rogwibb
Posted: Wed Jul 14, 2010 6:03 pm Post subject: Firewall Steering rod holes |
Does anyone have a good solution for plugging the steering rod holes. I've
ordered the Yamaha parts, and they were way too large (8CR-2198F). I've also
tried the inner tube rubber with a slit, but the rods are threaded the whole
way, and it just chews the rubber up. Leaving them open is an option, but not a
good one. Can anyone tell me what they are using?
Roger
Atwater, Ca.
n801bh(at)netzero.com Guest
Posted: Wed Jul 14, 2010 6:44 pm Post subject: Firewall Steering rod holes |
Is this for a 701 or an 801 ?
I thought both had the same size slots cut in the firewall.
Ben Haas
N801BH
www.haaspowerair.com
rrsharp(at)cox.net Guest
Posted: Wed Jul 14, 2010 8:57 pm Post subject: Firewall Steering rod holes |
Roger, go to matronics.com/photoshare and look for Charles F. Longs
solution, dated Dec. 23, 2007. I used his idea, which involves Jeep/Bronco
shifter boots. But I used scrap aluminum to make mounting plates and they
work well. I also used JB Weld to fill steering rod threads. If you'd
like, I have pictures of my installation.
Ralph
CH 701 N701SA
carlossa52(at)gmail.com Guest
dlorrzen701(at)earthlink. Guest
Posted: Thu Jul 15, 2010 5:41 am Post subject: Firewall Steering rod holes |
Ralph, if you don't mind please send out the pictures of your boots.
David L. Orr
sonar1@cox.net
Joined: 02 Oct 2007 Posts: 55 Location: Santa Barbara, Ca
Posted: Thu Jul 15, 2010 7:47 am Post subject: Re: Firewall Steering rod holes |
Hi Roger:
It IS a firewall, and I just don't think the rubber boots that people are using fit the purpose, other than keeping out air and exhaust.
I made some nomex boots, and just in case they weren't airtight enough (which I think they were) I coated the inside with "tent sure" (a urethane paint made for sealing tents). This is a picture from my 601 which has been sold.........Fred Sanford N9701
50.87 KB |
8652 Time(s) |
Posted: Thu Jul 15, 2010 8:53 am Post subject: Firewall Steering rod holes |
True statement Fred. My concern was carbon monoxide poisoning. Fire is a
whole different story......Ralph Sharp N701SA
Posted: Thu Jul 15, 2010 12:58 pm Post subject: Firewall Steering rod holes |
My boots are stuffed with ceramic wool. It takes 3000+ degrees to get it to burn. By that time you have lost the cowling, windscreen and any other flammable part between you and the motor.
Ben Haas
N801BH
