Carlos Sa
Posted: Mon Feb 06, 2006 3:17 pm Post subject: green scotchbrite |
One rudder, one elevator, one horiz. stabilizer, two outboard spars, one central spar, two fuel
tanks, I-don't-know-how-many-ribs done and you say the green stuff iznogood?!
Why?
Carlos
do not archive - for now
--- Thilo Kind <thilo.kind(at)gmx.net> a crit :
Quote: |
Green dust??? Sounds, like you are using the green Scotchbrite. No good for
aluminum. Use only the darl red stuff.
Happy building
Thilo Kind
Lche-vitrine ou lche-cran ?
magasinage.yahoo.ca
| - The Matronics Zenith-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
_________________ CH601-HD, plans
Montreal, Canada |
mike.sinclair(at)ATT.NET Guest
Posted: Mon Feb 06, 2006 4:35 pm Post subject: green scotchbrite |
One whole airplane, plus a 2nd right wing, and I'm kinda wonderin' myself. Suppose it might be ok
since I covered it all with green paint?
Mike Sinclair
N701TD should be back in the air in the next couple of weeks. Hum? maybe the green stuff was the
real reason for the axle failure. And speaking about getting in the air. Another 701, built by
Clyde Engert of Towanda, Kansas made it's initial excursions into the wild blue today. I don't
believe he is on the list, but I thought it was another noteworthy accomplishment. Aircraft
performed great and Clyde is now a much happier camper.
Why?
Carlos
> Happy building
> Thilo Kind
magasinage.yahoo.ca
jeffrey_davidson(at)earth Guest
Posted: Mon Feb 06, 2006 4:59 pm Post subject: green scotchbrite |
Not to take sides on the Scotch Brite thing, but from the archives:
Quote: |
>I've looked at it very carefully. It is an opinion issued by the Luscombe
>Association. I don't think they know what they are talking about.
>Cy Galley
+++ Cy, Zenith published a full page chart printed in the Zenair
Newletter #84 September/October 1994 issue that is virtually identical to
the listing just posted. It lists (9) different abrasives and says the
same
Quote: | thing including the comments about Scotch-brite A being acceptable, and
Scotchbrite-S being NOT acceptable, emery cloth or emery paper not
acceptable, steel brushes not acceptable, but Aluminum Oxide IS
Recommended. It goes on to further include a catagory of "Blast Cleaning
Grits" for those that might be using air blasting to remove paints or
prepare various metals for priming. From both catagories, it prohibits the
use of any steel or iron-oxide based products on aluminum. I asked the EAA
Techinical Advisor about this and was told that those products are listed
as
Quote: | "prohibited" because they leave micro-particles of steel or iron-oxide
imbedded in the aluminum, and that can produce the dialectric differential
with the aluminum which can promote corrosion of the aluminum. Fred
Jeff Davidson
Ron Lendon
Joined: 10 Jan 2006 Posts: 685 Location: Clinton Twp., MI
Posted: Mon Feb 06, 2006 5:39 pm Post subject: Re: green scotchbrite |
This is right from the Zodiac XL Photo Assembly guides:
Quote: |
Metal preparation for before priming
Gently scuff up the surface with a Scotch-bright general purpose hand pad 3M product P/N 7447+ (plastic pad similar to pad on back side of some sponges found around the kitchen!) do not use steel wool. De-grease the surface with a solvent on a clean rag, such as lacquer thinner. Apply the primer on bother matting surface, let dry, then cleco the parts together for riveting. Only apply the primer on the inside surfaces only, the primer may not be compatible with the top coat or paint!
Maybe the green stuff was $$$ as in not enough.
_________________ Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
https://sites.google.com/site/corvairenginedata/ |
bryanmmartin
Posted: Mon Feb 06, 2006 6:10 pm Post subject: green scotchbrite |
The 3M MSDS sheet for product P/N 7447+ shows that it uses an aluminum oxide
abrasive so it should be correct for use on aluminum. I guess you can't tell
what abrasive is used in the product by its color.
Bryan Martin
do not archive.
Ron Lendon, Clinton Township, MI
Corvair Zodiac XL, ScrapBuilder
_________________ --
Bryan Martin
do not archive. |
Bill(at)flyinmiata.com Guest
Posted: Mon Feb 06, 2006 6:22 pm Post subject: green scotchbrite |
Just please, please don't ever get it near aluminum engine parts. Don't
ask me how I know.
Bill Cardell (TurboDog's Dad)
www.flyinmiata.com
1-800-FLY-MX5S
tech 970-242-3800
BobTezyk
Joined: 10 Jan 2006 Posts: 38 Location: Midlothian, TX
Posted: Tue Feb 07, 2006 7:26 am Post subject: Re: green scotchbrite |
3M publishes several application documents specifically for use in aircraft. I have attached them to this message in the BBS forum. Those of you who get the email distribution will have to go there to get them.
Hope this helps.
Bob Tezyk
Getting Hangar ready to build a 601XL
Description: |
Filename: |
SBforACmfg.pdf |
Filesize: |
662.22 KB |
Downloaded: |
1856 Time(s) |
Description: |
Filename: |
SBforACmaint.pdf |
Filesize: |
542.2 KB |
Downloaded: |
3125 Time(s) |
davevanlanen(at)sbcglobal Guest
Posted: Tue Feb 07, 2006 7:17 pm Post subject: green scotchbrite |
Bryan,
So are you saying that the "green stuff" is OK? I purchased the green
stuff, but could not find a part number on the product, so I don't know if I
got part 7447+ or not. Since I haven't started building yet, I guess I'd
like to know for sure if it is OK to use. I haven't seen any red stuff -
wouldn't even know where to get that.
Dave
Time: 06:10:02 PM PST US
Subject: Re: Re: green scotchbrite
Bryan Martin
do not archive.
Posted: Tue Feb 07, 2006 7:54 pm Post subject: green scotchbrite |
Thilo
Zenith-List message posted by: "Thilo Kind" <thilo.kind(at)gmx.net>
Guess that since you kinda got this started, can you tell us where you got your
reference as to the suitability of red vs. green? I have enjoyed the discussion and
it is quite a bit late for me since I have mine already painted. I did use a
solvent product called Final Kleen and a tack rag over all surfaces after using the
green Scotch Brite, and I do believe I eliminated all the "green dust" before
primer coats. Seems that there are a couple of opinions as to red or green, but so
far nothing that really backs up one or the other. As I understand so far, green
should clean the surface by scuffing, and red is more of an abrasive. For myself I
think I would use the red only when dealing with a surface that has been previously
painted and you are in the process of prepping it for new paint. And also if
dealing with an aircraft that has a thicker skin than the typical Zenith aircraft
(due to the abrasive nature of the red). But since I've been wrong at least once
before (hate to admit that though, and ain't gonna say when), am open to any
suggestions that will help our sport be safer. And did I say I've enjoyed this
topic? Subjects like this keep the list interesting.
Mike Sinclair N701TD
Dave VanLanen wrote:
Quote: |
Bryan,
Dave
Bryan Martin
do not archive.
bryanmmartin
Posted: Wed Feb 08, 2006 2:41 am Post subject: green scotchbrite |
If you are talking about the green scrubbing pads from the grocery store, I
haven't found any good information about that. Someone mentioned part number
7447. I found some information at the 3M website about that. I don't know if
they are the same product. The 3M website has a link to search for MSDS
sheets by UPC code, you might try that if you still have any of the
packaging from the product you bought.
Bryan Martin
do not archive.
on 2/7/06 10:11 PM, Dave VanLanen at davevanlanen(at)sbcglobal.net wrote:
Quote: |
<davevanlanen(at)sbcglobal.net>
Bryan,
Dave
Bryan Martin
do not archive. |
mhoffman9(at)tampabay.rr. Guest
Posted: Wed Feb 08, 2006 3:24 am Post subject: green scotchbrite |
Steve,
I have stripped and repainted 4 aircraft and numerous cars and boats. I have
used the "green scotch pads" with no problems what so ever. I have also, on
occasion, used marine Zink chromate when the aviation specific Zink was not
readily available. I also am using green scotch pads to scuff the surfaces
on my 701.
Do not archive.
Just my 2 cents.
Mike Hoffman
agustafson(at)chartermi.n Guest
Posted: Wed Feb 08, 2006 5:49 am Post subject: green scotchbrite |
My Ace Hardware has all the colors. Just different coarseness. The gray is
fine and the red and green more coarse. I forget witch one is most coarse. I
have also seen some really coarse stuff used for scrubbing floors. It may
not be true to the color scheme.
Aaron
Ron Lendon
steveadams
Posted: Thu Feb 09, 2006 5:10 am Post subject: Re: green scotchbrite |
Could we please put this OWT to rest. Here is the MSDS on scothbrite 96 (the green ones), in spanish, but thats all I could find.
SCOTCH-BRITE(TM) FIBRA ESPONJA 96, MEXICO
ISSUED: January 28, 2000
SUPERSEDES: INITIAL ISSUE
DOCUMENT: 09-5039-4
1. INGREDIENT C.A.S. NO. PERCENT
PHENOLIC RESIN.......................... 9003-35-4 30-60%
ALUMINUM OXIDE.......................... 1344-28-1 20-50%
NYLON FIBER............................. Unknown 15-40%
I looked through all the msds's for scotch-brite and couldn't find any of the pads that had anything other than aluminum oxide, silicon carbide, talc, or polyester as an abrasive. The "aircraft cleaning pads" have talc and polyester. The various scotch-brite wheels, grinders etc may be different, I didn't look at them. Select them based upon how abrasive you want them to be, or price, or color if you just like the way marron or grey look in your hand, but none of the pads commonly available contain iron. All of us who picked up our green pads from walmart, home depot, or under the kitchen sink can finally sleep without worrying. Now as far as priming the interior surfaces.........
