Panel lettering
wjones(at)brazoriainet.co
PostPosted: Tue Oct 07, 2008 10:50 am    Post subject: Panel lettering Reply with quote
Hello group ,I have just come up with a bright (cheap for me ) idea .I am in the process of completing my instrument panel .I only need a few white on clear labels to identify a few things like flaps, trim ect. Instead of me buying a Brother P label maker for a one time use is there someone on the site that has gone this way before me that may have the equipment to make me a few labels .If so I can sent a list of what I need . Thanks
Wade Jones South Texas
601XL Franklin 0-235
pavel569
PostPosted: Tue Oct 07, 2008 11:10 am    Post subject: Re: Panel lettering Reply with quote
I like the idea of using a inkjet water slide decals. It is inexpensive and you can do pretty much anything you want with your drawing software and inkjet printer. Print it, then thin coat of lacquer, cut out of the sheet and you're done. If you don't like the look, just spray water over it and you can remove it without any trace.
Pavel
CA
Zodiac 601XL
Stratus Subaru EA-81
Tail, flaps, ailerons, wings, fuselage, canopy done ...
"do not archive"
TxDave
PostPosted: Tue Oct 07, 2008 12:08 pm    Post subject: Re: Panel lettering Reply with quote
Hi Wade,
You might check with a local print service like Staples, or Kwik Copy and see if they can make your labels.
I like Pavel's idea for the decal paper. You could make a ton of labels on a single sheet of paper using your computer and inkjet printer. Thanks for the info, Pavel.
Dave Clay
Temple, TX
pavel569
PostPosted: Tue Oct 07, 2008 12:22 pm    Post subject: Re: Panel lettering Reply with quote
It is not my idea, I'm not that smart, unfortunately. There is an article about a panel lettering in the last issue of Kitplanes Magazine.
Pavel
CA
Zodiac 601XL
"do not archive"
davgray(at)sbcglobal.net
PostPosted: Tue Oct 07, 2008 1:33 pm    Post subject: Panel lettering Reply with quote
Pavel
I think this works for most colors except for white on clear. The P-touch
brother label maker can make this combo but this tape is not offered in most
stores. It can be found on the net.
Gary Ray
jaybannist(at)cs.com
PostPosted: Tue Oct 07, 2008 2:05 pm    Post subject: Panel lettering Reply with quote
Wade,
Tell me what size letters you want and the words you want. I'll get them to you.
Jay in Dallas
PostPosted: Tue Oct 07, 2008 2:29 pm    Post subject: Panel lettering Reply with quote
Thanks Jay ,I have maybe missed some of what I need but I think for now this will do .If you think of anything else please send .How are you recovering from your latest mishap .Have you started thinking in a more positive manner regarding your future flying ,I hope so .With your new plane waiting I would think you would be chomping at the bit to fly it . Thanks .My Address is:
Wade Jones
  P.O. Box 1596
  Brazoria Tx. 77422
Insturment_labels.doc
 Filename:  Insturment_labels.doc
 Filesize:  19.5 KB
 Downloaded:  430 Time(s)
PostPosted: Tue Oct 07, 2008 2:42 pm    Post subject: Panel lettering Reply with quote
Hello group ,thanks for all the good responses on the panel lettering .Looks
like Jay is going to take care of me.What a group. Thanks
again
