rv(at)thelefflers.com Guest
Posted: Sat Nov 24, 2007 1:23 pm Post subject: Landing Light Question |
I’m just getting ready to order my wings.
For those of you that are flying, would you make a different decision on what lighting you installed or would you do the same thing in your next aircraft?
I’m debating between the Duckworks HID in the leading edge or a HID in the wingtip.
Bob
pilotdds(at)aol.com Guest
Posted: Sat Nov 24, 2007 6:35 pm Post subject: Landing Light Question |
I have the wingtip lights supplied by vans,I have found them somewhat lacking on dark nights for both landing and taxiing.There appears to be a poorly lit area directly in front of the pilot.I have adjusted them to max benefit,They are usable but not great in my application.
Albert Gardner
Posted: Sat Nov 24, 2007 6:39 pm Post subject: Landing Light Question |
I’m not happy with the wingtip lights myself. If I try to get them to converge toward the center so that the center stripe shows up, the wingtip blocks a lot of the light. I think I will add an additional light either in the cowl or in the leading edge of one wing. The light themselves are bright enough I think but leave a very dark area right in front of the plane.
Albert Gardner
Yuma, AZ
_________________ RV-9A N872RV
RV-10 N991RV |
Tim Olson
Posted: Sat Nov 24, 2007 7:01 pm Post subject: Landing Light Question |
The leading edge lights by Duckworks align really well for me
with dual landing lights (one per side). It's no problem to
land on even a totally unlit runway if you can find your way
down to it. If you go that route though and you haven't painted
yet, I would just suggest cutting the holes and mounting the
brackets for both sides, even if you only put in one lamp.
You can always toss in a non-HID if you need to for cost
reasons, and change them later if you wish.
I know I've heard that there are going to be HID's for the
wingtips (of course, some can also go with the LoPresti
option, but talk to people before you try to do this with
tip tanks) but just due to things like the other answers
given by Albert, I'm not sure if from a light alignment
point of view you could do a great job covering the
angles you need. Also, mounted there, the actual beam
dimensions may become very critical if you want to get
light in front of the plane at all. Not saying it won't work,
but you might have more challenges ahead of you than the
leading edge lights.
I can see why leading edge lights would be intimidating to
convince yourself to cut the holes, but other than that,
I haven't found any reason that they aren't an ideal
location. The actual cutting process isn't a big deal either,
once you start it.
Albert Gardner wrote:
[quote] I’m not happy with the wingtip lights myself. If I try to get them to
front of the plane.
Albert Gardner
Yuma, AZ
gipsowh(at)hotmail.com Guest
Posted: Sat Nov 24, 2007 7:22 pm Post subject: Landing Light Question |
Check out the Aerosun LED landing lights. I've installed in my 10, yet to fly.
www.aeroleds.com
| Quote: | From: rv(at)thelefflers.com
Subject: RV10-List: Landing Light Question
Date: Sat, 24 Nov 2007 16:22:49 -0500
.ExternalClass EC_p.MsoNormal, .ExternalClass EC_li.MsoNormal, .ExternalClass EC_div.MsoNormal {margin-bottom:.0001pt;font-size:11.0pt;font-family:'Calibri','sans-serif';} .ExternalClass a:link, .ExternalClass EC_span.MsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited, .ExternalClass EC_span.MsoHyperlinkFollowed {color:purple;text-decoration:underline;} .ExternalClass EC_span.EmailStyle17 {font-family:'Calibri','sans-serif';color:windowtext;} .ExternalClass .EC_MsoChpDefault {;} (at)page Section1 {size:8.5in 11.0in;} .ExternalClass EC_div.Section1 {page:Section1;}
Bob
get=_blank>http://www.matronics.com/Navigator?RV10-List
p://forums.matronics.com
| Get the power of Windows + Web with the new Windows Live. Power up! [quote][b]
capsteve
Joined: 09 Jan 2006 Posts: 111 Location: NIAGARA FALLS NY
Posted: Sat Nov 24, 2007 10:38 pm Post subject: Landing Light Question |
I am very interested in the shadowing of headlights from the wingtip
position. i have taken a lot of time and energy to develop and make a direct
replacement hid kit for the wingtip light position. as a matter of fact i
just received my stocking order last week (after 6 mo's of delay) and I've
been testing the product on the bench. the results have been very good. What
we ended up with was a 50watt 5000k hid lamp and ballast to drop in place
with no modifications required.
I'd like to recruit two flying rv10 owners who'd like to get a special deal
on some hid lights in exchange for some real world feedback on the kit. the
light output is awesome but if there is any coverage issues i may make a
fiberglass cowl light as a third. at 3.5 amp each running two or three
shouldn't pose ant problems from a current standpoint....
what has the general feeling been about the standard lights mounted in the
wingtips. this is the first i heard about light coverage (shadowing)
issues....
Steven dinieri
IFLYRV10.COM
Posted: Sun Nov 25, 2007 4:39 am Post subject: Landing Light Question |
Are there any RV’s that are flying with the AeroLEDs installed?
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill Gipson
Sent: Saturday, November 24, 2007 10:22 PM
Subject: RE: Landing Light Question
www.aeroleds.com
Subject: Landing Light Question
Bob
[quote] [b]
Posted: Sun Nov 25, 2007 4:47 am Post subject: Landing Light Question |
Albert,
Are you using the standard Van’s OP36 kit?
Although I would suspect if there are shadowing issues, they would be present in all the other wing tip vendors solutions too.
bob
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Albert Gardner
Sent: Saturday, November 24, 2007 9:41 PM
Albert Gardner
Yuma, AZ
Jim & Julie Wade
Posted: Sun Nov 25, 2007 4:55 am Post subject: Re: Landing Light Question |
Lopesti has a kit for the RV10. Fits right in the tip. 1000000 lumins. I fly in and out of an unlit grass strip and the lights are the only reason I can the old lights were useless. The Loprestis light the runway from end to end. Also you can run them all the time, because power draw is minimal and the bulb has a 5000 hour life.
Jim
Posted: Sun Nov 25, 2007 5:33 am Post subject: Landing Light Question |
Hmmm......
I can't seem to find these on their web site.
dmaib@me.com
Joined: 25 Apr 2006 Posts: 455 Location: New Smyrna Beach, Florida
Posted: Sun Nov 25, 2007 7:20 am Post subject: Landing Light Question |
The lights are not on the LoPresti web site. Give them a call and
they will direct you to them. I tried to install them on my airplane
and they would not fit with the SafeAir1 ER tip tanks. They would
have been fine without the tip tanks. I know Jim Wade has tip tanks
and the LoPresti lights. His was the prototype installation done by
LoPresti and I suspect the brackets may be slightly different. The
brackets that came with my kit did not match the dimensions of the
brackets in the scale drawings, and I am pretty sure that caused my
problem. The folks at LoPresti are very good to work with and provide
good customer service.
David Maib
40559
On Nov 25, 2007, at 7:32 AM, Bob Leffler wrote:
Hmmm......
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
Posted: Sun Nov 25, 2007 8:37 am Post subject: Landing Light Question |
I don't see pricing for the Boom Beam system on their site. Do anyone
know about what they cost?
Robin
40570
Albert Gardner
Posted: Sun Nov 25, 2007 6:13 pm Post subject: Landing Light Question |
Yes, my wingtips are totally stock. I don’t think brighter lights are the answer because of the shadowing issue. I really like to get the center stripe up even at a familiar field.
Albert Gardner
Yuma, AZ
RV-10 N991RV |
dmaib@me.com
Posted: Sun Nov 25, 2007 7:09 pm Post subject: Landing Light Question |
I think the normal price is about $800 for the complete kit.
David
40559
Robin
40570
RV-10 #40559
Phil.Perry(at)netapp.com Guest
Posted: Mon Nov 26, 2007 10:05 am Post subject: Landing Light Question |
I have seen Bill's AeroLED's and (even though I'm still a ways away) I plan on using the AeroLED 1600's too. They're insanely bright, simple to install, and they only pull 2amps. I'm looking forward to the saving a little bit of weight on smaller wiring.
But even with those benefits, the primary selling point for me is the wig-wag functionality. The wig-wag controller is built into the lights and you only need to run 1 extra wire from the lights to the cockpit switch. When you close the switch, the lights begin running in wig-wag mode. No extra boxes, or anything.
They're just really bright, simple to install, and very functional.
Phil
Sent: Sunday, November 25, 2007 6:39 AM
www.aeroleds.com
Bob
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
wcurtis(at)nerv10.com Guest
Posted: Mon Nov 26, 2007 10:23 am Post subject: Landing Light Question |
So LED are cool but why pay $325 for one 1600 lumens LED when the standard H3 bulb in the $100 dual kit from Vans puts out 1550 lumens? I'm sure they will last a lot longer however, that's a lot of H3 bulbs to get up to the cost of those LED. Unless you reeeeally need low power consumption or low heat, LED landing and taxi light just don't make sense at those prices and light levels--IMHO.
Me, I'll have two standard H3s in the wingtips that can wing-wag and a single HID in the cowl, ala Cirrus. Actually, the recognition lights in the Cirrus wingtips are also LED, but these are recognition, not flood like the HID in the cowling.
William
http://wcurtis.nerv10.com/
dasduck(at)comcast.net Guest
Posted: Mon Nov 26, 2007 11:46 am Post subject: Landing Light Question |
Bob,
I have heard from many RV pilots that they wished they would have used my Leading Edge lights instead of the tip lights, especially due to the 'blanking' issue.
This ranges from long-time RV guys with the big tip lights, to the newer 2" tip lights, both guys I know and strangers that I meet at Oshkosh.
The LE location prevents light from going where you don't want it (like up) and the shape of the cutout allows it to spread down, to the front and to the sides, where you do want the light.
Another benefit to my kits is the great diversity in lamps that can be used.
You can start with any one of the kits and be assured of a simple upgrade to newer lamps as they come available or as your needs change.
At some point in the future, LED lamps will be a great solution. While they are very bright to 'look at' (making them a good solution for running lights and brake lights, especially with their low power draw), they still don't project enough light over a long distance (as compared to HID).
Dollar per Lumen, the HID lights are currently the brightest, they last long, and have a low draw.
I understand that the newer tip with the cutout is a very tempting place to put lights, and for some pilot's needs that option is acceptable.
For those that want a complete, flexible solution, you may want to take another look at the Duckworks lights.
Please feel free to contact me if you have questions. Don
Duckworks Aviation LLC
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler
Sent: Sunday, November 25, 2007 4:47 AM
Albert,
bob
Albert Gardner
Yuma, AZ
-----Original Message-----
Bob
0123456789012345
__________ NOD32 2684 (20071125) Information __________
6 [quote][b]
msausen
Posted: Mon Nov 26, 2007 12:19 pm Post subject: Landing Light Question |
This comment is geared more to the DIY crowd out there, hey we are building experimental aircraft aren't we. If you look around the net a little you can make comparable setups to the Aerosun's for probably $50 in change. If you break down the Aerosun product into individual LED's you end up with 200 lumens per LED for the 1600 and 100 lumens per LED for the 800. A quick check on eBay shows Luxeon 95 Lumen LED's for about $2.95 each plus shipping. So for 8 of these you are looking at about $29.55 + another $15 or so for 10 lenses for them.
Again, I spent maybe 5 minutes looking around for current LED prices so I'm sure you can do better if you really hunt a bit. I'm also fairly certain Luxeon is selling LED's up above 150 Lumens each. Not knocking the Aerosuns product, they actually seem reasonably priced given development and the whole packaging. LED's are going to continue to get cheaper and brighter.
Michael
Posted: Mon Nov 26, 2007 1:05 pm Post subject: Landing Light Question |
Don,
For the most part I really like your product. The were some contradictions in you installation instructions that
need to be cleared up as the pictures show one thing but the, directions say another, (distances from rivet lines.) Also the distances between
the ribs were quite different from what the manual stated and I needed to make my own alterations to the lamp trays. I used the
second bay between ribs and not the last bay as I wanted more access to the AOA installation in the last bay. The last bay on the 10
also has quite a long span between ribs which would also allow much more of a harmonic to develop with engine and flight vibration.
For the most part, nice kit and thanks.
John G. 409
From: dasduck(at)comcast.netTo: rv10-list(at)matronics.comSubject: Landing Light QuestionDate: Mon, 26 Nov 2007 11:05:56 -0800
Bob,
Tim Olson
Posted: Mon Nov 26, 2007 3:05 pm Post subject: Landing Light Question |
You know, Don touched on something I hadn't actually pondered
much in all of this....the fact that you don't want the light
to go UP. Having used my lights in clouds and at night in
haze, in past planes I've found the light a bit distracting
if it lights up the stuff next to me. You now are flying
in a brighter bubble of air that makes it a little harder
to see out the windshield where the traffic is. With the
lights I have now, I don't really even know they're on, on
a clear night, unless there's some haze to see, and at least
then it's lighting it up below the horizon a bit.
I do think that for recognition lights though, if you're
going to wig-wag and just display them for recognition,
LED's are about as ideal as you could get. I think even
for taxi lights, if you feel you need them, LED's would
be a fair option. The sad part about the wingtip cutouts
is that the same thing that gives the Nav lights good
utility (the large field of view to the sides, top,
bottom, and somewhat of the front) is one of the
problems with using that location for landing lights. Not
that you absolutely can't put landing lights there and
see some of the runway, but it's much harder to mount
them there and get anything but runway edges lit up.
My old plane had a single 250W landing light. Man, that
sucker was 20A!! I did the best I could on that plane and
added another light bay since it had 2 holes in one wing.
I went with 2 lamps, 100W Halogen....saved some current
draw. The problem with the halogens was that the actual
beam width was about 1/2 of what the 250W standard was.
So I had to be careful to aim one across the plane and
one forward. I had enough brightness, but the coverage
wasn't as nice as the 250W was. So that's why I mentioned
before that you should watch the actual beam width
projected by whatever bulb you choose, for whatever
location you use.
Regarding Aerosun's...as I walked by them at OSH they
commented to me and tried to lure me in. I stopped
and looked and they actually look pretty nice compared
to some options. The guy started pushing me on how
much brighter they would be then too.....but that
stopped the second I told him I had dual HID's. They
aren't bad lights, but they don't hold a candle(power)
to HID's, and HID's also are pretty competitive in
their current draw. My dual 35W HID's draw about 6A
on my Ammeter.
don wentz wrote:
| Quote: | Bob,
'blanking' issue.
to HID).
Don
