Tom Jones
![](images/avatars/12173518354c347421a8052.jpg)
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Thu Mar 11, 2010 5:25 pm Post subject: Brake pedal ergonomics |
My matco brakes work fine but I find the angle my ankles are in to to push on the top of the pedal with my toes is a pain. Some times after I taxi the mile back to my trailer after landing my lower legs hurt like crazy.
The adjustment is already at the top of the master cylinder push rod. I have seen a few pictures where people have attached wood blocks or put hose over the top tube on the brake pedals. I'm guessing the purpose of those is to get a better toe angle on the brakes.
Any ideas on a fix for my old man legs appreciated.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
WurlyBird
![](images/avatars/9258194324b1c82ee96309.jpg)
Joined: 16 May 2008 Posts: 207 Location: North Pole, Alaska
Posted: Thu Mar 11, 2010 6:29 pm Post subject: Re: Brake pedal ergonomics |
I sure hope there is a good solution to this one because it is in the front of m time about every time I do a landing and forget to move my feet completely off the brakes, and then have to remove my feet from the pedals to get back on the brakes when I transition to taxiing. The mechanics of these brakes really should have been re-thought somewhere between Mk 1 and however far these things went, I know at least to Mk 3.
_________________ James
Kitfox 3 / 582 / 70" IVO 2 blade GA
50 hrs on the 582 swapping for HKS 700E and Avid Cowl. |
Lynn Matteson
Posted: Thu Mar 11, 2010 7:47 pm Post subject: Brake pedal ergonomics |
I made the square blocks that are the links between the piston rod
and the fixed point (?) longer. What this did was to rotate the top
of the pedal toward me, and made my short legs reach the tops of the
pedals. It seems like I also shortened the cables, too, bringing the
whole pedal closer.
Lynn Matteson
Jabiru 2200, #2062, 876.7 hrs (since 3-27-2006)
Countdown to 1000 hrs~124 to go(135 days to go)
Sensenich 62"x46" Wood (summer)
Sensenich 55.5" x 46" Wood (winter)
Rotec TBI-40 injection
Status: flying (and learning)
brakes.
Tom Jones
Classic IV
Ellensburg, WA
http://forums.matronics.com/viewtopic.php?p=290068#290068
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
MDKitfox(at)aol.com Guest
Posted: Thu Mar 11, 2010 7:59 pm Post subject: Brake pedal ergonomics |
I have the same problem on my Model V. To angle my size 13 feet back in order to keep my toes off the brakes is difficult. On my last landing I went to put in some right rudder and ended up braking the right wheel. It was fun screeching off to the right rapidly and unexpectedly! The fix I made was to cut a one inch square of wood as wide as the pedal. I secured it with duct tape, which actually holds the world together, so I know it won't come off. I fit checked it while in the hangar, ( I now clear the brake by about ¼ of an inch) but haven't flown it. If it works, I plan to make an aluminum copy of it and bolt it to the pedal, unless of course the duct tape works out good, in which case I'll stick with it (pun intended). It reminds me when I was a kid and had blocks on the pedals because I couldn't reach them:-)
Rick Weiss
N39RW Series V Speedster, 912ULS
SkyStar S/N 1
Port Orange, FL
On Mar 11, 2010, at 9:29 PM, WurlyBird wrote:
[quote]--> Kitfox-List message posted by: "WurlyBird" <james.t.trizzino(at)us.army.mil (james.t.trizzino(at)us.army.mil)>
James
Kitfox 3 / 582 / GSC prop
The ink is still drying on my new certificate
http://forums.matronics.com/viewtopic.php?p=290072#290072
- The Kitfox-List --> &n========================
Fox5flyer Guest
Posted: Fri Mar 12, 2010 5:13 am Post subject: Brake pedal ergonomics |
Rick, I had the same problems with the toe brakes on my model II, like many others. My fix was to just keep a pair of moose hide moccasins in the airplane and change out of my shoes whenever I would fly. They enabled me to "feel" the toe brakes and solved the problem.
Deke
Tom Jones
Posted: Fri Mar 12, 2010 6:20 am Post subject: Re: Brake pedal ergonomics |
Quote: | I made the square blocks that are the links between the piston rod
whole pedal closer.
Lynn Matteson |
I had not even thought of adjusting the cables. That may be the fix for me. I have the adjustable connecting links. If that doesn't help then the blocks mentioned by a few will be my next modification.
Classic IV
Ellensburg, WA |
napierm(at)cisco.com Guest
Posted: Fri Mar 12, 2010 7:54 am Post subject: Brake pedal ergonomics |
Hey James,
The brakes on my 3 bothered me too. A fix that helps a lot is using the
KF 4 style E pedals.
On the 3 the brakes are connected to the rudder bars, not on the floor.
To make them fit you need the 4 style E pedals from the passenger
(right) side. They will fit pilot (left) side on the 3.
I had to make two mods. One is that the tube that went through the
pedal (hinge tube?) was too short so I welded on an extension. The
other was that the lower corner of the tab that connects to the brake
tended to hit the clevis so I had to grind on it some.
You could probably get Kitfox Aircraft to make you a pair: just ask them
to make the center tube a couple of inches longer than normal. You can
cut it to length with a hacksaw.
With that done you can keep your feet on the pedals without actuating
the brakes by mistake.
I did still have the issue others have mentioned. With the pedal near
the firewall you have to push hard with your toes to actuate the brakes.
The right foot is worse because I have big feet and the top of my shoe
would catch on the throttle bell-crank and cables if I didn't think to
keep that foot low.
I also adjusted the cable length to compensate for my long legs and big
butt. In the end the cockpit is large enough to keep me comfortable
even on long cross countries.
Have fun,
Mark
Time: 06:29:59 PM PST US
Subject: Re: Brake pedal ergonomics
From: "WurlyBird" <james.t.trizzino(at)us.army.mil>
front of
completely off
on
really
things
James
Joel
![](images/avatars/1202521496453c06511bb1c.jpg)
Joined: 06 Oct 2006 Posts: 57 Location: Bremerton, WA USA
Posted: Fri Mar 12, 2010 9:03 am Post subject: Brake pedal ergonomics |
I made a similar arrangement using scraps of plastic/wood decking material. Totally water and rot proof, lighter than aluminum and easier to work with.
Joel, Kitfox V 912ULS Warp
The New Busy is not the old busy. Search, chat and e-mail from your inbox
_________________ Joel Mapes Kitfox 5 912 ULS Aerocomp amphibs |
pchristensen10(at)austin. Guest
Posted: Fri Mar 12, 2010 11:40 am Post subject: Brake pedal ergonomics |
I have my idle set so that I hardly use the brakes. As a matter of fact I
flew to Oshkosh last summer and my right brake went out in route and I had
no problem waiting until I got home to fix it.
Pete
Kitfox III, 912
Leander, TX
akflyer
![](images/avatars/2137179804977e39d71c60.jpg)
Posted: Fri Mar 12, 2010 4:28 pm Post subject: Re: Brake pedal ergonomics |
http://www.avidfoxflyers.com/index.php?/topic/541-pic-request/
Good thread on the brake geometry, and what one guy has done to fix the issue. I will have a set of his pedals if I ever take the floats of and go back to wheels. As you can see in the pics that C5 posted, there is a small bar that your feet hit on to keep you off the brakes when you are trying to only use the rudder!
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
WurlyBird
Posted: Fri Mar 12, 2010 6:50 pm Post subject: Re: Brake pedal ergonomics |
Does anyone have a picture or two they can post of what they are talking about?
It sounds like some of you are saying you attached a block to the front side of the rudder pedal, which would certainly help me as I am also one of those short people, which shifts the function of the brake farther back from the seat. If this is the case is there still plenty of room to apply full brake?
Ken Potter
Joined: 18 Aug 2007 Posts: 85 Location: Lanark, Ontario
Posted: Sat Mar 13, 2010 3:59 am Post subject: Re: Brake pedal ergonomics |
I came to similar conclusions when I was installing the brakes last fall. The solution I came up with was to cut a "wedge" out of the brake pedal tubing, bend it forward until the wedge was closed and then weld the joint. The result is that the pedals sit farther forward and my toes do not touch them when my feet are on the rudder pedals.
KP
_________________ Ken Potter
Model II, No. 483
Rotax 582, C-Box,
99% Complete
C-FJKP
Lanark, Ontario |
akflyer
Posted: Sat Mar 13, 2010 7:10 am Post subject: Re: Brake pedal ergonomics |
WurlyBird wrote: | Does anyone have a picture or two they can post of what they are talking about?
It sounds like some of you are saying you attached a block to the front side of the rudder pedal, which would certainly help me as I am also one of those short people, which shifts the function of the brake farther back from the seat. If this is the case is there still plenty of room to apply full brake? |
James,
If you click the link I posted it will take you to a bunch of pics.
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
jridgway
Posted: Sat Apr 17, 2010 5:07 pm Post subject: Re: Brake pedal ergonomics |
I did not have much luck with the blocks. I am welding in a extra 1.5 inch extension to raise the brake bar. Hope to test it in the next day or so.
Jack
jridgway
Posted: Wed Apr 21, 2010 7:04 am Post subject: Re: Brake pedal ergonomics |
raising the brake arm up 1.5 inch solved my problem. makes all the difference in the world. however, they are no longer true 'toe-brakes'. You do have to lift you feet some to get on them.
