DanM
Joined: 16 Nov 2006 Posts: 64 Location: Kingsburg, Calif.
Posted: Sun Oct 18, 2009 8:41 am Post subject: Flaperon Rigging Problem |
Hello all--- I preparing N443DM (mod IV) for 1st flight and am having a problem rigging the flaperons!
1st-- the construction manual call out an angle of 19 to 20 deg down from horizontal on the flaperon bell crank. I also have spec sheets that says the angle should be 11 1/2 deg. I don't know which is correct.
2nd-- is the flap handle suppose to be full forward until it contacts the cross tube during the setup procedure.?
Thanks for the help
_________________ Dan Mc Intyre
Kitfox IV
Jabiru 2200 SN 1311 , 59.7 hours
Sensenich 62x46
N443DM |
Tom Jones
![](images/avatars/12173518354c347421a8052.jpg)
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Sun Oct 18, 2009 3:57 pm Post subject: Re: Flaperon Rigging Problem |
Quote: | 1st-- the construction manual call out an angle of 19 to 20 deg down from horizontal on the flaperon bell crank. I also have spec sheets that says the angle should be 11 1/2 deg. I don't know which is correct.
Dan,
from my 1994 classic 4 assembly manual, "Rigging the Flaperons":
step (16): Adjust the flap push-pull tube so the angle between the belly of the aircraft and the #15049 bellcrank is 11.4 degrees...(A "Smartlevel" is invaluable for this.)
Quote: | 2nd-- is the flap handle suppose to be full forward until it contacts the cross tube during the setup procedure.? |
Yes, that's how I rigged mine.
I also second the vote for the smart level. I rigged mine the old fashion way with a bubble level and a protractor the first time. That took me several days. I rigged it again a couple years ago with a smart level in a couple hours.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
DanM
Posted: Mon Oct 19, 2009 6:45 am Post subject: Re: Flaperon Rigging Problem |
Thanks Tom, back to the airport on Saturday to try again. I guess the sheet spec's that specify 19 to 20 degrees is a mistake???? Oh yea I have a digital smart level also.
Kitfox IV
Sensenich 62x46
N443DM |
