gentryll
Posted: Fri Feb 04, 2011 11:17 am Post subject: Classic IV Weight and balance Sheet |
Where can I find a PDF version of the weight and balance sheet for a Classic IV.
Larry Gentry
Crawford, Ms.
Classic IV
dave
Posted: Fri Feb 04, 2011 1:39 pm Post subject: Re: Classic IV Weight and balance Sheet |
why not a .xls ?
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
gentryll
Posted: Fri Feb 04, 2011 4:07 pm Post subject: Re: Classic IV Weight and balance Sheet |
Excel will be fine. Kind of got hung up on pdf's.
Larry Gentry
Crawford, Ms.
Kitfox IV
Av8r3400
Joined: 22 Sep 2008 Posts: 83 Location: North Central Wisconsin (KRRL)
Posted: Fri Feb 04, 2011 6:55 pm Post subject: Re: Classic IV Weight and balance Sheet |
Here's mine I use for my model IV...
Description: |
 Download |
Filename: |
Kitfox Weight & Balance.xls |
Filesize: |
41.5 KB |
Downloaded: |
737 Time(s) |
_________________ Thanks,
Av8r3400
Kitfox Model IV-1200 W/912UL & IVO
Kitfox Model IV-1050 W/912UL & Warp
YouTube Videos |
gentryll
Posted: Fri Feb 04, 2011 7:42 pm Post subject: Re: Classic IV Weight and balance Sheet |
Thanks, That'll get me going.
Larry Gentry
Crawford, ms.
Kitfox IV
Float Flyr
Posted: Sat Feb 05, 2011 7:04 am Post subject: Classic IV Weight and balance Sheet |
I just had a look at your W&B and found a small mistake you have the arm of
your mains located at -2.25 in.. You then added the arms instead of
subtracting them.
That makes your balance 5028 + (-2(675)inlb)/ 632lb = 5.9in
Or
5028 - 1350 = 3678inlb/632lb = 5.8in
The cell D10 should read "B10*-C10" and Cell D11 should read "B11*-C11"
I've attached a correction to the sheet.
Noel
Description: |
 Download |
Filename: |
kitfox_weight_and_balance_178update.xlsx |
Filesize: |
28.61 KB |
Downloaded: |
608 Time(s) |
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Sat Feb 05, 2011 12:06 pm Post subject: Re: Classic IV Weight and balance Sheet |
Float Flyer said:
Quote: | I just had a look at your W&B and found a small mistake you have the arm of
your mains located at -2.25 in |
I don't see that Noel. Av8r3400's weight and balance appears to be correct to me.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
FoxDB
Posted: Sun Feb 06, 2011 7:28 pm Post subject: Re: Classic IV Weight and balance Sheet |
Correct me if I am wrong but I believe the position of the mains is about 2.25" aft of the fwd spar leading edge. This would make the arm a positive and the first calc would be correct. The error only seems to be the (-tare) shown in the item block.
Dave
Model 1
_________________ Dave Kitfox Mod 1 582 since 95 |
Float Flyr
Posted: Mon Feb 07, 2011 4:54 am Post subject: Classic IV Weight and balance Sheet |
My mistake, the datum in this case is forward of both the mains and the tail
wheel.
Noel
Kitfox III-A
Float Flyr
Posted: Mon Feb 07, 2011 5:56 pm Post subject: Classic IV Weight and balance Sheet |
Being that the datum is the leading edge of the plane when level you are
right... and I was wrong. For some unknown reason I considered the arm to
be not form the datum but from the CG... go figure.
Noel
Kitfox III-A
