RV8 Rocket
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Rocket-List
MaxHegler(at)msn.com
PostPosted: Fri Jun 29, 2007 10:21 am    Post subject: RV8 Rocket Reply with quote
Do any of the Rocket or F1 derivatives use the RV 8 as a basis? I am
wondering if I can use the RV-8 fuselage with the tapered wings from a
Rocket or F1.
Max
- The Matronics Rocket-List Email Forum -
http://www.matronics.com/Navigator?Rocket-List
kahuna
PostPosted: Fri Jun 29, 2007 11:04 am    Post subject: RV8 Rocket Reply with quote
There are RV-8's with 540's on them.
You would not be able to use the 8 fuse with the evo wing without serious modification.
The wing root and carry through are completely different as are the rear spar connects and dimensions.
Best,
[img]cid:1__=08BBF99ADFFBD9328f9e8a93df938(at)us.ibm.com[/img]"Max Hegler" <MaxHegler(at)msn.com>
[img]cid:3__=08BBF99ADFFBD9328f9e8a93df938(at)us.ibm.com[/img]
To
<rocket-list(at)matronics.com> [img]cid:3__=08BBF99ADFFBD9328f9e8a93df938(at)us.ibm.com[/img]
cc
Subject
RV8 Rocket [img]cid:3__=08BBF99ADFFBD9328f9e8a93df938(at)us.ibm.com[/img][img]cid:3__=08BBF99ADFFBD9328f9e8a93df938(at)us.ibm.com[/img]
--> Rocket-List message posted by: "Max Hegler" <MaxHegler(at)msn.com>
Rocket or F1.
Max
tor?Rocket-List">http://www.matronics.com/Navigator?Rocket-List
EB FORUMS -
tp://forums.matronics.com
 Filesize:  105 Bytes
 Viewed:  4400 Time(s)
 Filesize:  1.23 KB
 Viewed:  4398 Time(s)
 Filesize:  45 Bytes
jhstarn(at)verizon.net
PostPosted: Fri Jun 29, 2007 4:58 pm    Post subject: RV8 Rocket Reply with quote
Sorry I just don't get it. Why would you use a -8 to make a "Rocket". Gear leg boxes to get in the way of your feet. Less room overall. If you want a Rocket, build one...HRII or F-1, slower (HRII)build or QB (F-1). Take your pick unless ya "need" pre-punched.
Do Not Archive KABONG HRII N561FS.....waiting on the RV-12
From: Michael W Stewart <mike.stewart(at)us.ibm.com>
Date: 2007/06/29 Fri PM 02:01:28 CDT
To: rocket-list(at)matronics.com
Subject: Re: RV8 Rocket
Best,
Subject
RV8 Rocket
Do any of the Rocket or F1 derivatives use the RV 8 as a basis?  I am wondering if I can use the RV-8 fuselage with the tapered wings from a Rocket or F1.
Max
nico(at)cybersuperstore.c
PostPosted: Fri Jun 29, 2007 5:33 pm    Post subject: RV8 Rocket Reply with quote
RV-12?
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Rocket-List All times are GMT - 8 Hours
