annual again
sarg314(at)gmail.com
PostPosted: Tue May 17, 2011 9:36 am    Post subject: annual again Reply with quote
Thanks for those great responses to my question about the annual.  I will definitely use those lists.
I read thru section FAR 43.  I didn't see anywhere a clear description of the timing of the annual inspection.  If my airworthiness certificate was granted July 7, do I have to have the inspection completed by july 7?  Is there a "grace period"?
Is there a special logbook entry to be made?
Tom Sargent
recapen(at)earthlink.net
PostPosted: Tue May 17, 2011 10:20 am    Post subject: annual again Reply with quote
Mine was actually spelled out in my operating limitations – see attached.
I didn’t steal these from Gary……but I didn’t write them either……
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of thomas sargent
Sent: Tuesday, May 17, 2011 1:33 PM
To: rv-list
Subject: annual again
Tom Sargent
Page_4.pdf
 Filename:  Page_4.pdf
 Filesize:  737.33 KB
 Downloaded:  173 Time(s)
n320wt(at)yahoo.com
PostPosted: Tue May 17, 2011 11:04 am    Post subject: annual again Reply with quote
Your condition inspection is due the
last day of the month. Most pilots I
know like to have the books signed
on the first day of the month so you
really get thirteen months
Sent from my iPhoneBrian Alley
carbonfibercomposites.net
304-395-4932
On May 17, 2011, at 1:32 PM, thomas sargent <sarg314(at)gmail.com (sarg314(at)gmail.com)> wrote:
[quote]Thanks for those great responses to my question about the annual. I will definitely use those lists.
Tom Sargent
bobbyhester(at)newwavecom
PostPosted: Tue May 17, 2011 11:13 am    Post subject: annual again Reply with quote
You have till the end of the month and the logbook entry is in your operating limitations, I believe.
Sent from my Verizon iPhone
Tom Sargent
n223rv(at)wolflakeairport
PostPosted: Tue May 17, 2011 12:01 pm    Post subject: annual again Reply with quote
Mine too was input by the FAA inspector in my log book and operating limitations. He gave me 13 months for the first year. A/W received 5/2/2011, conditional inspection due 6/30/12...
Tom Sargent
bicyclop(at)pacbell.net
PostPosted: Tue May 17, 2011 8:38 pm    Post subject: annual again Reply with quote
Appendix D to part 43 contains the minimum inspection requirements. The log entry should reference appendix D. The exact verbiage should be in you oplims.
Pax,
Ed Holyoke
On 5/17/2011 10:32 AM, thomas sargent wrote: [quote]Thanks for those great responses to my question about the annual.  I will definitely use those lists.
Tom Sargent
mrobert569(at)hotmail.com
PostPosted: Thu May 19, 2011 6:59 am    Post subject: annual again Reply with quote
Sorry to do this to you, but your inspector cannot "give" you 13 months as the requirement to do the condition inspection every 12 xcalendar months is in FAR 91 as well as clearly called out in the aircraft operating limitations.  As your a/w was received on 5/2/2011 then you will need to inspect but the end of May, 2012, which effectively gives you almost 13 months.  Idealy, do the condition inspection the last week of may and sign it off on June 1.  Then the next year the condition inpsection won't be due until June 30.
For Tom,
A really good place to find POHs and inspeciton checklists is on the Van's Air Force website.  Several people, myself included, have posted RV POH's there.  And almost every one of them includes a section with a condition inpseciton checklist.
Mike Robertson
Das Fed
Repeat Offender
Subject: Re: annual again
Date: Tue, 17 May 2011 15:55:35 -0400
To: rv-list(at)matronics.com
On May 17, 2011, at 1:32 PM, thomas sargent <sarg314(at)gmail.com> wrote:
[quote] Thanks for those great responses to my question about the annual.  I will definitely use those lists.
Tom Sargent
-List
PostPosted: Thu May 19, 2011 7:55 am    Post subject: annual again Reply with quote
Not going to argue with you, but the FAA did my A/W inspection and gave me my op limits. He specifically stated in my op limits the 1st conditional inspection is due 6/30/2012. He told me he always gives 13 months the first year. He did the same thing when he certified my RV-4 in 2002...
On May 19, 2011, at 10:55 AM, Mike Robertson <mrobert569(at)hotmail.com (mrobert569(at)hotmail.com)> wrote:
[quote] Sorry to do this to you, but your inspector cannot "give" you 13 months as the requirement to do the condition inspection every 12 xcalendar months is in FAR 91 as well as clearly called out in the aircraft operating limitations. As your a/w was received on 5/2/2011 then you will need to inspect but the end of May, 2012, which effectively gives you almost 13 months. Idealy, do the condition inspection the last week of may and sign it off on June 1. Then the next year the condition inpsection won't be due until June 30.
For Tom,
Mike Robertson
Das Fed
Repeat Offender
From: [url=mailto:n223rv(at)wolflakeairport.net]n223rv(at)wolflakeairport.net (n223rv(at)wolflakeairport.net)[/url]
To: [url=mailto:rv-list(at)matronics.com]rv-list(at)matronics.com (rv-list(at)matronics.com)[/url]
Tom Sargent
-List
Kellym
PostPosted: Thu May 19, 2011 7:04 pm    Post subject: annual again Reply with quote
Mike R is correct. Not even an FAA employee can break the rules. 12
months is the rule. Now if he did your airworthiness inspection on the
last day of the month, I suppose he could date it for the next day.
Kelly
A&P/IA
Tech Counselor
FAAST Team
in 2002...
Kelly McMullen
KCHD
