BRS engine mount firewall attachment drawing?
sky_ranger161
PostPosted: Sat Jun 21, 2008 6:42 am    Post subject: BRS engine mount firewall attachment drawing? Reply with quote
Hi guys,
I'm at the point of attaching my new-style BRS engine mount brackets to the firewall. Has anyone seen a drawing that specifies number, type, and placement of bolts, etc? I searched the archives and the BRS site - no luck with the new Zenith mounts. I'll check with Zenith if there's not one out there and post it here.
Thanks in advance.
Debo Cox
Nags Head, NC
Scratchbuilding XL/Corvair
www.mykitlog.com/debo
Iberplanes
PostPosted: Sat Jun 21, 2008 8:35 am    Post subject: BRS engine mount firewall attachment drawing? Reply with quote
Hi there,
I only have the installation manuals for the one that ZAC recommends. Whats´the difference with this new one? Any website to check it out?
Thanks ,
Alberto Martin
www.iberplanes.es
Igualada - Barcelona - Spain
Zodiac 601 XL Builder
Serial: 6-7011
Tail Kit: Finished
Wings: Not Started
Fuselage: Ordered
Engine: Jabiru 3300 comming home!!
Alberto Martin
601 XL - Jabiru 3300
http://www.iberplanes.es
craig(at)craigandjean.com
PostPosted: Sat Jun 21, 2008 9:08 am    Post subject: BRS engine mount firewall attachment drawing? Reply with quote
The revised 6B6 dated 8/7 shows the details of the triangular top motor
mount bracket. I've attached the copy Caleb at ZAC sent me.
-- Craig
6-B-6.pdf
 Filename:  6-B-6.pdf
 Filesize:  103.19 KB
 Downloaded:  859 Time(s)
sky_ranger161
PostPosted: Sat Jun 21, 2008 9:35 am    Post subject: BRS engine mount firewall attachment drawing? Reply with quote
Craig!
This is perfect. Exactly what I was looking for. Thanks very much. This is why I stay on this list. You da man.
Debo Cox
Nags Head, NC
--- On Sat, 6/21/08, Craig Payne <craig(at)craigandjean.com> wrote:
[quote] From: Craig Payne <craig(at)craigandjean.com>
Subject: RE: BRS engine mount firewall attachment drawing?
Date: Saturday, June 21, 2008, 1:08 PM
me.
-- Craig
PostPosted: Sat Jun 21, 2008 9:54 am    Post subject: BRS engine mount firewall attachment drawing? Reply with quote
I hope the horizontal angle of the firewall to the upper longeron matches
that of the bracket. Otherwise you will have to trim the bracket like I did.
Or maybe you welded your own.
Also be careful to stagger the bolts through the bracket and the longeron
relative to the rivets that hold the side skins to the longerons. Otherwise
you may find it difficult to get the nuts and washers on the bolts (and get
a socket on them) due to interference with the "bulge" of the pulled rivets
inside the fuselage. But my installation was probably more complex than
yours since I was retrofitting the new style mounts dues to manufacturing
mistakes in my QBK.
-- Craig
Martin Pohl
PostPosted: Mon Jun 23, 2008 9:35 am    Post subject: Re: BRS engine mount firewall attachment drawing? Reply with quote
And here are some drawings of the BRS-installation for Europe's CH601XL ULM. I got them from Nick Heintz/Zenair Europe.
Does anybody know if the AMD BRS-installation is with softpack in front of the instrument panel (behind the firewall) or in the fuselage baggage compartment?
I will install a Galaxy GRS6-600 in my XL (similar to Scott's BRS-setup).
Cheers Martin
Zenair ULM supplement 22 pages.pdf
 Filename:  Zenair ULM supplement 22 pages.pdf
 Filesize:  1.96 MB
 Downloaded:  884 Time(s)
Martin Pohl
Zodiac XL QBK
8645 Jona, Switzerland
http://www.pohltec.ch/ZodiacXL/Main.html
