Kolb-List Real Airplane :-)
BMWBikeCrz(at)aol.com
PostPosted: Mon Jan 14, 2008 6:00 am    Post subject: Kolb-List Real Airplane :-) Reply with quote
My Local DAR says its an airplane Smile
Therefore it is !
I want to replace my strutts with new streamlined tubing anyone done this ? I dont want to use the covers if I dont have to
Dave ... Pilot of the "Sofa King" Firestar KX
Start the year off right. Easy ways to stay in shape.
http://body.aol.com/fitness/winter-exercise?NCID=aolcmp00300000002489 [quote][b]
ElleryWeld(at)aol.com
PostPosted: Mon Jan 14, 2008 11:59 am    Post subject: Kolb-List Real Airplane :-) Reply with quote
Dave I have rplaced my wing struts with the streamline Aluminum strut Material its a good idea to do that on a Kolb to lose some drag
Ellery
Start the year off right. Easy ways to stay in shape in the new year.
Steve Boetto
PostPosted: Mon Jan 14, 2008 12:13 pm    Post subject: Kolb-List Real Airplane :-) Reply with quote
Ellery, did you check to make sure that the strut material you used meets both the compression as well as the tension requirements?
steve
In a message dated 1/14/2008 3:00:51 P.M. Eastern Standard Time, ElleryWeld(at)aol.com writes:
Ellery
="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics.com/Navigator?Kolb-List
.matronics.com/">http://forums.matronics.com
://www.matronics.com/contribution">http://www.matronics.com/contribution
SteveFirefly 007/Floatsdo not archive
Ralph B
PostPosted: Mon Jan 14, 2008 1:46 pm    Post subject: Re: Kolb-List Real Airplane :-) Reply with quote
"ElleryWeld(at)aol.com"
Ellery
I replaced mine on my Original Firestar (that often gets mistaken for a Firefly). Mine are the kind with the tube inside and are all aluminum. I gained about 5 mph in cruise with them.
 Filesize:  458.55 KB
 Viewed:  731 Time(s)
Ralph B
Kolb Kolbra 912uls
N20386
550 hours
herbgh
PostPosted: Mon Jan 14, 2008 6:06 pm    Post subject: Kolb-List Real Airplane :-) Reply with quote
Best deal on streamlined, aluminum lift struts is from Mary Carlson..Skytec aircraft..Herb
_____________________________________________________________
Click now to shop a huge selection of name brand women's boots!
http://thirdpartyoffers.juno.com/TGL2111/fc/Ioyw6iieMbJvheqajP8eASHEGOsFw1SsD0wDMO6JS2JXRumeMGNC7j/
JetPilot
PostPosted: Tue Jan 15, 2008 11:03 am    Post subject: Re: Kolb-List Real Airplane :-) Reply with quote
I considered using Aluminum struts on my MK III Xtra. Right now, it has steel covered by streamlined plastic. I liked the idea of just having a " Real " aluminum strut. After talking to Kolb and some other people, there was some question as to weather the aluminum struts would meet the compression requirements ( Not fold in case of negative G's ). Being that I could not determine that, I stuck with the steel ones Kolb provides. The plastic covering seems strong enough, and has not cracked or even started to work loose as I had feared.
It may work fine, but do your homework and be careful when making structural changes to your Kolb. There can be many unintended consequences one never thinks about when doing something like that.
Mike
Kolb MK-III Xtra, 912-S
