What is the main spar material 6061T6 ?
marwynne(at)verizon.net
PostPosted: Thu Jun 14, 2007 8:57 pm    Post subject: What is the main spar material 6061T6 ? Reply with quote
What are the spars of a Kitfox 6061T6 ? My measurements were for 2 1/2 inch .065 thickness !
I looked in the book and they didn't give the metal. Anyone know ?
Thanks in Advance
Marwynne
 Filesize:  23.31 KB
 Viewed:  294 Time(s)
mclayton(at)rochester.rr.
PostPosted: Fri Jun 15, 2007 2:25 am    Post subject: What is the main spar material 6061T6 ? Reply with quote
John McBean can give you the definitive answer, but I am 99% sure that the alloy is 6061-T6, based on examination of the markings on the spar for my aircraft.  I also suspect the parts list in the construction manual may give the info.
Mike
mclayton(at)rochester.rr.com (mclayton(at)rochester.rr.com)
Mobile: 585-737-5506
8 Adams Trail
Spencerport, NY 14559
N16AF (KF II  Rebuild in Progress)
Thanks in Advance
Marwynne
