Classic IV Weight and balance Sheet
gentryll
PostPosted: Fri Feb 04, 2011 11:17 am    Post subject: Classic IV Weight and balance Sheet Reply with quote
Where can I find a PDF version of the weight and balance sheet for a Classic IV.
Larry Gentry
Crawford, Ms.
Classic IV
dave
PostPosted: Fri Feb 04, 2011 1:39 pm    Post subject: Re: Classic IV Weight and balance Sheet Reply with quote
why not a .xls ?
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube
gentryll
PostPosted: Fri Feb 04, 2011 4:07 pm    Post subject: Re: Classic IV Weight and balance Sheet Reply with quote
Excel will be fine. Kind of got hung up on pdf's.
Larry Gentry
Crawford, Ms.
Kitfox IV
Av8r3400
PostPosted: Fri Feb 04, 2011 6:55 pm    Post subject: Re: Classic IV Weight and balance Sheet Reply with quote
Here's mine I use for my model IV...
Kitfox Weight & Balance.xls
 Filename:  Kitfox Weight & Balance.xls
 Filesize:  41.5 KB
 Downloaded:  882 Time(s)
Av8r3400
Kitfox Model IV-1200 W/912UL & IVO
Kitfox Model IV-1050 W/912UL & Warp
YouTube Videos
gentryll
PostPosted: Fri Feb 04, 2011 7:42 pm    Post subject: Re: Classic IV Weight and balance Sheet Reply with quote
Thanks, That'll get me going.
Larry Gentry
Crawford, ms.
Kitfox IV
Float Flyr
PostPosted: Sat Feb 05, 2011 7:04 am    Post subject: Classic IV Weight and balance Sheet Reply with quote
I just had a look at your W&B and found a small mistake you have the arm of
your mains located at -2.25 in.. You then added the arms instead of
subtracting them.
That makes your balance 5028 + (-2(675)inlb)/ 632lb = 5.9in
Or
5028 - 1350 = 3678inlb/632lb = 5.8in
The cell D10 should read "B10*-C10" and Cell D11 should read "B11*-C11"
I've attached a correction to the sheet.
Noel
kitfox_weight_and_balance_178update.xlsx
 Filename:  kitfox_weight_and_balance_178update.xlsx
 Filesize:  28.61 KB
 Downloaded:  765 Time(s)
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Tom Jones
PostPosted: Sat Feb 05, 2011 12:06 pm    Post subject: Re: Classic IV Weight and balance Sheet Reply with quote
I don't see that Noel. Av8r3400's weight and balance appears to be correct to me.
Tom Jones
Classic IV
Ellensburg, WA
FoxDB
PostPosted: Sun Feb 06, 2011 7:28 pm    Post subject: Re: Classic IV Weight and balance Sheet Reply with quote
Correct me if I am wrong but I believe the position of the mains is about 2.25" aft of the fwd spar leading edge. This would make the arm a positive and the first calc would be correct. The error only seems to be the (-tare) shown in the item block.
Dave
Model 1
Dave Kitfox Mod 1 582 since 95
Float Flyr
PostPosted: Mon Feb 07, 2011 4:54 am    Post subject: Classic IV Weight and balance Sheet Reply with quote
My mistake, the datum in this case is forward of both the mains and the tail
wheel.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Float Flyr
PostPosted: Mon Feb 07, 2011 5:56 pm    Post subject: Classic IV Weight and balance Sheet Reply with quote
Being that the datum is the leading edge of the plane when level you are
right... and I was wrong. For some unknown reason I considered the arm to
be not form the datum but from the CG... go figure.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
