MaxHegler(at)msn.com Guest
Posted: Fri Jun 29, 2007 10:21 am Post subject: RV8 Rocket |
Do any of the Rocket or F1 derivatives use the RV 8 as a basis? I am
wondering if I can use the RV-8 fuselage with the tapered wings from a
Rocket or F1.
Max
| | - The Matronics Rocket-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Rocket-List |
kahuna
Posted: Fri Jun 29, 2007 11:04 am Post subject: RV8 Rocket |
There are RV-8's with 540's on them.
You would not be able to use the 8 fuse with the evo wing without serious modification.
The wing root and carry through are completely different as are the rear spar connects and dimensions.
Best,
Mike
[img]cid:1__=08BBF99ADFFBD9328f9e8a93df938(at)us.ibm.com[/img]"Max Hegler" <MaxHegler(at)msn.com>
[img]cid:3__=08BBF99ADFFBD9328f9e8a93df938(at)us.ibm.com[/img]
To
<rocket-list(at)matronics.com> [img]cid:3__=08BBF99ADFFBD9328f9e8a93df938(at)us.ibm.com[/img]
cc
Subject
RV8 Rocket [img]cid:3__=08BBF99ADFFBD9328f9e8a93df938(at)us.ibm.com[/img][img]cid:3__=08BBF99ADFFBD9328f9e8a93df938(at)us.ibm.com[/img]
--> Rocket-List message posted by: "Max Hegler" <MaxHegler(at)msn.com>
Rocket or F1.
Max
tor?Rocket-List">http://www.matronics.com/Navigator?Rocket-List
EB FORUMS -
tp://forums.matronics.com
105 Bytes |
4399 Time(s) |
1.23 KB |
4397 Time(s) |
45 Bytes |
4397 Time(s) |
jhstarn(at)verizon.net Guest
Posted: Fri Jun 29, 2007 4:58 pm Post subject: RV8 Rocket |
Sorry I just don't get it. Why would you use a -8 to make a "Rocket". Gear leg boxes to get in the way of your feet. Less room overall. If you want a Rocket, build one...HRII or F-1, slower (HRII)build or QB (F-1). Take your pick unless ya "need" pre-punched.
Do Not Archive KABONG HRII N561FS.....waiting on the RV-12
| Quote: | From: Michael W Stewart <mike.stewart(at)us.ibm.com>
Date: 2007/06/29 Fri PM 02:01:28 CDT
To: rocket-list(at)matronics.com
Subject: Re: RV8 Rocket
Best,
Mike
| Quote: | Subject
RV8 Rocket
Do any of the Rocket or F1 derivatives use the RV 8 as a basis? Â I am wondering if I can use the RV-8 fuselage with the tapered wings from a Rocket or F1.
Max
nico(at)cybersuperstore.c Guest
Posted: Fri Jun 29, 2007 5:33 pm Post subject: RV8 Rocket |
RV-12?
