		pmather
				 Posted: Fri Dec 16, 2011 11:22 am    Post subject: Vans 35A alternator - Nippondenso 14184 |
				Can anyone tell me the purpose of the third wire on the connector of this
 alternator?
 The cable supplied by Vans has Black - ground; green - field; white - not
 connected.
 I'm looking at using a regulator that has a stator connection which it uses
 to drive an ignition light - is the white connection to the stator?
 Thanks in advance
 Peter
				 Posted: Fri Dec 16, 2011 1:49 pm    Post subject: Vans 35A alternator - Nippondenso 14184 |
				At 01:17 PM 12/16/2011, you wrote:
 alternator?
 connected.
      Does Van's alternator REQUIRE an external
      regulator? Last time I looked, their offerings
      were internally regulated. Can you post an excerpt
      of the schematic . . . or point us to a link where
      your applicable schematic is visible?
      Trying to give useful advise based on numbers of
      pins and colors of wires is risky. The SCHEMATICS
      associated with the products being explored are
      necessary for offering well considered advice.
		pmather
				 Posted: Fri Dec 16, 2011 2:52 pm    Post subject: Vans 35A alternator - Nippondenso 14184 |
				Bob
 The alternator is one Vans were selling back in 04. It is externally
 regulated and Vans then  recommended a VR-1751 or MS-150A regulator but
 always said to leave the white lead "unconnected"
 I can't see what else the third wire could be except a stator connection but
 any suggestions or test ideas would be appreciated.
 Best Regards
 Peter
				 Posted: Sat Dec 17, 2011 7:30 am    Post subject: Vans 35A alternator - Nippondenso 14184 |
				At 04:48 PM 12/16/2011, you wrote:
 Bob
 Best Regards
 Peter
     Okay. If there's no regulator built in, then the
     third wire cannot be for the legacy "alternator
     inop light" provided by most built in regulators.
     This leaves the possibility that it is a stator
     tap for a y-wound alternator.
     Do an ohmmeter test between this connection and
     the alternator case. Check the indicated resistance
     for both polarities of the meter leads. One should
     be some 'low' value while the other will be very
     high if not infinite. This the expected display
     for looking at the resistance of the lower trio
     of diodes.
     Then do the same test between the 'third lead' and
     the b-terminal. You should see similar if not identical
     readings for the upper trio of diodes.
     Finally, in MIGHT be that Van was selling a modified
     automotive alternator wherein an internal regulator
     was removed. In this case, connections of the third
     lead are left up to the modifier . . . but is likely
     to be open circuit to any other portion of the
     alternator's internals.
     It's a game of non-invasive Clue . . . except that
     nobody died at the hands of Col. Mustard in the
     parlor by hanging.
     Whoops!
     Speaking of clues . . . I missed the one you provided
     in the subject line. Fooey . . . I've not finished
     my first cup of coffee . . . if that's a valid excuse.
     Okay, go to the Motorcar Parts of America website
     at
 http://www.onlinetechhelp.com/picturesPlus1.php
     and enter your 14184 in the part number search.
     Don't know why this takes you to a page featuring
     TWO part numbers, but select 14184.
     There you will find a drawing that gives dimensions,
     a picture of the device and a connector pin-out diagram.
     In this case, the mystery "third lead" is indeed a
     stator tap connection.
     The MPA website belongs to the company that
     offered me detailed insight into the alternator
     remanufacturing business several years ago. I gave
     a brief accounting of a tour of their Tijuana, MX
     facility in Revision 12, Chapter 3 of the 'Connection.
     Newcomers to the List might wish to avail themselves
     of that description. It's an eye-opener. I suggest
     that everyone bookmark this website in their browser.
     It's a huge repository of useful information.
     I was tempted to delete the opening soliloquy to
     gloss over my lack of due diligence in sorting the
     data you offered. But it's still a valid technique
     for making useful deductions on parts not so well
     identified as yours.
     So here it is . . . warts and all. I'm going for
     another cup of coffee.
		pmather
				 Posted: Sat Dec 17, 2011 8:48 am    Post subject: Vans 35A alternator - Nippondenso 14184 |
				Bob
 Thanks for that - I should have worked that one out for myself. Anyway, I've
 just tested as suggested using the diode setting on my DMM and it is
 definitely stator.
 Have you had a look at the STMicroelectronics alternator regulator chips?
 Single chip does everything, easy to package.
 The top of the ranhge version seems to be
 http://www.st.com/internet/automotive/product/89833.jsp
 Best regards
 Peter
				 Posted: Sat Dec 17, 2011 9:44 am    Post subject: Vans 35A alternator - Nippondenso 14184 |
				 	  | Quote: | 	 		  Have you had a look at the STMicroelectronics alternator regulator chips?
     I've not seen those devices before. Nice. They
     have a built in power fet for controlling the
     field.
     The problem with most regulator products is that
     they're designed to integrate with modern engine
     controllers and even the older chips (20+ years)
     have a phase sense pin that shuts the field current
     off until the alternator is sensed to be rotating.
     Not sure how this particular chip works but the
     device I first evaluated
 http://aeroelectric.com/Mfgr_Data/Misc/Freescale/MC33092A_Simplified.pdf
     also has this 'phase input signal' on pin 10
     that had to be 'fooled' believing that the
     alternator was turning. Otherwise, I needed to
     bring a phase sample out of the alternator (yet
     another airframe wire) to accommodate the
     chip's design goals.
     I've considered a number of new design projects
     for regulators friendly to the legacy, external
     regulator philosophy . . . but there's just too
     many perfectly acceptable regulators out there
     already.
     If I do one in the future, it will be processor
     based and feature some diagnostic outputs . . .
     THAT's a feature that the contemporary COTS
     products don't have. The L9911 chip you cited
     does have diagnostics tailored to the automotive
     engine controller world . . . I'd probably go
     more for a human readable output of some kind.
     That's WAaaayyyy back on the stove's burners  . . .
