Elevator Trim tab motor
Thruster87
PostPosted: Mon Jun 09, 2008 10:53 pm    Post subject: Elevator Trim tab motor Reply with quote
The trim tab motor does not line up with the access hole [factory cutout] once the rod is approximately in the center of the cutout [20 -25mm out towards the i/b side].If one was to mount the motor onto the bottom skin instead then it does line up, because of the offset on the trim motor actuator.My question ? is there a r/h and a l/h version of the trim motor. Cheers
Afterfxllc(at)aol.com
PostPosted: Tue Jun 10, 2008 2:43 am    Post subject: Elevator Trim tab motor Reply with quote
I just installed mine and it was offset also but you can still get at it if you had to. The motor is about 30mm from the rib and the rivets are about 20mm from the rib.
Jeff
Vote for your city's best dining and nightlife. City's Best 2008.
Jaybannist(at)cs.com
PostPosted: Tue Jun 10, 2008 4:38 am    Post subject: Elevator Trim tab motor Reply with quote
Yes, there are left and right hand trim servos. I had the same problem as you are describing. After discussing it with ZAC, I cut a larger access hole and made a larger cover.
Jay in Dallas
http://forums.matronics.com/viewtopic.php?p=187089#187089
countzero
PostPosted: Tue Jun 10, 2008 4:58 am    Post subject: Re: Elevator Trim tab motor Reply with quote
My pre-cut Elevator access hole was offset from the servo body and lined up with the rod instead.
I found that the Aileron access hole lined-up with the servo body after I made the cutout as per the drawing dimensions but then it was slightly harder to access the clevis to install the pin, clip and washers.
Rob
cndmovn(at)gmail.com
PostPosted: Tue Jun 10, 2008 5:14 am    Post subject: Elevator Trim tab motor Reply with quote
Did mine exactly like Jeff's. the pictures in the manual show it offset from the access panel in a few of the pics.
On Tue, Jun 10, 2008 at 6:43 AM, <Afterfxllc(at)aol.com (Afterfxllc(at)aol.com)> wrote:
[quote] I just installed mine and it was offset also but you can still get at it if you had to. The motor is about 30mm from the rib and the rivets are about 20mm from the rib.
Jeff
BobTezyk
PostPosted: Tue Jun 10, 2008 8:04 pm    Post subject: Re: Elevator Trim tab motor Reply with quote
Here are some pictures of my QBK servo installation. I had no problem with getting the servo lined up.
 Filesize:  82.2 KB
 Viewed:  1082 Time(s)
 Filesize:  53.77 KB
 Viewed:  1051 Time(s)
 Filesize:  115.49 KB
 Viewed:  1054 Time(s)
View user's profile Send private message Send e-mail Yahoo Messenger
