jpx(at)Qenesis.com Guest
Posted: Wed Dec 17, 2008 7:45 am Post subject: Dual Lightspeed Ignition modules |
I plan dual electronic ignitions for my aircraft. I started with
Z13/8. As much as I expect the designers have done significant things
to ensure the ignitions work, in spite of nasty power events, I
finally decided I wanted completely isolated electrical systems, so
any problem, no matter how unlikely or unpredictable, could not
prevent continued flight. So I added a few features from Z14. I
didn't go all the way. My aux battery is very small, and driven by an
SD-8 alternator. I did not join the batteries together for extra jolt
when starting. I do have a small cross-feed relay that will allow the
SD-8 to power the essential bus if the main alternator fails.
The biggest thing I wrestled with, was how was my wife to know what
switches to throw in the event of an alternator failure ? Together we
came up with coloured lines joining the warning light and switches
that are numbered. This low voltage light goes on, then flip these
switches in this order.
You can view my power diagram and the switch layout here:
http://www.curtispriest.com/tundra/Electrical
Jeff Page
Dream Aircraft Tundra #10
| Quote: | Speaking of Hall Effect stuff, I just purchased two LightSpeed III hall
effect ignition modules. The mfg says to connect the + side of the
controller through a pull-able breaker then directly to the battery
terminal. Ok, that covers their insurance folks if I crash. On the other
hand I am using Z-13 and was thinking of using the same scenario but
connecting them to the main battery bus using an ATC fuse and skipping
the breaker. I was never a proponent of having extra wires hanging off
the + side of the battery terminal. AS in Z-13 I will have a switch to
turn them on/off as necessary.
Has anyone wired up two of these and which method did you use.
Glenn
andrewbutler(at)ireland.c Guest
Posted: Thu Dec 18, 2008 5:00 am Post subject: Dual Lightspeed Ignition modules |
Hi Jeff,
I also plan on dual electronic ignition and my original design was practically identical to yours. This was when I was looking at Dual Plasma III Ignitions. Then I switched to dual P-MAGS. Reason? Simplicity and internal power. At this point I couldn't reason that the added complexity of the dual battery split bus was justified, and ended up removing the second battery from the design.
Both the designs are attached, the dual alt, dual batt dating from April. The current design is more or less finished.
Any takers of critiquing it for me?
The originals are in Visio. If anyone wants a copy, let me know.
Cheers, Andrew.
Dual_Alt_-_8Amp_Backup_-_Split_Bus.pdf |
765.66 KB |
546 Time(s) |
Dual_Batt_&_Alt_-_8Amp_Backup_-_Split_Bus.pdf |
295.41 KB |
447 Time(s) |
mlas(at)cox.net Guest
Posted: Thu Dec 18, 2008 10:03 am Post subject: Dual Lightspeed Ignition modules |
Andrew,
My two cents! I have personally seen more EMAG/PMAG failures then total
electrical failure in single bus electrical systems (Z-11). Add a
secondary battery (Z-19) and the statistics improve for a plasma system
vs. EMAG/PMAG. Remember during a major electrical failure (for what
ever reason) the Plasma systems only need, is a good battery for more
flying time then the airplane will hold fuel. The EMAG/PMAG product has
had more then it's fair share of field testing failures by the customer.
A customer that didn't realize they were test subjects. Just my opinion
viewed with actual 1st party data not 3rd!
Mike Larkin
Posted: Thu Dec 18, 2008 10:09 am Post subject: Dual Lightspeed Ignition modules |
Glenn,
The reason for wiring the Lightspeed Plasma systems directly to the
battery is to prevent engine failure should you experience a bus failure
(a bus short, over voltage, or heavy drain buy a runaway device. The
object is that you could simply shut off all electric and continue to
fly (powering the Lightspeed system directly from a battery). If you
wire the Plasma system to the bus, you would become a glider in the
event of an electrical problem. In my opinion the Lightspeed dual
system requires two batters in the airplane period. Anything less will
only serve to help you glider logbook.
Mike Larkin
rv9jim(at)juno.com Guest
Posted: Thu Dec 18, 2008 11:28 am Post subject: Dual Lightspeed Ignition modules |
Mike,
How many failures do you know about with the E-Mag, P-Mag
ignitions? How many failures of magneto ignitions have occured in the
same time? Other ignitions of various configurations. Fact vs: opinion
is very important. Nothing is perfect. The main reason we all use dual
ignitions is for safety. It also gives us better fuel burn.
Jim
Live the good life! Click now for great retirement planning assistance!
http://thirdpartyoffers.juno.com/TGL2141/fc/PnY6rw1hgimeim0pl7I4CFc1o21Xu2lJFNyMywOmmFBAAdKspEJHz/
jbr79r(at)yahoo.com Guest
Posted: Thu Dec 18, 2008 12:13 pm Post subject: Dual Lightspeed Ignition modules |
I have been using dual Lightspeed ign for about 300 hrs on my Glll with no problems.
Jim Robinson
Glll N79R
--- On Thu, 12/18/08, James H Nelson <rv9jim(at)juno.com> wrote:
[quote]From: James H Nelson <rv9jim(at)juno.com>
Subject: Dual Lightspeed Ignition modules
Date: Thursday, December 18, 2008, 12:23 PM
[quote]--> AeroElectric-List message posted by: James H Nelson
Mike,
is very important. Nothing is [quote][b]
Posted: Thu Dec 18, 2008 12:27 pm Post subject: Dual Lightspeed Ignition modules |
At 12:06 PM 12/18/2008, you wrote:
Glenn,
How do those feared risks occur?
How do you get a shorted battery bus failure? How does
connection directly to the battery protect against
an overvoltage condition? What matter of "runaway
device" can you imagine that brings the entire system
to its knees? As long as we're in the free-ranging
imagination mode, how about bursting batteries,
open batteries, etc. etc.
It's easy to hypothesize about all manner of failure
but the acid test is the repeatable experiment. Get
any combination of implements you choose and MAKE
one of those events happen. If it can happen accidently,
then you can make it happen. If it's exceedingly
difficult or impossible to MAKE it happen, then concerns
for accidental events go away. The physics of events do
not change for random versus purposeful failures.
Suppose your engine is also dependent upon electrically
delivered fuel? The path to Nirvana is more than hooking
certain accessories directly to the battery with some
notion of fending off nargles. Failure Mode Effects
Analysis is a science and exercise in logic that has
served aviation (and others) very well for 100+
years.
Making sure the electrically dependent engine is not
left in dark has been discussed here on the list for
over ten years. These discussions have included consideration
of auxiliary batteries both manually and automatically
controlled.
http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z29-30K.pdf
http://www.aeroelectric.com/articles/bat_iso2.pdf
http://www.aeroelectric.com/Catalog/AEC/9005/9005-701B.pdf
There are well considered rationale for dual
accessories and power sources that do not concern
themselves with the statistically improbable or
physically impossible failure. These were the thought
processes that went into crafting Z-19 for certain
kinds of engines.
http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z19m_1.pdf
http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z19m_2.pdf
Let us not get bogged down with concerns about why
and how to tie multiple wires to the battery(+) post.
There are tried and well tested ways to architecture
and fabricate an electrical system that grow out
of confidence of understanding as opposed to nostrums
that arise out of fear.
frank.hinde(at)hp.com Guest
Posted: Thu Dec 18, 2008 12:36 pm Post subject: Dual Lightspeed Ignition modules |
I would agree..There have been a handful of failures, some of those were serious where the E/Pmag lost its timing reference.
There were two reasons for this..One was where the firmware would see a false pressure spike and would then revert to its factory default timing..This was fixed a while ago and seems to have not re-occured.
The other reason was because the magnet was shifting on the end of the shaft. There have been several fixes for this but I believe the lastest one has finally got it. The magnet is now silver soldered on the holder and the holder is keyed to the end of the shaft.
Now of course this latest revision does not have that many hours on it so by default its unproven over the long term but it sure looks like a robust solution.
I have over 300 hours on an E/Pmag combo and did have some early teething troubles. I know have the latest fixes and feel quite comfortable flying behind them.
Frank
dale.r(at)cox.net Guest
Posted: Thu Dec 18, 2008 2:46 pm Post subject: Dual Lightspeed Ignition modules |
FWIW dept.
Marc Zeitlin documents the saga of his experiences, 2004 - 2008, with
the product line.
http://www.cozybuilders.org/Emagair_Warning/index.html
Dale R.
COZY MkIV #0497
Ch. 12
James H Nelson wrote:
Mike,
Jim
jack.byrne(at)bigpond.com Guest
Posted: Thu Dec 18, 2008 3:35 pm Post subject: Dual Lightspeed Ignition modules |
Dale wrote
| Quote: | FWIW dept.
Marc Zeitlin documents the saga of his experiences, 2004 - 2008, with the
product line.
And then there is the silent majority that are happy with their PMAG.
Yes some people have had problems, and there have been teething problems.I
have had to send mine back for an update.
But I haven't had any problems with mine. I only have 90 Hrs on them but
many others have 100's of hours on theirs.
Just to balance the argument.
Chris Byrne
Posted: Fri Dec 19, 2008 2:36 am Post subject: Dual Lightspeed Ignition modules |
Hi Mike,
Thanks for this. All two are welcome, as they help build a big picture of all sides of those coins.
I am aware of the issues with the P-Mags (magnets and the like) and this is why I have decided to wire up for dual P-mags, but only install one. This will still give me most of the benefits of the e-ignition, while allowing me to rest easy with regards any gremlins that might exist. I'll let the Slick MAG do its thing and see how things are in a couple of years with regards replacing it............
Cheers, Andrew.
Posted: Fri Dec 19, 2008 5:07 am Post subject: Dual Lightspeed Ignition modules |
Lets see, a tool across the bus, or direct short from a chafed wire, the
loss of the ground bus on a composite airplane just to name a few.
I have a story from a dark and stormy night where the air conditioner
started to break down and started to draw over 150 amps and caused both
Gen's to go off line and pull the volts down to about seven volts. The
CB didn't trip, everything just went almost completely dark before we
got the air conditioner off. Then we were able to restore power. The
problem, if we couldn't shut the Air conditioner off or couldn't figure
out the problem in time (if this airplane had a battery powered ignition
system) the engine would have failed, where simply turning the bus off
would have restored the engine or maybe even had enough voltage at the
battery to keep the engine running. Oh, the airplane referenced was a
certified airplane.
Bob, I sometime wonder if you fly or are around flying. This isn't a
hypothesis; it's based on real people in real airplanes. The fact is
that electrical systems fail with regularity, some worse then others.
An engine failure on top of that in many cases is a near death
experience. Loosing the engine is not the same as loosing the
transponder. Why do we use vacuum or backup batteries to power
important instrument systems? Don't you think the ignition system
deserves the same respect?
years.
It's not! In aviation failures that occur in the field are often not
reported. Airplanes with electrical systems have been around for less
the 100 years and electronic ignitions in aviation much less. We are
all inventing new system designs that are not able to accept total
failure of the total system.
controlled.
Yes, but not everyone has been here for 10 years and most of the
products and concepts haven't been either.
Mike
10/27/2008 7:57 AM
Posted: Fri Dec 19, 2008 6:20 am Post subject: Dual Lightspeed Ignition modules |
I have had direct interaction with four EMAG/PMAG airplanes where the
airplane was unflyable (loss of power in flight, or would not run on the
ground). I have seen many more mag failures but I have not seen both
fail at the same time making the airplane unflyable. I have also seen
one failure on the Lightspeed system but never a dual failure. Some of
the EMAG failures may have been isolatable in flight causing a single
failure on a dual system vs. the dual failures that caused landing out
or not running at all.
Mike
echristley(at)nc.rr.com Guest
Posted: Fri Dec 19, 2008 6:37 am Post subject: Dual Lightspeed Ignition modules |
Mike wrote:
| Quote: | Making sure the electrically dependent engine is not
controlled.
That statement shows a lot of insight, Mike. As the technology we use
evolves, some things that were critical become secondary, and some
things that were minor become critical.
With respect to electrically dependent (ED) engines, I think we can boil
all the concerns down to three things that the engine must have to keep
running: air, fuel, and spark. A bulletproof system will have full
redundancy across all three.
Redundant air is generally provided by some sort of flapper valve or
some such thingy to get around a clogged air filter, but the biggest
problem with air is carb icing. This is one area where electronic
injection shines. A significant portions of accidents occur when a carb
ices up where the fuel is evaporated into the air. EI moves the
evaporation location closer to the combustion location, where there is
more heat to keep the ice from forming. Icing is still possible, just
less so. Either way, methods for avoiding cutting off the air supply
look the same for all types of engines.
Redundant fuel is harder for ED engines. Fuel pumps are hard working
devices that are reliable, but do not have infinite lifespan, and it
depends on a lot of upstream stuff to work. A backup pump only backs up
the pump. For it to be a true alternate system, you have to backup
everything, up to and including the power generation source. Even with
a second pump, I chose to go low tech and provide a gravity fed drip
line to the air intake with a needle valve control. I would never be
able to get the engine started with this on the ground...and I'd never
want to. Control is slow and unresponsive, but it will get me to the
nearest airport. It is meant as a backup to keep the fan turning in an
emergency. This would work for any engine. Low wing aircraft would
need a header tank higher than the engine. The vast majority of
aircraft being built in garages today could stay straight and level for
an hour with 5gal of fuel, and travel nearly 100 miles. At a time when
everything is going that badly the only place you should be trying to
get to is 'nearest'. High wing aircraft would be able to run the tanks
dry with this method.
The spark is also more difficult for ED. Airplane engines are designed
with two independent, self contained spark producers. Each mag has a
generator, a distributor and coil all in one tidy package. You just
have to bolt them on and plug them in. Moving to ED generally means
that you're breaking the generator and spark producer apart. Most
designs have two spark producers, but combine the generators into one,
and depend on the battery for backup. Again, this isn't really
redundancy. My design calls for using two EDIS modules (self-contained
electronic ignition controller used by Ford), and converting the old
distributor to a generator. One EDIS module runs off ship's power. The
other is powered by the tiny generator (less than 5 amps) that was once
the distributor. If I lose ship's power, the secondary ignition will
keep right on going. The two are completely independent.
So Mike is correct. New products call for new thinking...but the
thinking really goes back to the same basic principles. The engine must
have air, spark and fuel. Backup systems must be able to deliver
without depending on the primary system. It is best to assume that the
primary system doesn't exist AT ALL when designing the backup. There's
a lot of new under the sun....just it's not, really.
longg(at)pjm.com Guest
Posted: Fri Dec 19, 2008 9:39 am Post subject: Dual Lightspeed Ignition modules |
Mike and Bob,
Thank you both for your input. I have emailed with Jeff P. and I've
decided a second battery (even a small 4.5 ah job) would be a good idea
as an independent source for keeping at least one ignition going even if
I shut down the power completely and simply had to fly home with just
the engine.
Mike, as you indicated that is the reason Lightspeed likes it wired
directly to the battery. Depending on a bus which is behind a solenoid
is asking for trouble. Yes, I've replaced more than one solenoid on
aircraft in the field and fortunately with mags there was no dependency.
FYI, stealing a solenoid off the FBOs old pick-up truck works in
airplanes too. Parts do fail, but only when you're flying - funny that.
The Lightspeed draws little power and I only need 1-2 amps to find a
landing spot. It may be that I install it inside the cabin and keep it
charged just as a backup. A big part of the process is monitoring and
recognizing when the system is acting up and when (and how) to shut it
down - that's process. I have done enough flying in the dark to realize
the importance of a backup something.
Thanks to all for the diagrams and discussion.
Glenn
Posted: Fri Dec 19, 2008 11:43 am Post subject: Dual Lightspeed Ignition modules |
At 07:01 AM 12/19/2008, you wrote:
. . . and are these all not manifestations of poor
craftsmanship or maintenance? If we're going to add
band-aids to any system that go to offsetting sub-standard
behavior by someone who has touched the airplane . . . where
does it end?
| Quote: | I have a story from a dark and stormy night where the air conditioner
certified airplane.
. . . and what did you learn from this or any other story
that would give you pause for evaluating your own project?
Are there things that could or should have been done in
the original design processes that would have prevented this
incident? Suppose your RV doesn't even HAVE a piece-of-(at)#$(at)#
air conditioner.What is the value of taking one incident where
the designers/fabricators/maintainers/operators stubbed there
collective toes and then levying new requirements on ALL
airplanes that work-around the SYMPTOMS of that one case?
| Quote: | Bob, I sometime wonder if you fly or are around flying. This isn't a
My career in aviation began in 1955 when I helped
an uncle install an MANUAL direction finder loop in
his 170. He could put holes in the airplane but couldn't
read a diagram or solder. I was 12 years old.
I retired from Hawker-Beechcraft 18 months ago as the
subject matter expert leader in electronics/electrical
systems. I'm still contracting to that organization and
several others who specialize in aviation design and
production.
I'm an 1000 hour private pilot with about that many
additional hours as a test engineer on TC aircraft
and 50 times that time as a designer, qualifier and
troubleshooter of airborne systems. I'm now 66 years
old and still in the business.
| Quote: | It's not! In aviation failures that occur in the field are often not
Agreed. But just as fuel flow under all anticipated
flight conditions was the big stumbling block for
many a designer 70 years ago, we have a new
challenge that isn't any different. Just as there's
no excuse for total failure of fuel flow, there is
NO EXCUSE for total failure of an electrical system.
Yeah, it has happened which means there's a REASON
but there is still no excuse.
| Quote: | Yes, but not everyone has been here for 10 years and most of the
Just because it is new doesn't mean that the
thought processes and fabrication techniques
for airworthiness are any different than what
has worked well for decades.
Suppose we consider an RV with a piece of (at)#$(at)
air conditioner with a failure mode that sucks down
the entire system? Of what value is it to tie
one or both systems directly to the (+) battery
post? Which is better, refine the A/C design or
add weight, complexity, cost-of-ownership to offset
the possibility that the A/C causes an unhappy day
in the cockpit?
On a related topic. Lots of folks are trying to figure
out ways to integrate lithium-ion batteries into
aircraft. It's no mean task. While the energy/weight
radio of l-ion is seductive, it's sorta like figuring
out a way to burn nitro-glycerine in your engine. Wow!
What energy potential! Now, how do you integrate
this potential into an existing, highly refined system
in a way that does not increase risk?
There are people who worry a lot about things
they don't understand. There are people who are
paid to worry a lot about things they presumably
understand and use force of law to modify our
behavior such that THEIR worries are mitigated
. . . all in the name of 'safety'.
http://www.hsegroup.com/hse/text/caffiene.htm
http://aeroelectric.com/Pictures/Misc/Cowboy_after_OSHA.jpg
My point about your posting was that it tended to
reenforce the notion that there was a valid WORRY
to be address without adding understanding.
An understanding of design for failure-tolerance,
craftsmanship, maintenance and operation such that
worries go away.
There are few suppliers to aviation that have a
working knowledge of low-risk, light-weight, failure-
tolerant system design. If we attached every worry-wart's
product to the battery(+) post . . . it's easy
to see where that idea leads!
Posted: Mon Dec 22, 2008 9:20 am Post subject: Dual Lightspeed Ignition modules |
Ah, good point Bob. I think as long as aircraft and human nature exist,
there is no end. One gets the impression that by introducing new
technology we somehow lesson our faith in its reliability.
I embrace new technology, but I don't want to have to build a
triple-redundant system on the chance it may take a bow. The goal of
simplicity with reliability should still be enforced.
Glenn
mjpereira68(at)gmail.com Guest
Posted: Mon Dec 22, 2008 2:05 pm Post subject: Dual Lightspeed Ignition modules |
| Quote: | On a related topic. Lots of folks are trying to figure
Oh good lord, li-poly batteries are awesome for *model*
aviation. I hope the manufacturers you're alluding to are
considering the "A123 Systems" type chemistry batteries (which
will take abuse without emiting a napalm like lithium/cobalt
fog).
Terry Watson
Joined: 09 Jan 2006 Posts: 290 Location: Seattle, WA USA
Posted: Mon Dec 22, 2008 2:59 pm Post subject: Dual Lightspeed Ignition modules |
Here is something from the archives. I think it followed a poll where Bill
Dube was asking how many of us would be interested in a really good aircraft
battery at a relatively high price:
Sep 07, 2007 From: Bill Dube <William.P.Dube(at)noaa.gov> Subject: Re:
A123 Systems Nano-phosphate technology and aircraft
(was: KillaCycle on Dish Net Tonight)
Whomever is designing the electronics doesn't have real experience with
A123 Systems cells. They think they are dealing with conventional Li-Ion
cells, and they are wrong.
A123 Systems nano-phosphate cells are quite different than other
Li-Ion cells. They will take a LOT of abuse. About the same amount as an
AGM. It is straightforward to make a drop-in replacement for a 12 volt
(or 24 volt) lead-acid battery using A123 Systems cells. The existing
charging system will work just fine. (It must have the voltage set
somewhere between 13.5 and 14.8 volts.)
In an airplane, you would want a warning that alerted the pilot that
the system was going over 14.8 volts and would make noise if the system
was going over 15 volts. It would also be useful to know if the battery
temperature was going over 80 Celsius. (You can go up to about 100 C
without damage, but no higher or you risk venting the cells and damaging
the plastic separator.)
>>> Case study <<<<
I have had a 3.5 lb A123 Systems battery running in my completely
unmodified GMC van for the past 7 months. It snaps the engine over much
better than the original 35 lb lead-acid battery.
Let's talk about abuse. My wife left my van door unlocked and
someone rifled my glove box and left it open with the light on. This
killed the battery and it sat at ZERO VOLTS for over a week. I thought,
"So much for THAT battery." I then decided to do what the typical
consumer would do and I connected up the 3.5 lb completely dead battery
to a fully-charged car battery with jumper cables. Hundreds of amps
flowed and slightly warmed the cables. I waited a couple of minutes for
the 3.5 lb battery voltage to come up, disconnected the jumper cables
(the worst thing you could do) and cranked up the van. It started
instantly. The alternator then gave the 3.5 lb battery ~100 amps until
it came up to 13.4 volts and then tapered off. The BMS showed that all
the cells were still in balance!
This was five months ago. I haven't capacity-tested the battery, but
I can't tell the difference in cranking performance. It was just as if
nothing had happened. I even left it parked for 5 weeks while I was out
of town and it cranked right up without a problem.
If you were to torture a conventional Li-Ion battery like this, it
would have burst into flames, or at least it would have just burst. I
tell this story to folks with years of experience with conventional
Li-Ion cells and they cringe when I get to the part about the jumper
cables.
The A123 Systems cells will, indeed, "take the abuse". I have a very
simplistic charge-balancing electronics (BMS) on my GMC van battery.
Nothing fancy is needed.
If you overcharge them grossly, they will vent a small amount of
flammable vapor (like paint thinner.) If there is an ignition source,
this vapor could catch fire. The cells can also burst if overcharged
severely. That is the extent of the hazard this technology presents.
Bill Dube'
