I Love Left handed drill bits
rickofudall
PostPosted: Sun Jul 07, 2013 11:41 am    Post subject: I Love Left handed drill bits Reply with quote
Let's face it, there are ham handed people in this world who should not be allowed near fine machinery. The fellow who logged that he "cleaned" the carbs on the 912 belonging to my customer is one. He put the fixation screw holding the jet needle in so tight that the screw driver slot just stripped off its ears when I tried to get it out. Soaked it with PB Blaster for 36 hours and no luck. Chucked the piston in my lathe, touched the top of the screw with a center drill and chucked up a left handed drill bit. Took longer to set up than it did for the drill to pull the screw out. As you can see by the picture the needle is quite literally jammed into the bottom of the screw. The carb piston, thankfully, is completely pristeen.  Did I mention that I love left handed drill bits?
Rick Girard
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
  - Groucho Marx
 Filesize:  948.59 KB
 Viewed:  12354 Time(s)
BARRY CHECK 6
PostPosted: Sun Jul 07, 2013 1:21 pm    Post subject: I Love Left handed drill bits Reply with quote
"THE REASON WHY PILOTS THINK THEY ARE MECHANICS IS BECAUSE THEY CAN BUY TOOLS AT HOME DEPOT."
Barry
On Sun, Jul 7, 2013 at 3:41 PM, Richard Girard <aslsa.rng(at)gmail.com (aslsa.rng(at)gmail.com)> wrote:
[quote]Let's face it, there are ham handed people in this world who should not be allowed near fine machinery. The fellow who logged that he "cleaned" the carbs on the 912 belonging to my customer is one. He put the fixation screw holding the jet needle in so tight that the screw driver slot just stripped off its ears when I tried to get it out. Soaked it with PB Blaster for 36 hours and no luck. Chucked the piston in my lathe, touched the top of the screw with a center drill and chucked up a left handed drill bit. Took longer to set up than it did for the drill to pull the screw out. As you can see by the picture the needle is quite literally jammed into the bottom of the screw. The carb piston, thankfully, is completely pristeen.  Did I mention that I love left handed drill bits?
Rick Girard
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
  - Groucho Marx
Roger Lee
PostPosted: Sun Jul 07, 2013 7:08 pm    Post subject: Re: I Love Left handed drill bits Reply with quote
Hi Rick,
It wasn't the mechanics fault. These fixation screws have Loctite on them from Bing and they can strip out if not heated. Once in a while I find one I can remove without over torquing it, but most times I heat them with a heat gun or small butane torch. Once heated they come right out.
What were you saying on the other post about Rotax engines, problems and owners?
It usually isn't the engine that has the issues, but not having the proper training to maintain them or maintaining them on schedule. They are not Continental's or Lycoming's and treating them as such will only cost owners and mechanics grief and money.
Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056
Thom Riddle
PostPosted: Mon Jul 08, 2013 4:19 am    Post subject: Re: I Love Left handed drill bits Reply with quote
Anyone who thinks that this connection needs thread locker clearly does not understand that aluminum has a very high coefficient of friction. In use, there is no external torque that would tend to loosen this connection. Applying thread locker to this connection is unnecessary and a very bad idea.
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
Roger Lee
PostPosted: Mon Jul 08, 2013 1:23 pm    Post subject: Re: I Love Left handed drill bits Reply with quote
Hi Thom,
I comes with a dry blue Loctite from Bing. Either from the factory or if ordered separately.
Roger Lee
Tucson, Az.
Cell 520-349-7056
rickofudall
PostPosted: Tue Jul 09, 2013 6:47 am    Post subject: I Love Left handed drill bits Reply with quote
Thom, As Roger noted the Locktite comes applied to the fixation screw in dry form. Also, the use of Locktite 221 is specified for this part in the 912 Illustrated Parts Catalog.
Rick Girard
On Mon, Jul 8, 2013 at 7:19 AM, Thom Riddle <riddletr(at)gmail.com (riddletr(at)gmail.com)> wrote:
--> RotaxEngines-List message posted by: "Thom Riddle" <riddletr(at)gmail.com (riddletr(at)gmail.com)>
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
http://forums.matronics.com/viewtopic.php?p=404178#404178
-List" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
  - Groucho Marx
Thom Riddle
PostPosted: Wed Jul 10, 2013 4:05 am    Post subject: Re: I Love Left handed drill bits Reply with quote
I am aware that Rotax puts the blue loctite on that screw. I am also aware that they have changed their minds on many other things as their customer base's experience increased over the years. As experience grew they have redesigned or changed specs on many things over the years. One original design element in particular that caused all kinds of grief which they eventually changed was the internal Torx type fitting on the gearbox magnetic oil fitting.
My experience with aluminum threads, where no in-use external torque is applied in the loosening direction, is that no thread locker is needed due to the high coefficient of friction. Perhaps Rotax will one day realize that loctite is not needed on this carb part. Until then, use it if you want.
I remove it from the carbs I disassemble and do not apply new loctite when re-installing. In fact upon reinstallation I torque it only with thumb and one finger because even without loctite it very easy to over torque this part and make the left-handed drills or easy-outs a required part of future disassembly. Been there once and that was enough.
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
Roger Lee
PostPosted: Wed Jul 10, 2013 8:26 am    Post subject: Re: I Love Left handed drill bits Reply with quote
Hi Thom,
The reason Loctite is applied here is that these are two different metals and this area gets significant vibration and any loosening would cause a needle change in the jet and possibly a aircraft incident before it was found. I'm sure they have had their reasons over the last 22 years to apply this. It's a better safe than sorry application. Too much Loctite here can be a problem getting it out later. Just the tiniest drop is needed. If it still has some of the old Loctite on the screw it will work just fine. Heating it is no big deal either for removal. Like I said, I take a small butane torch and heat it for a few seconds and they all come right out.
Roger Lee
Tucson, Az.
Cell 520-349-7056
BARRY CHECK 6
PostPosted: Wed Jul 10, 2013 9:34 am    Post subject: I Love Left handed drill bits Reply with quote
Gaggle:
From a Test Engineer viewpoint; Thom is quite accurate with aluminum threads not requiring a liquid locking agent.  There are a few questions that would have to be asked though:
1 - What type of aluminum is the part made from?
2 - What temper is it brought to?
3 - Was the tempering done before or after the threads were cut?
4 - Were the threads cut or rolled?
5 - What type of thread is being used?
6 - What material is the part being threaded into?
And then a repeat of all the questions above about the mating threaded part:7 - What type of aluminum is the part made from?
8 - What temper is it brought to?
9 - Was the tempering done before or after the threads were cut?
10 - Were the threads cut or molded <-- Since this is a internal thread.
11 - What type of thread is being used?  <-- This should be the same as the mating part - BUT - Sometimes one company makes part A and another makes part B and little things like percentage of thread is different.
Now if both parts are aluminum and ESPECIALLY if they are not ANODIZED, There is a very high possibility of galling and/or fretting.
Some methods of prevention are:
Shoulder Seat - To limit force/torque on threads - This is something Roatx really should consider.  Maybe in the next generation of engineering changes.
Lock washer - I guess none was used in this situation.
Nylon Stop  Plug
Teflon Tape - Not for this situation.  Untrained users.
Teflon Paste - HMmmmm  much better idea - But 99.9987% of the users tend to OVER APPLY it and cause catastrophic problems.
Liquid Locking Compound - Well this would be BLUE Loctite but there is a problem with this --  They advertize a holding strength of 8.5 Nm (~6.2 Ft/Lbs).  Well this is WAY too much holding force for such a small thread and material.  So, again I hope Rotax makes some changes.  AND when Loctite did this testing and came up with the 8.5 Nm, they did NOT test it on aluminum threads. Holding force is VERY argumentative.  They TRY to be scientific but in the long run it is a shot in the twilight.
Last point:  It truly is a good idea to use SOMETHING on the threads.  Not really needed too much for holding but for thread protection.  If aluminum threads are not protected they will gall/frett and LOCK-UP!  From an FAA standpoint they and you need some reassurance that the thing will not vibrate free in flight AND should be easy to remove for inspection/repair/replacement.  Just think there are companies that have made entire fortunes on just doing that - Loctite!
Barry
On Wed, Jul 10, 2013 at 8:05 AM, Thom Riddle <riddletr(at)gmail.com (riddletr(at)gmail.com)> wrote:
[quote]--> RotaxEngines-List message posted by: "Thom Riddle" <riddletr(at)gmail.com (riddletr(at)gmail.com)>
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
Roger Lee
PostPosted: Wed Jul 10, 2013 1:54 pm    Post subject: Re: I Love Left handed drill bits Reply with quote
I may agree about aluminum, but from the Bing and Rotax guys it's a liability issue. Adding a little heat as far as they are concerned is no big deal for peace of mind.
Should be peace of mind for you now too.
Roger Lee
Tucson, Az.
Cell 520-349-7056
