Post subject: Exhaust Ball Joint Conversion Kit - anyone using it? |
I have 30+ hours on mine... A lot better than springs in my estimation... I have stainless bolts and they're wearing... My best guesstimate is stainless bolt replacement at around 40-50 hours... No broken springs though...
DVD
On 3/25/07, John H Murphy <jhm9812(at)yahoo.com (jhm9812(at)yahoo.com)> wrote: [quote]--> Kolb-List message posted by: "John H Murphy" <jhm9812(at)yahoo.com (jhm9812(at)yahoo.com)>
_________________ ô¿ô
"Both optimists and pessimists contribute to the society. The optimist invents the aeroplane, the pessimist the parachute."
--- George Bernard Shaw |
