Thruster87
Posted: Mon Jun 09, 2008 10:53 pm Post subject: Elevator Trim tab motor |
The trim tab motor does not line up with the access hole [factory cutout] once the rod is approximately in the center of the cutout [20 -25mm out towards the i/b side].If one was to mount the motor onto the bottom skin instead then it does line up, because of the offset on the trim motor actuator.My question ? is there a r/h and a l/h version of the trim motor. Cheers
| - The Matronics Zenith601-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Afterfxllc(at)aol.com Guest
Posted: Tue Jun 10, 2008 2:43 am Post subject: Elevator Trim tab motor |
I just installed mine and it was offset also but you can still get at it if you had to. The motor is about 30mm from the rib and the rivets are about 20mm from the rib.
Jeff
Vote for your city's best dining and nightlife. City's Best 2008.
Jaybannist(at)cs.com Guest
Posted: Tue Jun 10, 2008 4:38 am Post subject: Elevator Trim tab motor |
Yes, there are left and right hand trim servos. I had the same problem as you are describing. After discussing it with ZAC, I cut a larger access hole and made a larger cover.
Jay in Dallas
"Thruster87" <alania(at)optusnet.com.au> wrote:
http://forums.matronics.com/viewtopic.php?p=187089#187089
countzero
Posted: Tue Jun 10, 2008 4:58 am Post subject: Re: Elevator Trim tab motor |
My pre-cut Elevator access hole was offset from the servo body and lined up with the rod instead.
I found that the Aileron access hole lined-up with the servo body after I made the cutout as per the drawing dimensions but then it was slightly harder to access the clevis to install the pin, clip and washers.
Rob
cndmovn(at)gmail.com Guest
Posted: Tue Jun 10, 2008 5:14 am Post subject: Elevator Trim tab motor |
Did mine exactly like Jeff's. the pictures in the manual show it offset from the access panel in a few of the pics.
On Tue, Jun 10, 2008 at 6:43 AM, <Afterfxllc(at)aol.com (Afterfxllc(at)aol.com)> wrote:
[quote] I just installed mine and it was offset also but you can still get at it if you had to. The motor is about 30mm from the rib and the rivets are about 20mm from the rib.
Jeff
BobTezyk
Joined: 10 Jan 2006 Posts: 38 Location: Midlothian, TX
Posted: Tue Jun 10, 2008 8:04 pm Post subject: Re: Elevator Trim tab motor |
Here are some pictures of my QBK servo installation. I had no problem with getting the servo lined up.
Description: |
Filesize: |
82.2 KB |
Viewed: |
836 Time(s) |
Description: |
Filesize: |
53.77 KB |
Viewed: |
809 Time(s) |
Description: |
Filesize: |
115.49 KB |
Viewed: |
809 Time(s) |
