JOE RONCO
Joined: 04 Aug 2007 Posts: 31 Location: CENTENNIAL COLORADO
Posted: Wed Nov 04, 2009 9:34 am Post subject: Jabiru Flywheel Bolts Important Notice |
FWIW attached is a copy of the draft report on the flywheel bolt breakage by Anton Lawrence with pictures for those interested in seeing what the problem looks like.
Hope this helps.
Joe R
Jabaru_2200_Flywheel_Investigation.pdf |
2.75 MB |
2869 Time(s) |
Gilles.Thesee(at)ac-greno Guest
Posted: Wed Nov 04, 2009 11:21 am Post subject: Jabiru Flywheel Bolts Important Notice |
Joe Ronco a écrit :
| Quote: | FWIW attached is a copy of the draft report on the flywheel bolt breakage by Anton Lawrence with pictures for those interested in seeing what the problem looks like.
Anton's article can be found in HTML form at :
http://contrails.free.fr/engine_jab_flywheel_en.php
FWIW,
Best regards,
Gilles
Jim Ballenger
Joined: 12 Jan 2006 Posts: 18 Location: Virginia Beach, Virginia
Posted: Wed Nov 04, 2009 1:12 pm Post subject: Jabiru Flywheel Bolts Important Notice |
Joe
Thanks. Pictures are worth a thousands words.
Jim
Iberplanes
Joined: 10 Dec 2007 Posts: 174 Location: Igualada - Barcelona - Spain
Posted: Wed Nov 04, 2009 1:19 pm Post subject: Jabiru Flywheel Bolts Important Notice |
Hello guys,
How can we be sure If all this problems were caused by using an improper propeller? so we can rule that out. I´m planning to use a DUC Swirl propeller. I know a few guys that have used them with great success.
Bye !
Alberto Martin
www.iberplanes.es
Zodiac 601 XL Builder
Serial: 6-7011
Tail Kit: Finished
Wings: Not Started
Fuselage: Started
Engine: Jabiru 3300
_________________ Alberto Martin
601 XL - Jabiru 3300
http://www.iberplanes.es
Igualada - Barcelona - Spain |
plus2s
Posted: Wed Nov 04, 2009 2:56 pm Post subject: Jabiru Flywheel Bolts Important Notice |
Other thoughts were loose prop bolts and 4 inch prop extensions or prop extensions not true
--- On Thu, 5/11/09, Iberplanes IGL <iberplanes(at)gmail.com> wrote:
Subject: Re: Jabiru Flywheel Bolts Important Notice
Received: Thursday, 5 November, 2009, 10:19 AM
Hello guys,
How can we be sure If all this problems were caused by using an improper propeller? so we can rule that out.. I´m planning to use a DUC Swirl propeller. I know a few guys that have used them with great success.
Bye !
Alberto Martin
www.iberplanes.es
Serial: 6-7011
Tail Kit: Finished
Wings: Not Started
Fuselage: Started
Engine: Jabiru 3300
_blank rel=nofollow>www.aeroelectric.com
/" target=_blank rel=nofollow>www.buildersbooks.com
=_blank rel=nofollow>www.homebuilthelp.com
blank rel=nofollow>http://www.matronics.com/contribution
ist" target=_blank rel=nofollow>http://www.matronics.com/Navigator?JabiruEngine-List
=nofollow>http://forums.matronics.com
| [quote][b]
Peter H
Posted: Wed Nov 04, 2009 3:04 pm Post subject: Jabiru Flywheel Bolts Important Notice |
I found my engine shaking at various times (sometimes scary) depending on the power setting and I think it is caused by imbalance when mixture is distributed unevenly L to R because of the lack of a regular symmetrical induction plenum. It is also well worth getting the prop dynamic balanced. Although my prop was carefully static balanced it required 3 g weight to get a dynamic balance and now the prop is a long way from static balance. It seems to mean that we had to compensate for imbalance in the engine itself.
Peter
From: owner-jabiruengine-list-server(at)matronics.com [mailto:owner-jabiruengine-list-server(at)matronics.com] On Behalf Of Keith Pickford
Sent: Thursday, 5 November 2009 8:26 AM
Subject: Re: JabiruEngine-List: Jabiru Flywheel Bolts Important Notice
Hello guys,
How can we be sure If all this problems were caused by using an improper propeller? so we can rule that out... I´m planning to use a DUC Swirl propeller. I know a few guys that have used them with great success.
Bye !
Alberto Martin
www.iberplanes.es
Serial: 6-7011
Tail Kit: Finished
Wings: Not Started
Fuselage: Started
Engine: Jabiru 3300 | Quote: | | _blank rel=nofollow>www.aeroelectric.com/" target=_blank rel=nofollow>www.buildersbooks.com=_blank rel=nofollow>www.homebuilthelp.comblank rel=nofollow>http://www.matronics.com/contributionist" target=_blank rel=nofollow>http://www.matronics.com/Navigator?JabiruEngine-List=nofollow>http://forums.matronics.com |
0123456789 | Quote: | | _blank rel=nofollow>www.aeroelectric.com | 0 | Quote: | | _blank rel=nofollow>www.aeroelectric.com | 1 | Quote: | | _blank rel=nofollow>www.aeroelectric.com | 2 | Quote: | | _blank rel=nofollow>www.aeroelectric.com | 3 | Quote: | | _blank rel=nofollow>www.aeroelectric.com | 4 | Quote: | | _blank rel=nofollow>www.aeroelectric.com | 5 | Quote: | | _blank rel=nofollow>www.aeroelectric.com | 6 | Quote: | | _blank rel=nofollow>www.aeroelectric.com | 7 | Quote: | | _blank rel=nofollow>www.aeroelectric.com | 8 | Quote: | | _blank rel=nofollow>www.aeroelectric.com | 9 | Quote: | | /" target=_blank rel=nofollow>www.buildersbooks.com | 0 | Quote: | | /" target=_blank rel=nofollow>www.buildersbooks.com | 1 | Quote: | | /" target=_blank rel=nofollow>www.buildersbooks.com | 2 | Quote: | | /" target=_blank rel=nofollow>www.buildersbooks.com | 3 | Quote: | | /" target=_blank rel=nofollow>www.buildersbooks.com | 4 | Quote: | | /" target=_blank rel=nofollow>www.buildersbooks.com | 5 | Quote: | | /" target=_blank rel=nofollow>www.buildersbooks.com | 6 | Quote: | | /" target=_blank rel=nofollow>www.buildersbooks.com | 7
No virus found in this incoming message. Checked by AVG - www.avg.com 270.14.48/2479 - Release Date: 11/03/09 19:38:00 [quote][b]
