marwynne(at)verizon.net Guest
Posted: Thu Jun 14, 2007 8:57 pm Post subject: What is the main spar material 6061T6 ? |
What are the spars of a Kitfox 6061T6 ? My measurements were for 2 1/2 inch .065 thickness !
I looked in the book and they didn't give the metal. Anyone know ?
Thanks in Advance
Marwynne
23.31 KB |
338 Time(s) |
mclayton(at)rochester.rr. Guest
Posted: Fri Jun 15, 2007 2:25 am Post subject: What is the main spar material 6061T6 ? |
John McBean can give you the definitive answer, but I am 99% sure that the alloy is 6061-T6, based on examination of the markings on the spar for my aircraft. I also suspect the parts list in the construction manual may give the info.
mclayton(at)rochester.rr.com (mclayton(at)rochester.rr.com)
Mobile: 585-737-5506
8 Adams Trail
Spencerport, NY 14559
N16AF (KF II Rebuild in Progress)
On Jun 15, 2007, at 12:55 AM, Marwynne Kuhn wrote:
| Quote: | What are the spars of a Kitfox 6061T6 ? My measurements were for 2 1/2 inch .065 thickness !
Thanks in Advance
Marwynne
