Europa XS with ULPower 260i engine
vaughnray(at)bvunet.net
PostPosted: Tue Jan 08, 2008 4:56 pm    Post subject: Europa XS with ULPower 260i engine Reply with quote
I have received the following reply from the ULPower representatvie to my question, "Why do I not need to include crowbar OV protection with this engine?"
Our electronics guy sent me a diagram showing the principle of how our type of regulator works. He says (in Dutch below) that:
our type is a "shunt" regulator which shorts the PMG to ground when the battery voltage increases above the nominal level so that the battery can never be over charged and damaged.
The principle of a PMG is different to a Regulated Field Generator (typical in cars) where the magnetic field is regulated to vary the voltage of the generator.
A PMG acts as a constant current source and therefore may be shorted out.
The regulator / rectifier we use is typically used on large capacity motorbikes and our supplier says they are very robust.
He also sent the attached schematic:
So as I see it, the attached schematic for my airplane should be sufficient.
Vaughn Teegarden
PMG_regulator.pdf
 Filename:  PMG_regulator.pdf
 Filesize:  50.45 KB
 Downloaded:  434 Time(s)
EuropaUL260i.pdf
 Filename:  EuropaUL260i.pdf
 Filesize:  287.96 KB
 Downloaded:  463 Time(s)
nuckolls.bob(at)cox.net
PostPosted: Sat Jan 12, 2008 11:40 am    Post subject: Europa XS with ULPower 260i engine Reply with quote
engine?"
Vaughn Teegarden
What you've proposed will be fine. The regulator
topology you cited is a carry through of the
earliest PM alternator regulators. It throttles
or controls alternator output to the system by
putting a dead short on the alternator's stator
windings during short periods where unrestrained
output would boost the system voltage too much.
This is a very simple approach that has been
effective since day-one . . . but does have the
down-side of causing the alternator to run at
max output current 100% of the time whether that
energy is used by the electrical system or not.
Of course, if wire size and cooling considerations
for the alternator are carefully addressed, this
can produce a robust, reliable system.
( -Thomas Paine 1776- )
PostPosted: Sat Jan 12, 2008 4:53 pm    Post subject: Europa XS with ULPower 260i engine Reply with quote
Thanks Bob,
I am going down to LSA show in Sebring, Florida to see the guys who make
the engine. I hope it works out well for me.
Vaughn Teegarden
