thomas(at)scherer.com Guest
Posted: Sun Feb 25, 2007 8:58 pm Post subject: she did what she was supposed to do |
it is my sad duty (well, glad - I am reporting it myself) that N81EU was
lost tonight on a take-off failure with me and Kim Prout aboard.,
The Rotax 912 failed on take-off and running out of options I had to put her
down at the end of the runway with a droop and fence ahead.
Plane came to a rest in a quarry after shearing off the landing gear
(trigear) and tearing off the firewall foward.
It is a miracle that Kim and me walked away and I fully attribute it to the
design of the central tunnel and the wheel attachment that we're not only
alive but walked away unharmed from a complete crash,
The flying surfaces seem unhamarmed as well as the fuselelage except the
firewall foward (which broke off 1oo %) and the gears which were lost about
2oo feet short off the crash site.
It is very early to say anything - the engine was fine - we worked on it the
entire afternoon and found it to be very smooth - I fear I installed as new
fuel filter which should not have been there - more later.
Anyway - we're alive (and having our share of Whiskey) and I promise you ...
you will hear again of N81EU.
Thanks to the designer who made her this crashworthy - N18EU now has 890 hrs
under her belly and never missed a beat (Rotax 912).
more later
<Thomas N81EU>
PS: the only pain we can report of is on our feet - after the firewall
sheared off our feet were in the void and got hurt on the last impact. She
was flying right to the end. Europa rulez !
Paul Boulet
Joined: 09 Jan 2006 Posts: 57 Location: Malibu, California
Posted: Sun Feb 25, 2007 9:35 pm Post subject: she did what she was supposed to do |
Wow.... my empathy to you and Kim.... congrats are in order not just to the designer but to the pilot for cool thinking in a crisis situation. Thank you for your candid report of this terrible situation. May you quickly get your bird repaired and into the air soon!
Paul Boulet, N914PB, Malibu, California
Kevin Klinefelter
Posted: Sun Feb 25, 2007 10:04 pm Post subject: she did what she was supposed to do |
Very happy to hear you are both OK.Wow.
Did it happen at Cable? Nevermind... have another drink you two... very
happy indeed.
All the Best to you both, Kevin Klinefelter
Thomas Scherer wrote:
was lost tonight on a take-off failure with me and Kim Prout aboard.,
put her down at the end of the runway with a droop and fence ahead.
to the design of the central tunnel and the wheel attachment that
we're not only alive but walked away unharmed from a complete crash,
the firewall foward (which broke off 1oo %) and the gears which were
lost about 2oo feet short off the crash site.
it the entire afternoon and found it to be very smooth - I fear I
installed as new fuel filter which should not have been there - more
later.
you ... you will hear again of N81EU.
890 hrs under her belly and never missed a beat (Rotax 912).
more later
<Thomas N81EU>
She was flying right to the end. Europa rulez !
_________________ Europa XS, Mono Wheel N211KA
Intercooled 914, Airmaster Prop |
Posted: Mon Feb 26, 2007 12:05 am Post subject: she did what she was supposed to do |
Hi! Thomas.
Sad to hear the news about the a/c and pleased you are generally OK.
Unfortunately on take off it only needs to miss "one beat", I'm
wondering if you had been able to do a long full power test prior to
departure? When I had my fuel blockage (due to drilling restrictions in
the tank connectors) I had been unable to restrain the a/c on the trike
gear brakes on full power for longer than to "bounce" the max. RPM on
the tacho. I then resorted to lengthy full power checks with one brake
only (so long as folks are clear!)
It does look like you are a lunatic but allows an extended full power
run up. Anyway Having done it I still had first main tank engine fail
followed by reserve tank engine fail in the same take off run but with a
runway about 2 miles long ! (no damage occurred)However ................
I am still in the repair process of G-PTAG since a nose wheel yoke
departure last May so take some comfort that you aren't alone in your
trials!
Hopefully your replacement Rotax becomes available quicker than mine
which is due in April.
Bob Harrison G-PTAG
Do not archive.
willie.harrison(at)tinyon Guest
Posted: Mon Feb 26, 2007 1:12 am Post subject: she did what she was supposed to do |
Hey, Thomas, any landing you can walk away from is a good landing.
What is the story regarding the fuel filter?
Hope you get back on the horse soon.
Cheers
Willie Harrison
On 26 Feb 2007, at 04:57, Thomas Scherer wrote:
<thomas(at)scherer.com>
N81EU was lost tonight on a take-off failure with me and Kim Prout
aboard.,
to put her down at the end of the runway with a droop and fence ahead.
gear (trigear) and tearing off the firewall foward.
it to the design of the central tunnel and the wheel attachment
that we're not only alive but walked away unharmed from a complete
crash,
except the firewall foward (which broke off 1oo %) and the gears
which were lost about 2oo feet short off the crash site.
on it the entire afternoon and found it to be very smooth - I fear
I installed as new fuel filter which should not have been there -
more later.
promise you ... you will hear again of N81EU.
has 890 hrs under her belly and never missed a beat (Rotax 912).
more later
<Thomas N81EU>
firewall sheared off our feet were in the void and got hurt on the
last impact. She was flying right to the end. Europa rulez !
rogerabc
Posted: Mon Feb 26, 2007 1:13 am Post subject: she did what she was supposed to do |
Glad to hear you are both OK, it sounds like you did a good job Thomas.
I think that for even the most careful of us "fate is the hunter".
Good luck with the rebuild, aufweidersehn
Roger
___________________________________________________________
http://uk.docs.yahoo.com/nowyoucan.html
gcrowder2
Joined: 09 Jan 2006 Posts: 136 Location: Golden, Colorado USA
Posted: Mon Feb 26, 2007 9:37 am Post subject: she did what she was supposed to do |
Wow Tom - glad you're OK. Just shows you can turn into a glider at any
time.
Sounds like the Europa is the plane I want to be in when I do an off field
landing!
I'm headed to the bar right now to celebrate your adventure!
Glenn
| Quote: | From: "Thomas Scherer" <thomas(at)scherer.com>
Reply-To: europa-list(at)matronics.com
To: <europa-list(at)matronics.com>
Subject: she did what she was supposed to do
Date: Sun, 25 Feb 2007 20:57:05 -0800
the entire afternoon and found it to be very smooth - I fear I installed as
new fuel filter which should not have been there - more later.
more later
<Thomas N81EU>
Find what you need at prices you’ll love. Compare products and save at MSN®
Shopping.
http://shopping.msn.com/default/shp/?ptnrid=37,ptnrdata 4102&tcode=T001MSN20A0701
karelvranken(at)hotmail.c Guest
Posted: Mon Feb 26, 2007 9:50 am Post subject: she did what she was supposed to do |
Dear Thomas and Kim,
We realy feel sad for the accident and admire your courage.
Wish you both a quick recover.
Karel Vranken # 447 F-PKRL
----- Original Messaadmire your couragege -----
Sent: Monday, February 26, 2007 5:57 AM
Mijn Postvak In wordt beschermd door SPAMfighter
0 spam-mails zijn er tot op heden geblokkeerd.
Download de gratis SPAMfighter vandaag nog!
fklein(at)orcasonline.com Guest
Posted: Mon Feb 26, 2007 10:36 am Post subject: she did what she was supposed to do |
Thomas,
I salute your airmanship skills in that suddenly very quiet moment and
hope that "the morning after" has you still walking around.
I'm looking forward to reading your debriefing which I'm sure will be
thorough. I'm particularly interested in knowing whether or not you had
installed any means by which the height of your shoulder straps was
raised as others have done to alleviate possible compression of
vertebrae in the event of the kind of accident you've experienced.
Fred
kpaviat(at)verizon.net Guest
Posted: Wed Feb 28, 2007 11:11 am Post subject: she did what she was supposed to do |
Hi Roger!
Wow, what a ride....
There were a thousand things that could have gone really wrong, but only one
way this was going to work out OK for me and Thomas. Looking at the initial
impact point at the end of the runway and where the aircraft hit a second
time below that level in a gravel clearing is certainly sobering. Anyway, I
feel blessed, with a small scratch, a small bruise and a bit of a sore neck
(probably from taking a bad tumble playing raquetball earlier that morning
anyway). Getting out of the airplane was simple. The firewall forward broke
open and tilted downward leaving a large (enough) opening that I could just
stand up and walk out through. No need to open the canopy!
This hasn't disheartened me in any way from continuing flying my Europa.
Thanks to everyone for their concern and condolences.
I will be at Sun and Fun this year (flying out commercial) to help my
friend at IK Technologies and to visit my Uncle and my niece and her family
in Bradenton. Then June 5 through June 21, I will travel to Sweden (Gotland)
to visit Gert and Inger Martinsson at the old military airbase there that
they bought a few years ago. We're thinking about how to set up a small
Europa fly-in there.
Anyway, I hope you and your family are doing well!
Mom and Dad always ask about you and enjoy remembering the times we had
together here.
Cheers and ....happy skies!
kp
