HodgeJW(at)aol.com Guest
Posted: Thu Sep 13, 2007 4:49 pm Post subject: hydro lock |
Hey Guys,
I was flying friends Yak 50 today (Tim G). I parked it for about 15 min. when I went back to start it, I debated about whether to pull the prop thru or not. I mean it was only 15 min. right? I only pull my 52 thru first flight of the day. Well good thing I did, it was locked SOLID. Pulled the cowls, and bottom plugs, and you wouldn't believe the amount of oil that came out. From now on, if I walk away from it, I'll pull it thru. On another note, man will a 50 tumble!!!! Damn, I love that plane. Here lately I've been flying some hotrods (Pitts S2C Suk 29 Extra 300) but this 50 has some serious personality. I cant thank Tim enough for letting me have access to this beast. Thanks man.
Jay
See what's new atblank">Make AOL Your Homepage.
cjpilot710(at)aol.com Guest
Posted: Thu Sep 13, 2007 5:09 pm Post subject: hydro lock |
Why is it, these -50 and TWs seem to have "oil events"? At OSH this year, I notice you could tell where a TW or 50 had been parked. A huge oil stain on the grass where these guys pulled their props though before starting. Its seen the straight 52s don't have that habit or at least not as bad. Of course my CJ with it's M-14p does not seem to do nasty things like that. Smirk- smirk - ;>}
Jim "Pappy" Goolsby
Se69" target="_blank">Make AOL Your Homepage.
david(at)mcgirt.net Guest
Posted: Thu Sep 13, 2007 5:17 pm Post subject: hydro lock |
Solved my problem with a oil scavenger pump, but it is valid point.. Something about sitting at that angle ( tail dragger ) seems to be part of the “feature”
On 9/13/07 9:09 PM, "cjpilot710(at)aol.com" <cjpilot710(at)aol.com> wrote:
Quote: | Why is it, these -50 and TWs seem to have "oil events"? At OSH this year, I notice you could tell where a TW or 50 had been parked. A huge oil stain on the grass where these guys pulled their props though before starting. Its seen the straight 52s don't have that habit or at least not as bad. Of course my CJ with it's M-14p does not seem to do nasty things like that. Smirk- smirk - ;>}
Jim "Pappy" Goolsby
ail Forum -
">http://www.matronics.com/Navigator?Yak-List
; - NEW MATRONICS WEB FORUMS -
matronics.com
Posted: Thu Sep 13, 2007 6:54 pm Post subject: hydro lock |
Jay,
I had a similar experience. I even had the intake drain open and got a loc. Rocked the prop a couple of times and it cleared. I to pull blades each and every time before flying he 50. I think it has to do with the fact that those intake tubes are sitting on an incline of 15 degrees vs the 52 with it intakes being pretty much parallel to the ground. Even with the 52 if she has sat for a few minutes I will pull a minimum of 8 blades.
She does have a serious personality!
My 2 cents.
Doc
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of HodgeJW(at)aol.com
Sent: Thursday, September 13, 2007 7:49 PM
To: yak-list(at)matronics.com
Subject: hydro lock
Hey Guys,
Jay
Posted: Thu Sep 13, 2007 7:13 pm Post subject: hydro lock |
It’s all in the angle of the dangle!
Doc
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of cjpilot710(at)aol.com
Sent: Thursday, September 13, 2007 8:09 PM
Subject: Re: hydro lock
Jim "Pappy" Goolsby
shinden33(at)earthlink.ne Guest
Posted: Thu Sep 13, 2007 9:05 pm Post subject: hydro lock |
I concure. I always pull my '52 through before starting no matter how long since it ran. The time is well worth it considering the possible consequences.
Scott
N8252
[quote] --
jan.mevis(at)informavia.b Guest
Posted: Thu Sep 13, 2007 10:32 pm Post subject: hydro lock |
Me too, I always have to pull the prop, whereas my friends with their 52’s have less oil coming out AFTER flying. AND I do the scavenging as it should be done. AND I’m quite certain that my engine is in as good a shape as theirs. Maybe it’s a coincidence. There are not enough YK50’s to have significant statistical data J
Jan
RA2005K YK50
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of David McGirt
Sent: vrijdag 14 september 2007 3:17
Jim "Pappy" Goolsby
ail Forum -
matronics.com
andy717(at)comcast.net Guest
Posted: Fri Sep 14, 2007 7:22 am Post subject: hydro lock |
Hey guys,
Future M14P pilot here -- wouldn’t using a quick drain valve collecting from cylinders 4, 5 and 6 be an alternative to pulling the plugs? I’m not sure if the Yak folks have/use these drains or not and I’m just trying to verify if pulling the plugs AND using a drain valve are necessary -
Thank you!
Andy
www.radialrocketman.com
Nashville, TN
On 9/13/07 7:49 PM, "HodgeJW(at)aol.com" <HodgeJW(at)aol.com> wrote:
Jay
ail Forum -
matronics.com
Scooter
Posted: Fri Sep 14, 2007 8:45 am Post subject: Re: hydro lock |
Most, if not all, aircraft with M-14p have the quick drain. If you get a hydraulic lock (drain was closed, etc) then the only/best remedy is to remove the plugs.
[quote="andy717(at)comcast.net"]Hey guys,
Thank you!
Andy
Nashville, TN
On 9/13/07 7:49 PM, "HodgeJW(at)aol.com" <HodgeJW> wrote:
Jay
ail Forum -
matronics.com
f on
scott-p(at)texas.net Guest
Posted: Fri Sep 14, 2007 8:57 am Post subject: hydro lock |
Hi Andy,
I have an intake drain set up on my Yak 55M, and it prevents MOST hydro-lock conditions, however, it is still possible to have enough oil in a cylinder which, when cold won’t come out through the relatively small diameter intake drain and you end up needing to pull the plugs. In my case that has happened twice in the past 4 years, but it does occasionally happen. Usually when I haven’t flown the plane for more than 2 weeks.
Another good reason to go fly…<VBG>
Scott
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Andy Hawes
Sent: Friday, 14 September, 2007 09:22
Hey guys,
Thank you!
Andy
Nashville, TN
Hey Guys,
Jay
ail Forum -
matronics.com
brian-1927(at)lloyd.com Guest
Posted: Fri Sep 14, 2007 9:03 am Post subject: hydro lock |
The quick drains drain the intake riser tubes, not the cylinder. If
the intake valve is closed and oil goes past the rings into the
cylinder itself it would never make it to the quick drain. (As the
engine cools, air trapped in the cylinder decreases in volume and
forms a vacuum which can suck-in any oil sitting on top of the piston.)
So, the quick drains do not necessarily end up with all the oil at
the low point.
Some people like to turn the engine backwards when encountering
resistance/lock which then pushes oil from the cylinder to the intake
tube. There are two problems with this that may cause the engine to
hydraulic lock again upon starting:
1. The intake valve is not necessarily the lowest point in the
cylinder. Significant quantity of oil can still sit in the head. Best
case this raises compression. Worst case is that there might be
enough to cause a lock.
2. Oil that is pushed into the intake tube might not go out the quick
drain and instead remain in the intake tube. This oil can be sucked
back into the cylinder and cause a lock after the engine fires. If
there is enough this is just about guaranteed to bend/break a piston
or con-rod.
The ONLY 100% safe way to undo a hydraulic lock is to open in the
intake drains, pull the bottom plugs, and pull the engine through
until you can get no more oil from the plug holes or the intake drain
plug holes.
Given how much a broken engine can cost, it just isn't worth the time
saved by doing a half-assed job of clearing the bottom cylinders.
Also remember, a partial lock can bend a rod but leave no other
symptoms. Your engine then becomes a time-bomb.
Brian Lloyd 3191 Western Drive
brian HYPHEN 1927 AT lloyd DOT com Cameron Park, CA 95682
— Antoine de Saint-Exupéry
PGP key ID: 12095C52A32A1B6C
PGP key fingerprint: 3B1D BA11 4913 3254 B6E0 CC09 1209 5C52 A32A 1B6C
Posted: Fri Sep 14, 2007 1:19 pm Post subject: hydro lock |
Read Brian Lloyd's reply to this one for the best of advice, but let me
just add a few things:
1. I own a YAK-50 with intake drains, and due to a slightly leaky ball
check valve in my oil pump I get oil into the cylinders very quickly.
In a month of no flying I can actually lose up to 3 GALLONS of oil. If
I fly every two weeks or so, that never happens.
2. Each person has his or her own method for getting oil out of the
cylinders, Brian's method being the most safe obviously.
3. Probably the best method I saw of everyone listed was on Sergei
Boriak's SU-31 (before it crashed). Sergei was sick and tired of oil in
the cylinders and having to pull it through EVERY time.
A. He spent a huge amount of $$$ and had new pistons put in with gapless
rings. Much more was done here than I will list, but the rings made a
big difference.
B. The best trick was that he installed an OIL VALVE in the oil supply
line to the engine. Yes, there is an obvious danger in doing that. He
put in the typical safety steps with starter inhibitors, etc. etc. And
I am sure, a lot of people will say it is still too dangerous. So if
you feel that way, good for you. Keep yanking the plugs. On the flip
side, shutting off the oil supply pretty much puts an END to this
problem.
C. The last step was to install an engine sump line going to an
electrical pump. After landing and shutting the engine down, you run
the pump and the oil from the sump is pumped back into the main oil
tank.
You combine all three and you have a very dry engine, no oil on the
ground, and no need to pull it through, and no chance of hydrostatic
locks.
I'm going to go with the main tank oil shut off valve, with push pull
control from the cockpit.
Mark
N50YK
Posted: Fri Sep 14, 2007 1:22 pm Post subject: hydro lock |
I had them as well, and they work GREAT. I was just too worried about one of the many oil hoses coming off in flight and me never being able to know it was happening. In my way of thinking, the more oil hoses and clamps you can remove, the better off you are.
I also had his original electrical sump pump. It worked great as well.
Mark
N50YK
wlannon(at)cablerocket.co Guest
Posted: Fri Sep 14, 2007 8:07 pm Post subject: hydro lock |
Right on Brian.
Good to have you back.
Walt
Posted: Fri Sep 14, 2007 9:04 pm Post subject: hydro lock |
On Sep 14, 2007, at 9:07 PM, Walter Lannon wrote:
Quote: |
<wlannon(at)cablerocket.com>
Right on Brian.
Thanks Walt.
Posted: Sat Sep 15, 2007 7:05 am Post subject: hydro lock |
Thanks very much for all the very detailed replies. I believe the current
prototype for the Radial Rocket is using both an electric sump pump for post
flight clean up, the oil shut-off valve as well as the valve/drain with
success. As I get closer to setting up fuel, air and oil systems I'm sure
I'll have even more questions.
Thanks again for everyone's extensive input and time here --
Andy Hawes
Nashville, TN
On 9/14/07 12:03 PM, "Brian Lloyd" <brian-1927(at)lloyd.com> wrote:
> Hey guys,
> Future M14P pilot here -- wouldn¹t using a quick drain valve
> the plugs? I¹m not sure if the Yak folks have/use these drains or
> not and I¹m just trying to verify if pulling the plugs AND using a
the low point.
or con-rod.
plug holes.
‹ Antoine de Saint-Exupéry
