Panel cutting hint
Fergus Kyle
PostPosted: Sat Jan 19, 2008 7:45 am    Post subject: Panel cutting hint Reply with quote
Thanks to Peter Field et al for the Subject topic.
Being in my eleventh year from delivery date, I'm past that phase,
but have the following hint to share:
When in UK I bought a box full of 0.5mm drill bits, an inexpensive
hobby facet for which UK is abundant supplier. When carving composite
materials (such as canoe cut-outs and panel sites) I insert one bit in my
high-speed granddad of the Dremel series (35k RPM), draw an accurate
outline, and plunge the bit in to start. Angled slightly to permit line
tracing, I slowly follow the line around 'til the job is done. Carefully
done, the result is a 0.5+/-mm cut that should (but not necessarily) be done
before finishing. It leaves an almost imperceptible gap which is easily
finished. Did I lose any bits from overheating? - yes, but I just kept
spinning with the remnant 'til there wasn't some. At 6p or whatever it was
quick, accurate and fairly cheap.
This little tidbit I bring to the Altar of Knowledge.
Ferg
Europa 914 mono CS prop
Wiring wiring wiring
