pmather
Posted: Fri Dec 16, 2011 11:22 am Post subject: Vans 35A alternator - Nippondenso 14184 |
Can anyone tell me the purpose of the third wire on the connector of this
alternator?
The cable supplied by Vans has Black - ground; green - field; white - not
connected.
I'm looking at using a regulator that has a stator connection which it uses
to drive an ignition light - is the white connection to the stator?
Thanks in advance
Peter
Posted: Fri Dec 16, 2011 1:49 pm Post subject: Vans 35A alternator - Nippondenso 14184 |
At 01:17 PM 12/16/2011, you wrote:
alternator?
connected.
Does Van's alternator REQUIRE an external
regulator? Last time I looked, their offerings
were internally regulated. Can you post an excerpt
of the schematic . . . or point us to a link where
your applicable schematic is visible?
Trying to give useful advise based on numbers of
pins and colors of wires is risky. The SCHEMATICS
associated with the products being explored are
necessary for offering well considered advice.
pmather
Posted: Fri Dec 16, 2011 2:52 pm Post subject: Vans 35A alternator - Nippondenso 14184 |
Bob
The alternator is one Vans were selling back in 04. It is externally
regulated and Vans then recommended a VR-1751 or MS-150A regulator but
always said to leave the white lead "unconnected"
I can't see what else the third wire could be except a stator connection but
any suggestions or test ideas would be appreciated.
Best Regards
Peter
Posted: Sat Dec 17, 2011 7:30 am Post subject: Vans 35A alternator - Nippondenso 14184 |
At 04:48 PM 12/16/2011, you wrote:
Bob
Best Regards
Peter
Okay. If there's no regulator built in, then the
third wire cannot be for the legacy "alternator
inop light" provided by most built in regulators.
This leaves the possibility that it is a stator
tap for a y-wound alternator.
Do an ohmmeter test between this connection and
the alternator case. Check the indicated resistance
for both polarities of the meter leads. One should
be some 'low' value while the other will be very
high if not infinite. This the expected display
for looking at the resistance of the lower trio
of diodes.
Then do the same test between the 'third lead' and
the b-terminal. You should see similar if not identical
readings for the upper trio of diodes.
Finally, in MIGHT be that Van was selling a modified
automotive alternator wherein an internal regulator
was removed. In this case, connections of the third
lead are left up to the modifier . . . but is likely
to be open circuit to any other portion of the
alternator's internals.
It's a game of non-invasive Clue . . . except that
nobody died at the hands of Col. Mustard in the
parlor by hanging.
Whoops!
Speaking of clues . . . I missed the one you provided
in the subject line. Fooey . . . I've not finished
my first cup of coffee . . . if that's a valid excuse.
Okay, go to the Motorcar Parts of America website
at
http://www.onlinetechhelp.com/picturesPlus1.php
and enter your 14184 in the part number search.
Don't know why this takes you to a page featuring
TWO part numbers, but select 14184.
There you will find a drawing that gives dimensions,
a picture of the device and a connector pin-out diagram.
In this case, the mystery "third lead" is indeed a
stator tap connection.
The MPA website belongs to the company that
offered me detailed insight into the alternator
remanufacturing business several years ago. I gave
a brief accounting of a tour of their Tijuana, MX
facility in Revision 12, Chapter 3 of the 'Connection.
Newcomers to the List might wish to avail themselves
of that description. It's an eye-opener. I suggest
that everyone bookmark this website in their browser.
It's a huge repository of useful information.
I was tempted to delete the opening soliloquy to
gloss over my lack of due diligence in sorting the
data you offered. But it's still a valid technique
for making useful deductions on parts not so well
identified as yours.
So here it is . . . warts and all. I'm going for
another cup of coffee.
pmather
Posted: Sat Dec 17, 2011 8:48 am Post subject: Vans 35A alternator - Nippondenso 14184 |
Bob
Thanks for that - I should have worked that one out for myself. Anyway, I've
just tested as suggested using the diode setting on my DMM and it is
definitely stator.
Have you had a look at the STMicroelectronics alternator regulator chips?
Single chip does everything, easy to package.
The top of the ranhge version seems to be
http://www.st.com/internet/automotive/product/89833.jsp
Best regards
Peter
Posted: Sat Dec 17, 2011 9:44 am Post subject: Vans 35A alternator - Nippondenso 14184 |
| Quote: | Have you had a look at the STMicroelectronics alternator regulator chips?
I've not seen those devices before. Nice. They
have a built in power fet for controlling the
field.
The problem with most regulator products is that
they're designed to integrate with modern engine
controllers and even the older chips (20+ years)
have a phase sense pin that shuts the field current
off until the alternator is sensed to be rotating.
Not sure how this particular chip works but the
device I first evaluated
http://aeroelectric.com/Mfgr_Data/Misc/Freescale/MC33092A_Simplified.pdf
also has this 'phase input signal' on pin 10
that had to be 'fooled' believing that the
alternator was turning. Otherwise, I needed to
bring a phase sample out of the alternator (yet
another airframe wire) to accommodate the
chip's design goals.
I've considered a number of new design projects
for regulators friendly to the legacy, external
regulator philosophy . . . but there's just too
many perfectly acceptable regulators out there
already.
If I do one in the future, it will be processor
based and feature some diagnostic outputs . . .
THAT's a feature that the contemporary COTS
products don't have. The L9911 chip you cited
does have diagnostics tailored to the automotive
engine controller world . . . I'd probably go
more for a human readable output of some kind.
That's WAaaayyyy back on the stove's burners . . .
