steve.freeman(at)syntaxds Guest
Posted: Fri Aug 30, 2013 11:44 am Post subject: Wing root rubber fairing material question |
Hi Jay…
This is a huge help.
How did you get it to lay flat as you go around the nose? Also, did you cut out the bottom side of the material as you go over the spar? DO you use glue to hold it down? IF so, what kind and at what point did you apply it?
Thanks for the photos…Your plane looks awesome1
Steve Freeman
602-228-3830
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Jay Bannister
Sent: Friday, August 30, 2013 12:26 PM
Subject: Re: Wing root rubber fairing material question
Steve,
Not exactly what you asked for, but the best I can do.
Jay
1.81 KB |
3045 Time(s) |
1.81 KB |
3045 Time(s) |
jaybannist(at)cs.com Guest
Posted: Fri Aug 30, 2013 11:58 am Post subject: Wing root rubber fairing material question |
Steve,
The flange that touches the fuselage stayed pretty tight by itself. If it flares as it goes around the nose, I have heard that a little "nudging" with a heat gun might help. I did have to glue down the flange that lays on the wing in just a few places. Otherwise, no glue needed. On the bottom, I stopped it just short of the spar.
Jay
1.81 KB |
3044 Time(s) |
1.81 KB |
3044 Time(s) |
