Shorting the bow tips
mustangsally(at)semo.net
PostPosted: Thu Apr 20, 2006 6:19 pm    Post subject: Shorting the bow tips Reply with quote
Has anyone shortened the bow tips on the wings of Firestar? Seems to be a lot of drag out there. Doing some measuring, 6" could be done pretty easy. That would be 12" less of nonlift producing drag gone.
Jerry
biglar
PostPosted: Thu Apr 20, 2006 6:46 pm    Post subject: Shorting the bow tips Reply with quote
Not sure about the FireStar, but a few years ago, Ron Christensen built a
much modified Kolb that he called the Mk III 1/2. It gave me several ideas
for Vamoose. There's a couple of pics of it on one of my Vamoose webpages.
He originally tried just what you're asking, and lost performance. Then he
built several variations of wingtips, including drooped, out of fiberglass.
He did a beautiful job, but finally wound up with stock wingtips, and said
they performed best. Lar.
Larry Bourne
Palm Springs, CA
Building Kolb Mk III
N78LB Vamoose
www.gogittum.com
Larry Bourne
Palm Springs, CA
Building Kolb Mk IIIC
"Vamoose"
John Jung
PostPosted: Thu Apr 20, 2006 8:41 pm    Post subject: Re: Shorting the bow tips Reply with quote
Jerry
Jerry,
I'm not so sure that the tips don't produce lift. My original Firestar had stock tips and my Firestar II has shorter tips. I suspect that they do. If I ever build new Kolb wings they will have stock tips.
John Jung
Firestar II N6163J
Surprise, AZ
Denny Rowe
PostPosted: Fri Apr 21, 2006 5:20 am    Post subject: Shorting the bow tips Reply with quote
Remember the tips are at an incline to the relitive wind, same as the rest
of the wing, they are producing plenty of lift by deflecting air downward.
Denny
jindoguy(at)gmail.com
PostPosted: Fri Apr 21, 2006 6:28 am    Post subject: Shorting the bow tips Reply with quote
As I have stated before, I'm not an engineer and this is worth exactly what
you paid for it.
All Kolb aircraft have a straight, rectangular planeform wing. For the
purposes of lift distribution in high speed cruise, it is the worst
planeform to use. For the purposes of lift distribution at stall it is the
best.
Discussing the Kolb wing tip as a lift producing device is, well, quite
frankly, the back assward view. If we could look at the airflow over the
wing starting at the root and working outboard we would see that somewhere
around 75 to 80 per cent of the way to the tip the air begins to turn, drawn
by the difference in pressure between the top and bottom of the wing, and
run spanwise down the wing. This effect becomes more pronounced as the wing
angle of attack increases. So it comes down to an inescapable conclusion.
Wing tips don't produce lift, wing tips reduce loses due to spanwise flow.
Now what is you want to do?
Do you want to land slower and shorter? Take a look at the work done by the
STOL speciality shops. To inhibit spanwise flow, they add wing fences and
wingtips with a down ward curl along the trailing edge. The benefits are
that you get to go slower AND maintain an unstalled flow over the ailerons
so they remain effective at the lower airspeed.
Do you want to go faster with very low induced drag in cruise? I hate to
break it to you, but you bought the wrong airplane. The Kolb has a boatload
of parasitic drag at all airspeeds and that is far more effective at
inhibiting its cruise performance than anything going on at the wing tips.
Even if you could clean up most of it, the Kolb would still be Vne limited.
I have no trouble at all reaching red line airspeed in my Mk III while
trying to maintain altitude in the grips of even a mild Kansas thermal.
My suggestion would be this, concentrate on the areas that will get you the
biggest bang for the buck. Streamline the lift struts, gear legs and control
tubes. Make a good sealed gap cover. Seal the gaps around all the
stabilizers and the gaps at the control hinge lines. These things can be
done very cheaply, will get you immediate benefits, and most important,
won't compromise the structure of the wing.
You will, of course, do exactly as you please.
> Jerry
Jerry,
John Jung
Firestar II N6163J
Surprise, AZ
http://forums.matronics.com/viewtopic.php?p=3D29801#29801
Rick Girard
"Pining for a home on the Range"
slyck(at)frontiernet.net
PostPosted: Fri Apr 21, 2006 6:58 am    Post subject: Shorting the bow tips Reply with quote
to
funny
Guess I knew that when I first saw a Kolb.
58 hp/65 mph , 90 hp/85 mph + a lot more petrol.
But then I'm a slow guy, happy with a slow plane.
Buy a Sonex if you want a fast, simple airplane.
I like feeling like I'm riding around the sky on a barcalounger
instead of in a sardine can.
-BB, MkIII, REALLY inefficient wingtips.
gtb(at)commspeed.net
PostPosted: Fri Apr 21, 2006 7:50 am    Post subject: Shorting the bow tips Reply with quote
My apologies to the group.
I failed to add the authors name to my last post.
It was Richard R. Ryburn <ric(at)srclink.net>
George
Kirk Smith
PostPosted: Fri Apr 21, 2006 10:09 am    Post subject: Shorting the bow tips Reply with quote
I remember a Kolb Mark3 at Oskosh that had lengthened the wings
to slow it even more so they could do hang glider tows. Now that
was neato. I'd like to see leading edge slats on one also, slow it
down to about a 15 mph flight.
Do not
archive
eagle1(at)commspeed.net
PostPosted: Fri Apr 21, 2006 10:37 am    Post subject: Shorting the bow tips Reply with quote
Been there, done that, on my Firestar II. I would not recommend it. I
thought that I would gain some speed but I could not see that it did that
but slowed the take off a bit ( Not that that hurt anything). I shortened
the bow about 8 inches on each side. In my opinion, you will not gain
anything worthwhile.
Az Bald Eagle
Possum
PostPosted: Fri Apr 21, 2006 12:50 pm    Post subject: Re: Shorting the bow tips Reply with quote
Jerry
I did - to 26'9" - I'll send some pictures. I think it works fine. I have standard Kolb Ribs (built on a wooden jig - the old fashion way) - different wing bow ...a few other things different but not with the wings though - execpt VGs.
 Filesize:  158.32 KB
 Viewed:  609 Time(s)
 Filesize:  14.01 KB
 Viewed:  578 Time(s)
 Filesize:  30.79 KB
 Viewed:  611 Time(s)
 Filesize:  48.26 KB
 Viewed:  577 Time(s)
 Filesize:  48.03 KB
 Viewed:  594 Time(s)
Thom Riddle
PostPosted: Sat Apr 22, 2006 3:50 am    Post subject: Shorting the bow tips Reply with quote
If that Hoerner Style wing tip does to a Kolb what they do for a
Cherokee, the results must be wonderful. Of course the original shape
of the Hershey bar wing tip on the Cherokee is not as good as the
original Kolb wing tip.
Thom in Buffalo
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
Dennis.Kirby(at)kirtland.
PostPosted: Mon Apr 24, 2006 12:59 pm    Post subject: Shorting the bow tips Reply with quote
<< Been there, done that, on my Firestar II. I would not recommend it. I
anything worthwhile. Az Bald Eagle >>
Here's another story that corroborates this exact point:
In the mid-90s, at the little airport I fly out of near Albuquerque, a
fellow arrived with a newly-purchased Mark-III that he bought from someone
in Arizona who built it with shortened wingtips. In the attempt to "make it
a little more agile," the builder truncated the wing at the end of the spar,
essentially eliminating the tip bow altogether.
Our hapless buyer had no Kolb experience, so he talked one of the local
ultralight instructors into doing a few test flights in the Kolb, to better
evaluate how the plane flew. This instructor was experienced, including
time in Kolbs, but he was not prepared for the drastic decrease in available
lift at low speeds in this modified Mark-3.
On the first test flight, the engine quit just after departure, at about
300' AGL. At this altitude, most normal light sport airplanes in this
weight class are able to execute a 90 degree turn and glide safely to a
landing on this airport's crossing runway. My instructor friend tells us
that, while trying to do this, it stalled at nearly 60 mph in a slight turn.
Spun it in from nearly 80 feet. Totaled the Mark-3, but he survived with
only a charley horse in his thigh.
Aside from taking away the message that you should leave Homer's wings
alone, this story speaks volumes about the crash worthiness of these Kolb
airplanes!
Dennis Kirby
Mark-3, 912ul
Cedar Crest, NM
