AOA circuitry
Mike Welch
PostPosted: Fri Feb 25, 2011 11:46 am    Post subject: AOA circuitry Reply with quote
Guys,
  Just for fun, I am going to build that AOA circuit recently referred to on this list.
It's the one that uses a Hall Effect sensor, and airstream probe that has a
tiny magnet that swings past the sensor, depending on AOA (airspeed controlled).
(see enclosed attachment)
  The author refers to the Hall Effect sensor as the Allegro N503 (as well as it also
being N305, but I suspect this is a typo).  In either case, it appears that this particular
sensor may be out of production, and replaced with the A1302, and the more sensitive
A1301.  (This is just a guess on my part, because I can't seem to find out anything about
a N503, but I did find an Allegro N3503, which they say is replaced by the A1302/A1301.)
  In analyzing this circuit, can anyone identify if the Hall Effect sensor A1302, would work?
Why I be better off with the more sensitive A1301?  Are these not even the correct ones,
and there is a better choice?
  What about a magnet suggestion.  The author suggests the .374" long x.1mm x .1mm
samaruim cobalt magnet, and then lists a neomydium magnet in his list of parts.  ???
Thanks for your help,
Mike Welch
AOA_Hall_Effect_Circuit.pdf
 Filename:  AOA_Hall_Effect_Circuit.pdf
 Filesize:  722.31 KB
 Downloaded:  674 Time(s)
jimw_btg(at)earthlink.net
PostPosted: Fri Feb 25, 2011 12:54 pm    Post subject: AOA circuitry Reply with quote
Mike,
The Neodymium and Samarium Cobalt magnets are both rare-earth magnets. They are both used in Servo motor and stepper motor technology. I would believe either would work just basic supply availability.
I looked at the article as well and felt that was a typo as well. I did not compare the specs of the N35o3 to the new replacements. Take care happy building.
Jim Wickert
Tel 920-467-0219
Cell 920-912-1014
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Mike Welch
Sent: Friday, February 25, 2011 1:42 PM
Subject: AOA circuitry
Guys,
Mike Welch
retasker(at)optonline.net
PostPosted: Fri Feb 25, 2011 1:41 pm    Post subject: AOA circuitry Reply with quote
If you look at his web site, there is a new PDF for download there, which I have included. There is also a different one on the web that was presented to an EAA chapter meeting as well.
These new descriptions say to use a Honeywell SS49 for the sensor. See http://www.mouser.com/search/ProductDetail.aspx?qs=%2Ffq2y7sSKcICtUFaib78cA%3D%3D
How that compares to the one you are suggesting, I do not know. The circuit is pretty simple. It just connects the output of the hall sensor to the input of the display IC with provisions for gain and offset settings.
Dick Tasker
Mike Welch wrote:
Guys,
Mike Welch
AOA_Display.pdf
 Filename:  AOA_Display.pdf
 Filesize:  809.51 KB
 Downloaded:  593 Time(s)
AOADisplay2.pdf
 Filename:  AOADisplay2.pdf
 Filesize:  871.45 KB
 Downloaded:  1599 Time(s)
Ed Anderson
PostPosted: Fri Feb 25, 2011 2:49 pm    Post subject: AOA circuitry Reply with quote
Sounds like an interesting project, Mike
I had not seen a magnet mounted in that orientation to a Hall effect sensor previously (but, then my experience with their use is quite limited), however, it became clear (based on the graph below) that that specific orientation provides a way to determine which side of the pitot center line (air flow vector) the van is pointing based on voltage magnitude.
If VCC is 5 volts, then it looks like 2.5 volts would be VOQ - in which case, a voltage above 2.5 volts would indicate the vane was pointing in one direction (say Up relative to orientation of pitot tube)) and if voltage is below 2.5 volts the vane would be pointing to the opposite direction (say Down relative to the pitot tube). The magnitude of the voltage would then indicate the degree of variation from the reference point.
The sensitivity of both of the subtitute sensor you mentioned are in millivolt/gauss mv/g. The old sensor apparently was around 1.3 mv/g with the A1301 being more sensitive at 2.5 mv/g than the A1302 at 1.3 mv/g
The effect of substituting the more sensitive A1301 would in effect increase the voltage swing by 2.5 / 1.3 = 1.92 or almost twice the voltage swing for the same gauss strength over the less sensitive Hall sensor. This would undoubtedly call for a different calibration point in the processing circuit - but should reduce the effects of electrical noise with a higher voltage input. (See Spreadsheet graph of this effect below)
If you did not change the circuit calibration then I suspect the what you would get (without having analyzed the circuit) is that your LEDs would in effect indicate approx 1/2 the degree variation of the less sensitive sensor. In other words, you would hit the voltage limit excursion of your LED (due to the 2 times higher voltage per gauss) in about 1/2 of the angular variation of the less sensitive sensor.
[img]cid:3A5913E9902A4428A8177526CFE55E75(at)EdPC[/img]
[img]cid:963D45B0691544578B9A1BE836D56304(at)EdPC[/img]
In plotting their comparative sensitivities to magnetic field strength change I derived the above chart - so as you can see for the same magnetic field strength the A1301 gives you approx twice the voltage swing of the less sensitive 1302 sensor
So for example, at approx 2000 on the gauss scale that would give you around 2.5 volts vs almost 5 volts for the 1301. So your LED (at 5 volts output) would be maxed out at 1/2 the gauss (degree divergence?) strength of the less sensitive sensor - but, I would assume you could compensate for that in the calibration or an resistor of twice the called for value someplace in the circuit - otherwise, just go with the drop in replacement the 1302.
In any case, looks like a fun and interesting project
Good Luck with it, be interested in hear the results once you are flying with it.
Ed
Edward L. Anderson
Anderson Electronic Enterprises LLC
305 Reefton Road
Weddington, NC 28104
http://www.andersonee.com
http://www.eicommander.com
Sent: Friday, February 25, 2011 2:41 PM
Guys,
Mike Welch
 Filesize:  32.89 KB
 Viewed:  10525 Time(s)
 Filesize:  29.66 KB
Ed Anderson
Rv-6A N494BW Rotary Powered
Matthews, NC
eanderson@carolina.rr.com
Mike Welch
PostPosted: Fri Feb 25, 2011 3:58 pm    Post subject: AOA circuitry Reply with quote
Thanks for the information and pointers, Jim, Dick, and Ed!!
That updated article you shared, Dick, is much sharper and has a lot more detail.
I found some magnets on eBay that I think would be perfect for trying out, Jim.
Ed, I think you are correct about the A1302 being the better sensor (compared to
the 1301).  I'm not trying a reinvent the wheel, (completely), so I think I'll get a couple
of those 1302's and the Honeywell SS49, and compare the two.
  It'll be a couple of weeks before I can round up all the parts, but when I get something
soldered together, I'll get back to ya'll with some details, and a picture or two.
Thanks again, guys!!
Mike Welch
email(at)jaredyates.com
PostPosted: Fri Feb 25, 2011 4:38 pm    Post subject: AOA circuitry Reply with quote
I know it isn't exactly on topic for your question, but I am remembering a discussion at Oshkosh 2009 hosted by Corky Fornoff.  He was talking about the Bede jet that he and Burt were trying to get flying for a movie, and said that the feds required them to have an AOA indication.  After much head-scratching, they went with a mechanical AOA that featured a vane and a pointer on a common pivot, with the vane on the outside of the fuse and a pointer on the inside of the fuse.  With one moving part, it was about as simple as it gets.  I know you're looking for an electrical project, but it might be considering if anyone wants a simple AOA instead.
On Fri, Feb 25, 2011 at 6:50 PM, Mike Welch <mdnanwelch7(at)hotmail.com (mdnanwelch7(at)hotmail.com)> wrote:
[quote] Thanks for the information and pointers, Jim, Dick, and Ed!!
Mike Welch
ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
tp://forums.matronics.com
PostPosted: Fri Feb 25, 2011 5:32 pm    Post subject: AOA circuitry Reply with quote
voltage magnitude.
We looked at linear hall effect sensors as potential
non-contact position feedback for use in actuators.
This particular technology didn't get off the ground
due to the limited range of linear output performance
. . . combined with some temperature drift issues.
Years later, Microswitch came out with a chip that
contained a pair of magnetometers oriented 90 degrees
to each other. The output of these two devices could
be resolved into a discrete value over the full 360
degrees of magnet rotation. But these were analog
outputs that required a lot of external support hardware
and perhaps software too. A friend of mine did a proof-
of-concept potentiometer replacement using this technology.
Never found a good fit for the idea.
Then came these guys:
http://www.austriamicrosystems.com/eng/Products/Magnetic-Encoders/Rotary-Encoders
I've proposed several programs that would exploit
this technology for the purpose of replacing
rotary variable differential transformers and/or
potentiometers.
On my website at:
http://www.aeroelectric.com/Mfgr_Data/Sensors/Austriamicrosystems/
you'll find a data package on the AS5040, which is
a 10-bit encoder. There's a video that demonstrates
a portion of its functionality. I had to shoot the
video in subdued light so that the LEDs would show
up so the foreground features are pretty noisy . . .
but you get the idea.
The green LED in the center is driven by the chip's
PWM output. Note that the count goes over the cliff
at 1024 and drops to zero. The green LED appears to
go dark and comes back alive as the count increases.
There's another pair of LEDS in the upper left corner
that are warning flags for magnet mis-positioning.
You see these flash around count 910 as a result
of my clumsiness. When I pull the shaft out of the
hole to show the magnet, the display goes nuts. The
lights come on to annunciate bad data.
This chip internally decodes rotary position and
outputs it simultaneously as serial data (0001-1024)
and PWM 5V full scale with 1024 bits of resolution.
If your range of display interest spreads over say, 6
degrees. Delta-V in the PWM output is on the order
of 80 millivolts. It would take very little gain
to drive a meter movement.
At the same time, you could consider processing
serial data with something like a PIC
microcontroller. That approach could drive an LED
array directly. The 6 delta-degrees of interest
would offer a delta-count on the order of 17.
If more resolution is needed, the AS5045 would
offer 4096 bits of resolution. This wouldn't help
the PWM output except to offer finer granularity
of data. The delta-count in the digital stream
would go up by a factor of 4 to 85 counts.
These are modern parts, readily available (samples
are even free) and a whole lot more predictable
in performance than the linear hall effect devices.
PostPosted: Fri Feb 25, 2011 5:34 pm    Post subject: AOA circuitry Reply with quote
P.S.
EmagAir uses the Austriamicrosystems technology as a crankshaft
position sensor to drive their ignition timing routine.
PostPosted: Fri Feb 25, 2011 7:32 pm    Post subject: AOA circuitry Reply with quote
picture or two.
Mike Welch
I dug around in the skunk-werks inventory
and found a package of 5 AS5040 chips and some
"baby aspirin" magnets. If you'd like to
explore this technology, I can send them to
you. Also, someplace in the digital archives,
I'm pretty sure I have a layout for the ECB
that would mount these puppies and bring
the relevant leads out to a .1" space c-grid
header. Unfortunately, these critters only
come in a not too terribly friendly 16-lead
surface mount part. But once they're down
on the board, the rest is pretty straight
forward.
earl_schroeder(at)juno.co
PostPosted: Fri Feb 25, 2011 8:28 pm    Post subject: AOA circuitry Reply with quote
Hi Bob,
I've built the AOA from the kit that has been under discussion. However, I could not get full scale display
from the vane movement desired with the time I had to spend on the project and put the parts in a drawer.
Perhaps the AS5040 could be retrofitted but it probably would require more connecting wires than the
three in the original design.
I also have an AOA in the Lancair that has sensing ports in the upper and lower wing skins along with
airspeed, static air, flap and gear position inputs. This system works great and used in getting that slick
machine shoe horned in a 2200 grass strip it calls home.
If you have surplus parts after supplying the current builders, I would try to find time to experiment a bit..
Thanks, Earl
PostPosted: Sat Feb 26, 2011 12:27 pm    Post subject: Powerful magnets Reply with quote
If you have an old hard drive that you do not want, you can take it apart and remove the powerful magnets. Do not get your fingers between them!
Joe
Joe Gores
PostPosted: Sat Feb 26, 2011 1:58 pm    Post subject: AOA circuitry Reply with quote
If you want an old hard drive to take apart and don't have one, send me an email and I'll fill up a flat-rate envelope for you.
On Sat, Feb 26, 2011 at 3:27 PM, user9253 <fran4sew(at)banyanol.com (fran4sew(at)banyanol.com)> wrote:
[quote]--> AeroElectric-List message posted by: "user9253" <fran4sew(at)banyanol.com (fran4sew(at)banyanol.com)>
Joe
Joe Gores
http://forums.matronics.com/viewtopic.php?p=332155#332155
le, List Admin.
