Flaperon Rigging Problem
DanM
PostPosted: Sun Oct 18, 2009 8:41 am    Post subject: Flaperon Rigging Problem Reply with quote
Hello all--- I preparing N443DM (mod IV) for 1st flight and am having a problem rigging the flaperons!
1st-- the construction manual call out an angle of 19 to 20 deg down from horizontal on the flaperon bell crank. I also have spec sheets that says the angle should be 11 1/2 deg. I don't know which is correct.
2nd-- is the flap handle suppose to be full forward until it contacts the cross tube during the setup procedure.?
Thanks for the help
Dan Mc Intyre
Kitfox IV
Jabiru 2200 SN 1311 , 59.7 hours
Sensenich 62x46
N443DM
Tom Jones
PostPosted: Sun Oct 18, 2009 3:57 pm    Post subject: Re: Flaperon Rigging Problem Reply with quote
Dan,
from my 1994 classic 4 assembly manual, "Rigging the Flaperons":
step (16): Adjust the flap push-pull tube so the angle between the belly of the aircraft and the #15049 bellcrank is 11.4 degrees...(A "Smartlevel" is invaluable for this.)
Yes, that's how I rigged mine.
I also second the vote for the smart level. I rigged mine the old fashion way with a bubble level and a protractor the first time. That took me several days. I rigged it again a couple years ago with a smart level in a couple hours.
Tom Jones
Classic IV
Ellensburg, WA
DanM
PostPosted: Mon Oct 19, 2009 6:45 am    Post subject: Re: Flaperon Rigging Problem Reply with quote
Thanks Tom, back to the airport on Saturday to try again. I guess the sheet spec's that specify 19 to 20 degrees is a mistake???? Oh yea I have a digital smart level also.
Dan Mc Intyre
Kitfox IV
Sensenich 62x46
N443DM
