Dnul
Posted: Thu Jul 11, 2013 10:36 am Post subject: Drilling Center Of Tube |
To drill the center of a tube use a "V" block. Simply lower the drill on the drill press down to the bottom of the "V" to position for center.
_________________ Dnul |
Carolina Flyer
Joined: 03 Oct 2010 Posts: 62 Location: Buffalo, South Carolina
Posted: Thu Jul 11, 2013 1:12 pm Post subject: Re: Drilling Center Of Tube |
Here is what I use and it works perfect every time
193.78 KB |
6741 Time(s) |
88.89 KB |
6741 Time(s) |
_________________ Kolb Firestar II
503 C-Box / RK400
Soon to have a
Rotax 670 DCDI
with a C-Box and
RK 400 Clutch
Challenger II
503 Tall Drive
Dnul
Posted: Fri Jul 12, 2013 10:22 am Post subject: Re: Drilling Center Of Tube |
That would be great to order for drilling the vertical stabilizer post, the drag strut, or the landing gear leg and the universal joint on the aileron control tube which would be drilled inaccurately. It might be used to drill an innumerable number of holes in small tubing used in the wing.
Dnul
