Fergus Kyle
Joined: 03 Jun 2007 Posts: 291 Location: Burlington ON Canada
Posted: Sat Jan 19, 2008 7:45 am Post subject: Panel cutting hint |
Thanks to Peter Field et al for the Subject topic.
Being in my eleventh year from delivery date, I'm past that phase,
but have the following hint to share:
When in UK I bought a box full of 0.5mm drill bits, an inexpensive
hobby facet for which UK is abundant supplier. When carving composite
materials (such as canoe cut-outs and panel sites) I insert one bit in my
high-speed granddad of the Dremel series (35k RPM), draw an accurate
outline, and plunge the bit in to start. Angled slightly to permit line
tracing, I slowly follow the line around 'til the job is done. Carefully
done, the result is a 0.5+/-mm cut that should (but not necessarily) be done
before finishing. It leaves an almost imperceptible gap which is easily
finished. Did I lose any bits from overheating? - yes, but I just kept
spinning with the remnant 'til there wasn't some. At 6p or whatever it was
quick, accurate and fairly cheap.
This little tidbit I bring to the Altar of Knowledge.
Ferg
Europa 914 mono CS prop
Wiring wiring wiring
