jan_de_jong(at)casema.nl Guest
Posted: Tue Mar 08, 2011 9:33 am Post subject: Bistable relay control |
I'm thinking of making a monostable relay type control for bistable
relays (if and when) in one or more (or none) of the following shapes:
- 2 square inches of pcb
- mounted in a DSub DE-9 backshell
- integrated with a Tyco BDS-A contactor plug
Components will be SMD's.
Attached two contemplated variations.
Any and all comments welcome.
Jan de Jong
Tycolatchingswitch.pdf |
60.61 KB |
1114 Time(s) |
60.48 KB |
591 Time(s) |
JLuckey(at)pacbell.net Guest
Posted: Tue Mar 08, 2011 10:57 am Post subject: Bistable relay control |
Jan,
I'm assuming that you are referring to the Tyco latching relays that were
discussed here a few weeks ago.
That looks like a lot of (pretty cool) engineering, but is it really
necessary? I'm thinking that a SPDT (on)- off - (on) toggle switch is all
that is really req'd to control the Tyco latching relay.
Am I missing something?
Posted: Tue Mar 08, 2011 12:51 pm Post subject: Bistable relay control |
Jeff,
You are absolutely right.
It is only when one wants to do more than switch one latching relay on
and off that it is useful for latching relays to behave like monostable
relays.
Say there are several latching relays in a system:
1. Progressive power down may be needed so that a relay has power for
switching off (can also be in a checklist)
2. It may be nice to have a handle position reflect a relay state (can
also be provided with an indicator led)
3. The system requires automation - automation has open/close outputs
and cannot be expected to provide pulses.
Jan de Jong
Jeff Luckey wrote:
Jan,
