Wing root rubber fairing material question
steve.freeman(at)syntaxds
PostPosted: Fri Aug 30, 2013 11:44 am    Post subject: Wing root rubber fairing material question Reply with quote
Hi Jay…
This is a huge help.
How did you get it to lay flat as you go around the nose? Also, did you cut out the bottom side of the material as you go over the spar? DO you use glue to hold it down? IF so, what kind and at what point did you apply it?
Thanks for the photos…Your plane looks awesome1
Steve Freeman
  602-228-3830
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Jay Bannister
Sent: Friday, August 30, 2013 12:26 PM
Subject: Re: Wing root rubber fairing material question
Steve,
Not exactly what you asked for, but the best I can do.
Jay
 Filesize:  1.81 KB
 Viewed:  3028 Time(s)
 Filesize:  1.81 KB
jaybannist(at)cs.com
PostPosted: Fri Aug 30, 2013 11:58 am    Post subject: Wing root rubber fairing material question Reply with quote
Steve,
The flange that touches the fuselage stayed pretty tight by itself. If it flares as it goes around the nose, I have heard that a little "nudging" with a heat gun might help. I did have to glue down the flange that lays on the wing in just a few places. Otherwise, no glue needed.  On the bottom, I stopped it just short of the spar.
Jay
 Filesize:  1.81 KB
 Viewed:  3027 Time(s)
 Filesize:  1.81 KB
