t.j.vanduin(at)gmail.com Guest
Posted: Tue Oct 07, 2008 1:22 pm Post subject: Allegro 2000, cracked gear leg |
Thom,
Thank you for your explanation about how you replaced the gear legs of the Allegro 2000.
It's very reassuring that one doesn't need to be a magician to do the job.
After I found the Matronics Allegro list, I started to read all emails and read also your mail about the gear leg cracks. Then I checked my plane and found a crack at the same position as you described. I'm not pleased that I saw the crack, but very pleased that you rang the bell! On my behalf, thanks for all your contributions to the Allegro list!
Theo van Duin
| - The Matronics Allegro-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Allegro-List |
hgmckay
Posted: Tue Oct 07, 2008 2:21 pm Post subject: Allegro 2000, cracked gear leg |
Theo
How many hours are on your 2001 Allegro 2000 airframe? Do you think you will be able to get enough dimensions duplicate the shape of your panel? If you don’t, I can send you a full size hard copy of the early working drawings I made in laying out my instruments. That full size drawing has the outline of the aluminum panel and the location of the 10 holes for attaching the panel to the dash. You can just trace the outline on a new aluminum sheet. Unfortunately I would have to send it to you via “snail mail”, but I would be willing to do so if you need it.
Hugh McKay
From: owner-allegro-list-server(at)matronics.com [mailto:owner-allegro-list-server(at)matronics.com] On Behalf Of theo van duin
Sent: Tuesday, October 07, 2008 5:23 PM
To: allegro-list(at)matronics.com
Subject: Allegro 2000, cracked gear leg
Thom,
Theo van Duin
Quote: | http://www.matronics.com/Navigator?Allegro-List | 0123456789
Checked by AVG - http://www.avg.com
10/7/2008 9:41 AM
Posted: Wed Oct 08, 2008 1:52 am Post subject: Allegro 2000, cracked gear leg |
Hugh,
According to the records my 2001 Allegro 2000 has 140 hours on airframe and motor.
The airplane did not fly at all for more than two and a half years because of incapability of the former owner. The plane suffered more from hangering than from flying.
I don't think I'm able to get the dimensions from my plywood instrument panel with
sufficient accuracy, while the panel is still on the plane. I would be very pleased to recieve a full size hard copy from you by mail. This would be a great help to me.
Could you give me an indication about the thickness of the alu panel?
My address in France: Theo van Duin
Les Cargeots
71550 Cussy en Morvan
France
Thank you so much for your help,
Theo
2008/10/8 Hugh <hgmckay(at)bellsouth.net (hgmckay(at)bellsouth.net)>
Theo
How many hours are on your 2001 Allegro 2000 airframe? Do you think you will be able to get enough dimensions duplicate the shape of your panel? If you don't, I can send you a full size hard copy of the early working drawings I made in laying out my instruments. That full size drawing has the outline of the aluminum panel and the location of the 10 holes for attaching the panel to the dash. You can just trace the outline on a new aluminum sheet. Unfortunately I would have to send it to you via "snail mail", but I would be willing to do so if you need it.
Hugh McKay
From: owner-allegro-list-server(at)matronics.com (owner-allegro-list-server(at)matronics.com) [mailto:owner-allegro-list-server(at)matronics.com (owner-allegro-list-server(at)matronics.com)] On Behalf Of theo van duin
To: allegro-list(at)matronics.com (allegro-list(at)matronics.com)
Thom,
Theo van Duin
hgmckay
Posted: Wed Oct 08, 2008 10:47 am Post subject: Allegro 2000, cracked gear leg |
Theo:
I am sending you a full size hard copy of an early working drawing showing the layout of my instrument panel. The outline of the edge of the aluminum panel is colored in yellow. You should be able to cut the paper along this line and have a template for the outer edge of the panel. As a precaution I would suggest that after you remove your old panel, you carefully transfer the location and size of the existing attaching holes on your panel and dash to the new aluminum panel. Your holes may be different in size and location than what is shown on my drawing. However, the panel outline should be the same. Just check everything before you cut the new aluminum sheet. It the moment I can’t give you the thickness of the aluminum sheet used for the panel because my panel is mounted in my airplane. However, I will get the thickness and notify you via email before you get the drawing.
With regards,
Hugh McKay
Sent: Wednesday, October 08, 2008 5:53 AM
Subject: Re: Allegro 2000, cracked gear leg
Hugh,
Les Cargeots
France
Theo
Theo
Hugh McKay
Thom,
Theo van Duin
Quote: | http://www.matronics.com/contribution |
0123456789 Quote: | http://www.matronics.com/contribution | 0 Quote: | http://www.matronics.com/contribution | 1 Quote: | http://www.matronics.com/contribution | 2 Quote: | http://www.matronics.com/contribution | 3 Quote: | http://www.matronics.com/contribution | 4 Quote: | http://www.matronics.com/contribution | 5 Quote: | http://www.matronics.com/contribution | 6
10/8/2008 7:01 AM
